Old Oct 19, 2004, 04:19 AM
kestrel2003 is offline
Find More Posts by kestrel2003
No Guts No Glory
kestrel2003's Avatar
Switzerland
Joined Feb 2003
Depron Biplane
My first biplane. It is all made out of Depron and uses a geared speed 300 (some GWS?) from the Protech Tojeiro. I put a Hacker into the tojeiro, so I was left with this engine. I went with a simple flat plate wing and added the struts between the wing so as to create turbulances along the plate.I do not know if this helps the plane or not
It flies very well, but only with the engine running. It has a glide angle of a Brick/Manhole. But it looks neat , well I think so ,and flies ok
kestrel2003 is offline Find More Posts by kestrel2003
Old Oct 25, 2004, 05:31 PM
foamflyer is offline
Find More Posts by foamflyer
Trapped in California
foamflyer's Avatar
United States, CA, Quartz Hill
Joined Nov 2003
Very nice kestrel2003. Biplanes are pretty draggy anyway.
foamflyer is offline Find More Posts by foamflyer
Old Oct 25, 2004, 05:49 PM
stjobs is offline
Find More Posts by stjobs
Gainesville, Florida, United States
Joined Sep 2001
Interesting looking. I wonder why the glide is poor? Maybe the CG is too far forward?
stjobs is offline Find More Posts by stjobs
Old Oct 26, 2004, 01:39 AM
No Guts No Glory
Switzerland
Joined Feb 2003
Cg
that is a good point. I will ad 5gr. near the tail and see if it helps. That is when it finally stops raining. I did not calculate the CG, I just used my "intuition". It seamed ok and it flys well powered and did not need much trimming. Thanks for the tip
Old Oct 26, 2004, 09:08 AM
jimkirley is offline
Find More Posts by jimkirley
Joined Jul 2004
Just to help you out, might consider the following changes, depron and fff are stronger than you think, balsa reinforcements not always needed, hot glue and kabob squiers, work great as wing stiffners, also can replace the depron you have between the wings, way less drag, 2 depron formers spaced 3/4 " apart and motor stick hole cut into them is fine, no balsa needed, bread plastic closers can be used as control horns and work great and less work, and it looks as if you could reduce the size of both the horz. and vert. stabs by about 1/3. Might want to go to az chuck r/c and look at his cheat sheet for slow fliers parameters. Keep building! It's really hard to spend $40/200 on a kit once you build a sucessful airplane from scratch-Best of luck!
jimkirley is offline Find More Posts by jimkirley
Old Oct 26, 2004, 12:57 PM
No Guts No Glory
Switzerland
Joined Feb 2003
Kit VS Scratch built
Thanks for the tips. I agree that thier is nothing as cool as seeing a scrathbuild plane fly well. But I still enjoy building a kit from time to time, as I have almost always learned a lot from building them. I will certainly reduce the Stab and play with the cg
Old Oct 26, 2004, 01:30 PM
REVKEV6 is offline
Find More Posts by REVKEV6
massachusetts
Joined Apr 2003
I think I can help ya with the glide a bit. to make as efficient use of the biplane setup as possible you have the two wings as far apart from each other as the cord of the wing. so if your wing has a cord of 3 inches the two wings should be at least 3 inches apart. my guess is you are fowling the top wing without the power on.
REVKEV6 is offline Find More Posts by REVKEV6
Old Oct 26, 2004, 04:46 PM
Al Dente is offline
Find More Posts by Al Dente
Joined Mar 2003
Kestrel I too built my first own design this week,though "design" would be overstatement.Just took some packing foam from my last computor and cut and shut it a little.She looks a lot like a sister of your plane,the ugly one though.Put my ailerons on the lower wing,made her all moving tail ,same Gws type power on 3s 700 li-po.Flys great though like yours ,mine does not like power off,I think revkev6 nailed that one;still,live and learn.Jimkirleys post included lots of other stuff I wish I had known sooner.Had five flights out of her and really regretted having to take the bits out of her today but my second attempt at an indoor foamie needed the transplant.Didn't try the first attempt indoors,too fast,too heavy and that brick like glide.Mk 2 is more of a flying plank,went for a sort of space ship look and ended up with a wheel barrow.Maiden tomorrow,weather willing.Regards all,Al.
Al Dente is offline Find More Posts by Al Dente
Old Oct 27, 2004, 06:32 PM
Al Dente is offline
Joined Mar 2003
Well weather was sort of willing for the test flight of my second attempt at an indoor foamie,bit windy.Made the elevons big,thought it would help indoors.Well looks like another failure for indoors,though I'm sure she will be fine outdoors,once tamed a little.Just took off and went into the start of a big loop[thought a little up might be wise,wrong] just had time to shut off the power before the floor rearranged the foam a bit.Next time less control throw,plus a test glide first, if she is still a handfull a smaller motor.Regards Al.
Build Log "Bipie" - Profile depron biplane cartoon style chara Foamies (Scratchbuilt) 711 Aug 01, 2016 04:57 PM
ParkBipe - Depron Biplane Photon Foamies (Kits) 22 Dec 01, 2011 02:06 AM
3mm-depron biplane design (images) kevbeer 3D Flying 11 Mar 03, 2005 02:50 AM
Depron Biplane - My first scratch build pjsmith The Builders Workshop 0 Jun 28, 2004 05:30 AM
Video of Matt Fritz Depron Biplane... kepople Foamies (Kits) 11 Oct 17, 2003 09:41 AM
