Old Feb 16, 2002, 05:53 PM
DerekB is offline
Find More Posts by DerekB
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Help with power supply to foam cutter
I got this old model train transformer today to use for hot wire foam cutting. I don't get along with electrons, so could someone tell me which terminals to hook to my Nichrome cutting wire?
There are 4 terminals, numbered 1, 2, 3, and 4. The label says: Revell 800 Plus Power Station Model A Toy Transformer.
Input: 115 volts 60 cycles AC
Output: 15 Volt - Amperes
Terminals: 1 & 2 for 22 Volts AC
3 & 4 for 1 to 18 Volts DC
Which terminals do I hook up to. Does the control knob vary the AC output or the DC output? Will I be able to vary the heat in the wire?
Please help. I have my first foamie all ready to cut.
Derek
DerekB is offline Find More Posts by DerekB
Old Feb 16, 2002, 06:28 PM
iflyelectric is offline
Find More Posts by iflyelectric
Boulder Municipal, Colorado, United States
Joined Sep 2001
Normally the AC is used to power the lights, etc. on the layout. Use the DC for you foam cutting. If in doubt, just hook up your wires and do a test on a scrap of foam while varying the speed on the transformer. If the wire continues to cut at the same rate, you have it hooked up to the wrong terminals.
iflyelectric is offline Find More Posts by iflyelectric
Old Feb 16, 2002, 06:37 PM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Thanks 'ifly',
Should I just hook alligator clips directly to the nichrome near the ends of the nichrome? Or, I've seen other rigs with wheel collars on the 5/32" rods, up near the wood handle. The power supply wires are soldered to the wheel collars then taped along the wood handle to exit at one end. This seems more sensible for safety and easy handling. But is first way better for delivery of power to the cutting wire?
Derek
Old Feb 16, 2002, 07:01 PM
Joined Sep 2001
Not real sure about the collars. I've always just used the alligator clips. Mainly because I have 2 foam cutters (one for cutting out the blocks and thicknessing them so I can attach the templates. The other cutter is used to cut the cores.
Old Feb 16, 2002, 07:15 PM
Joined Sep 2001
Are you going to have a friend helping you cut the cores by calling out the numbers? If so it works better to be able to have an adjustable clamp for each person so the distance from the templates are about 2" or so. That way you can clamp the alligator clips just inside the clamps. For my clamp, I cut a slit in 2 thick 2 pieces of fiberglass blocks for each side (about 2" square), drilled 2 holes in each and clamped them around the wire so the slits are at 90 degrees to each other. This makes a pretty good handle. I also suspend my bow from the ceiling so it dangles just above the templates. This gives me a good balance on the bow with no friction as is the case with a tail wheel runing on the table. I can take a picture later and post it if youd like.
Old Feb 16, 2002, 08:25 PM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
It's working
I'm cutting foam!!! I got it working. Thanks 'ifly'. Here's a photo of my bow. It's just 12" and I'll make a longer one later for the wings. It cuts fine at half setting, so lots of power in reserve.
Yes, please post a photo of your bow for wings.
How tight should the wire be?
By the way, here is my project:
http://216.40.226.212/~admin2/forums...threadid=27799
and the resulting templates:
http://216.40.226.212/~admin2/forums...threadid=28758
Derek
Old Feb 17, 2002, 12:29 AM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Fuselage is cut
I got the fuselage rough cut. Thanks. Some photos are posted on my original thread:
Derek
Question Need help with power supply (Celestica 7000 Series) lgehrig4 Batteries and Chargers 1 Feb 05, 2008 07:11 AM
Discussion Need help with power supply. Tophinater DIY Electronics 12 Jan 14, 2006 03:44 PM
Help with power supply for foam cutting zbrubaker Foamies (Kits) 0 Oct 28, 2002 05:45 AM
Need help with power choice 3.5 lb Cub, Endoplasma? slowflyer Electric Plane Talk 3 Aug 01, 2001 02:16 PM
HELP! Computor power supply problems newflyer Life, The Universe, and Politics 1 Jun 18, 2001 06:20 PM
