Old Oct 18, 2004, 01:44 PM
mrbaseballny is offline
Find More Posts by mrbaseballny
mrbaseballny's Avatar
Joined Sep 2004
Which motor for the Wemotec Midi Fan??
I was looking at the Wemotec Midi fan, the 90mm one on the wemotec site. It says it can produce up to 20N of thrust, or roughly 5 pounds of thrust. My questions is this: What motor are they using to reach those figures? I imagine it would be a brushless using a lipo for power. Anyone know the answers to this?? Suggestions would be very greatfull as well.
mrbaseballny is offline Find More Posts by mrbaseballny
Old Oct 18, 2004, 03:34 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
http://www.eam.net/Wemotec/midi_fan.htm
Here's a link which lists several motors which can get you 20N @ 1000W input.
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 20, 2004, 02:40 PM
Norman Greene is offline
Find More Posts by Norman Greene
Dublin, Ireland
Joined Mar 2002
Any quality brushless motor capable of 600 watts will do it.
Kontronik Fun 600.20 for example
If you use a motor with 2000 rpm per volt (2000 Kv) you can use 14-18 cells.
Suitable cells would be RC2400 nicads, GP3300 Nimhs, or equivalent.
Norman in Dublin
www.greenhobbymodel.com
Norman Greene is offline Find More Posts by Norman Greene
Old Oct 20, 2004, 02:59 PM
kriptonic is offline
Find More Posts by kriptonic
kriptonic's Avatar
Los Angeles
Joined Aug 2004
In my Harrier I'll be using a Midi Fan with an Aveox 36-30-2 and i'll probably get the jeti 77 amp cus it can go upto 30 cells, or the hacker 77 opto..... (i think they are the exact same esc, just that one has the hacker wraping on it) off of probably 6s4p up to 8s3p.... I should be around 1250 watts to 1450 watts depending on battery. Talk about power,,, I hope i have enough.
Gene.
kriptonic is offline Find More Posts by kriptonic
Old Oct 20, 2004, 03:04 PM
Joined Sep 2004
Gene, where are you getting the Aveox motor?
Motor for a Wemotec micro fan? picard1 Electric Ducted Fan Jet Talk 11 Dec 06, 2005 03:18 AM
Torque value for Wemotec Midi Fan 90mm ashvani Electric Ducted Fan Jet Talk 10 Oct 04, 2005 04:58 AM
how do you calculate thrust for WeMoTec midi fan? gensis5280 Electric Ducted Fan Jet Talk 1 Dec 30, 2004 05:35 PM
Best Motor For The Wemotec HW 609 Fan Joe Elston Electric Ducted Fan Jet Talk 12 Jul 29, 2002 08:19 PM
Best Motor for Wemotec Micro-fan Gordon Electric Ducted Fan Jet Talk 16 Jun 10, 2001 11:23 PM
