Old Oct 18, 2004, 09:22 AM
rthorne is offline
Find More Posts by rthorne
Quit Chucking My Wood
rthorne's Avatar
USA, TX, Amarillo
Joined Dec 2003
Scale Conversion: Watts to Weight Ratio?
I'm in the process of determining which motor/battery combo to put in an HF Model ASW28 3 meter bird. I'd like to run an AXI 2826/10 or /12 with a 3s2p 2200 lithium pack
I'm not looking for a rocket ship, just something to get it up in the air a couple of times so I can thermal around.
I was thinking that 50 watts per pound ought to handle it.
Whats the wisdom of this group think?
Rich
rthorne is offline Find More Posts by rthorne
Old Oct 18, 2004, 01:20 PM
Lenny970 is offline
Find More Posts by Lenny970
Lenny970's Avatar
Greeley, Colorado, USA
Joined Feb 2000
Rich,
I've converted several (3.5-6.6 meter) scale sailplanes to electric. I generally design the power system for about 75 watts per pound. This gives a strong, not rocket ship climb rate. I'd guess the typical climb angle would be around 30 degrees. I'm sure you could safely use something less than 75, but 50 watts per pound sounds a bit low to me.
Good luck,
Lenny
Lenny970 is offline Find More Posts by Lenny970
Old Oct 18, 2004, 02:36 PM
rthorne is offline
rthorne's Avatar
USA, TX, Amarillo
Joined Dec 2003
Hi Lenny:
Thats what I needed to know.
I have a AXI 4120-18 on a Hanger 9 Funtanna with 6s2p 2200 irate cells. However, I think the motor is too big as well as the batteries from a weight stand point.
What do you recommend for a motor and/or gear box combination to put in a 80 to 90 oz scale bird?\
Rich
Old Oct 20, 2004, 08:05 AM
gustabmo is offline
Find More Posts by gustabmo
Gustavo Exel
gustabmo's Avatar
Switzerland, GE, Geneva
Joined May 2003
Hello,
Are you speaking motor input or output watts ?
gustabmo is offline Find More Posts by gustabmo
Old Oct 20, 2004, 09:30 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
We use input watts..
..a
Discussion Who has the highest power to weight ratio? Post your watts/pound setup! dalbert02 Electric Plane Talk 23 Dec 10, 2006 09:45 PM
Gear drives effect on power/weight ratio Shakey Jake Power Systems 6 Mar 17, 2002 09:25 AM
Thrust to Weight Ratio??? sapok Beginner Training Area (Aircraft-Electric) 1 Feb 23, 2002 04:21 AM
Thrust to weight ratio Frank B Electric Plane Talk 6 Oct 19, 2001 07:08 AM
What type of scale should i buy to weight my planes??? JStory Electric Plane Talk 2 Aug 08, 2001 04:01 AM
