Old Oct 17, 2004, 11:16 PM
MartinL is offline
Find More Posts by MartinL
Australia
Joined Oct 2000
Indoor RC with GWS IPS gears
Has anyone made an indoor ornithopter with GWS IPS gears?? It will be nice to have a go at it instead of flying commercial unit.
MartinL is offline Find More Posts by MartinL
Old Oct 18, 2004, 05:09 AM
KOROBELNIK is offline
Find More Posts by KOROBELNIK
KOROBELNIK's Avatar
PARIS
Joined Oct 2002
goto:
http://www.rcgroups.com/forums/showt...=162934&page=2
& old thread
KOROBELNIK is offline Find More Posts by KOROBELNIK
Old Oct 18, 2004, 11:53 AM
FrancisG is offline
Find More Posts by FrancisG
FrancisG's Avatar
Dijon. France
Joined Nov 2002
Yes, Martin
My Birdy http://perso.wanadoo.fr/francis.girault/birdy.htm use the GWS IPS with GWS gears, ball bearings and shafts ( http://www.aircraft-world.com/ ) .
Pinion M0,3 10T, gears 86/16T M0,3/0,4 and 66T M0,4 for 1/35,47 reduction, Etec 2S 250mAh and 56cm wing, but it's not perfect. The gearbox (30g with motor) is perhaps too heavy! I made a new wing at the present time.
Francis
FrancisG is offline Find More Posts by FrancisG
Old Oct 18, 2004, 05:45 PM
andyUK is offline
Find More Posts by andyUK
London,England,UK
Joined Jan 2001
Hi Francis
This bird could do with this motor
http://robotbirds.com/catalog/produc...roducts_id=164
Has made all GWS models a bit more exciting
Andy
andyUK is offline Find More Posts by andyUK
Old Oct 19, 2004, 07:16 AM
FrancisG is offline
FrancisG's Avatar
Dijon. France
Joined Nov 2002
Very interesting, Andy, thanks, but I prefer (the price of!) the brushed motors to brushless
Francis
Old Oct 19, 2004, 12:57 PM
Raj Quest is offline
Find More Posts by Raj Quest
Joined Aug 2004
This may not be the best place to post this question but I don't know where else to do it.........
Is the Mabuchi FF-030-PA/PK suitable for ornithopter/cui-cui ?
data-sheet on:
http://www.mabuchi-motor.co.jp/engli...uct/index.html
Requesting FrancisG, Korobelnik, and other experts to help.....Please
Raj.
Raj Quest is offline Find More Posts by Raj Quest
Old Oct 19, 2004, 03:25 PM
FrancisG is offline
FrancisG's Avatar
Dijon. France
Joined Nov 2002
Raj,
Good place, good question, but ...I do'nt know. This is a low price motor, try !!!
Francis
Old Oct 19, 2004, 05:41 PM
KOROBELNIK's Avatar
PARIS
Joined Oct 2002
Raj,
I had no time to build a Cui-Cui.
Jean-Claude PESCE Designer of the Cui-Cui uses the DC 5-2-4.
You will find easily this DC 5-2-4 at Wess technik
http://www.wes-technik.de/English/motors.htm
If the characteristics of Mabuchi FF-030-PA / PK are identical or better then it will work also
Good courage
Robert Korobelnik
Old Oct 20, 2004, 12:28 AM
Joined Aug 2004
Robert,
Thanks for your guidence.
Best thing would be to use what is specified by the designer for sure success, OR
to fiddle around and actually try out another motor and see the results.
Francis,
I like your approach to "Birdy" for keeping the cost low.
But I think that needs a lot of patience and hard work.
I also fell in love with the "parrot" and the "chicken" on your web site.
Extremely well finished, excellent expressions on the faces of these birds.
The Red frame - is it FRP ? or is it Carbon painted red ? or is it plywood painted red ?
Raj
Old Oct 20, 2004, 04:47 AM
FrancisG is offline
FrancisG's Avatar
Dijon. France
Joined Nov 2002
It's very kind, Raj !
They are in painted epoxy (FR4) (printed electronic circuit without copper, I use some "perchlorure" (in french) of iron).
"But I think that needs a lot of patience and hard work." : no, no, Raj, I'm just an ordinary model maker !
Francis
Old Oct 20, 2004, 07:03 AM
Joined Aug 2004
"no, no, Raj, I'm just an ordinary model maker"
Very modest indeed.
Thanks Francis
Raj.
Old Oct 20, 2004, 10:08 AM
Chronister is offline
Find More Posts by Chronister
Nathan Chronister
Chronister's Avatar
Joined Jun 2003
I've built two models using the GWS motor and gears. One of them flies really well. The GWS gears do not allow enough reduction. It flies but it draws a lot of current.
Chronister is offline Find More Posts by Chronister
Old Oct 20, 2004, 10:54 AM
FrancisG is offline
FrancisG's Avatar
Dijon. France
Joined Nov 2002
Raj,
No false modesty: the work of Sean Kinkade (Alias Leonardo with the black glasses ) for the Skybird and the Parkhawk was fantastic! But to copy or to be inspired is less difficult... To make a gearbox is not very hard, the precision is required, yes, but it's not insurmountable. The rest of an orni is half kite, half aircraft. As says Nike: just do it!
Francis
Old Oct 20, 2004, 12:47 PM
Joined Aug 2004
Francis,
I Agree.
Friends,
Is there any online store for GWS IPS ?
Raj.
Old Nov 15, 2004, 04:16 PM
Aio_1 is offline
Find More Posts by Aio_1
Aio_1's Avatar
Ireland, Kildare, Leixlip
Joined May 2002
Hi guys,
This thread has been dormant for a while so I'm not sure if anyone's still interested but:
Raj,
Many if not most of the online places do IPS drives. For example www.Aircraft-world.com.
Francis,
You list your bird as having 2s cells and being short on power. The standard IPS motor works far better on 3s. Efficiency is better and you can run it at 2A pretty reliably (possibly a bit higher if you have a heat sink). I know this would require gearing changes but you can double the power output for the weight of an additional cell. Also the motor is probably close to the brushless for efficiency when you use it like this.
Aidan
Aio_1 is offline Find More Posts by Aio_1
Home made micro heli with GWS IPS power kwan Micro Helis 16 Jun 15, 2003 11:09 PM
Effect of gearing with GWS IPS units. Ahawk Beginner Training Area (Aircraft-Electric) 1 Aug 27, 2002 08:48 PM
7 cell 300 mah nicad ok with GWS IPS? Hammer Head Electric Plane Talk 4 Jun 21, 2002 01:36 AM
GWS IPS gears with EDF50's High power C motor GWS4CEO Parkflyers 16 Nov 18, 2001 07:15 PM
Mix 'n Match GWS IPS Gears? Dave Hederich Parkflyers 9 Nov 05, 2001 06:04 PM
