Old Oct 17, 2004, 10:20 PM
Tawg is offline
Find More Posts by Tawg
Moderatee buncha places
Tawg's Avatar
Southern California
Joined Aug 2003
48" LEG P-40 hybrid
How about a good 'ol fashoined build thread.
This is a Leading Edge Glider kit that will have a wide root wing. It will be similar to two of the three Helcats I built a few months ago: http://www.rcgroups.com/forums/showt...2&page=1&pp=15
so sit back, relax, and enjoy!
Tawg is offline Find More Posts by Tawg
Old Oct 17, 2004, 10:23 PM
1 zipper is offline
Find More Posts by 1 zipper
If its blown Im slop'n
1 zipper's Avatar
Sydney Australia
Joined May 2004
Tawg
All ways up for one of you build threads
Let the building begin
1 zipper is offline Find More Posts by 1 zipper
Old Oct 17, 2004, 10:26 PM
Tawg is offline
Tawg's Avatar
Southern California
Joined Aug 2003
Here are all the pieces out of the box. when you look at it in this state its easy to convince yourself it shuldnt be that difficult because there isnt a bunch of pieces.
Here is the difference between the standard wing and the wide root one. A standard wing is a good two inches smaller. They have the same airfoil (RG14).
Old Oct 17, 2004, 10:31 PM
Tawg is offline
Tawg's Avatar
Southern California
Joined Aug 2003
I started with glueing the scarf joints on the spars with tight-bond wood glue.
Old Oct 17, 2004, 10:32 PM
Tawg is offline
Tawg's Avatar
Southern California
Joined Aug 2003
Originally Posted by 1 zipper
Tawg
Thanks, and congrats on your 60th
Tawg
Old Oct 17, 2004, 10:36 PM
Tawg is offline
Tawg's Avatar
Southern California
Joined Aug 2003
I then outlined and cut out the slot for the smaller spar stiffiner with a sharp sanp blade.
Old Oct 17, 2004, 10:41 PM
Tawg is offline
Tawg's Avatar
Southern California
Joined Aug 2003
I like to cut about 1/2 of an inch off the tips of my spars to prevent them from poking out after a few rough landings.
Old Oct 17, 2004, 10:45 PM
monti is offline
Find More Posts by monti
monti's Avatar
So Cal.
Joined Jan 2003
I hate to ask stoopid question so early but how do you get the bottom of that cut so smooth? all of my spar cuts look like i cut it out with a claw hammer
monti is offline Find More Posts by monti
Old Oct 17, 2004, 10:52 PM
Tawg is offline
Tawg's Avatar
Southern California
Joined Aug 2003
in the back ground of post #6 you can see little 2-3" pieces of foam i cut out. I set the depth of the snap blade to just barely exceed the width of the spar and cut my outline first. Then I extend the blade all the way out and press it flat against the pre existing spar cut and remove little pices at a time insted of all at once.
Bring on the questions!
Tawg
Old Oct 17, 2004, 10:55 PM
InTheLift is offline
Find More Posts by InTheLift
It could happen...
InTheLift's Avatar
Torrance, California
Joined Jan 2004
Always up for a build thread Tawg, thanks! What's with this kit and the wide wing, new release fron LEG?
Like the new avitar.
InTheLift is offline Find More Posts by InTheLift
Old Oct 17, 2004, 11:10 PM
Aerobat152A is offline
Find More Posts by Aerobat152A
Tryin not to be a hack!!
Aerobat152A's Avatar
SoCal
Joined May 2004
OK, lets see what the Tawgsters up to now..........oh nice!!! Im gonna start calling you Teacher....... Teacher!! Adding this to my collection of Tawg build threads!!
Kevin, the other one...not number one...geez...you know what I mean!!
Aerobat152A is offline Find More Posts by Aerobat152A
Old Oct 18, 2004, 08:56 AM
Tawg is offline
Tawg's Avatar
Southern California
Joined Aug 2003
Yes, you can order your 48" kits with this wing. It helps diversify the wing loading for light lift days or for combat. It takes away from the scale looks but makes it a lot easier to handle. It still performs well due to keeping the same airfoil vs Leading Edge Gliders older wide root wings (Hellcat/ Patriot) had a 3016 or 3021 airfoil.
Tawg
Old Oct 18, 2004, 08:58 AM
Tawg is offline
Tawg's Avatar
Southern California
Joined Aug 2003
Thanks Kevin
I have no doubt with your building skills that your foamy will shadow all mine with quality
Tawg
Old Oct 18, 2004, 02:16 PM
Doc Holiday48 is offline
Find More Posts by Doc Holiday48
I'm your huckleberry
Doc Holiday48's Avatar
USA, CA, Gardena
Joined Jun 2004
Hey Tawg,
Have you had this kit for a while, or is this a new kit coming out of Kansas. Just curious because I'm still waiting. I know they are supposed to be shipping soon.
Bob
Doc Holiday48 is offline Find More Posts by Doc Holiday48
Old Oct 18, 2004, 02:37 PM
Louied is offline
Find More Posts by Louied
ALL IN !
Louied's Avatar
Carlsbad, California, United States
Joined Feb 2004
Hey that Gear looks familiar
Louied is offline Find More Posts by Louied
Sold LEG 60" ME-109 and 48" P-40 Kit Combo NIB BenH Aircraft - Sailplanes (FS/W) 3 Jun 18, 2007 07:55 PM
Sold Partially built 48" LEG P-40 *Price Reduced* codezilla Aircraft - Sailplanes (FS/W) 2 Dec 05, 2006 06:13 PM
FS: LEG 60" P-51 and 48" P-40 nib donaldl00 Aircraft - Sailplanes (FS/W) 3 Nov 09, 2004 10:36 AM
LEG P-40 Toothjob masson74 Slope 21 Feb 18, 2004 04:59 PM
Need a little help w/ LEG P-40 gunnisonflyer Slope 23 Jan 01, 2004 01:01 PM
