Oct 18, 2004, 01:24 PM
Most Southern England, Brighton UK
Joined May 2004
Great advice!...Ok, isn't my prop a GWS 5x3?? It looks like it in the picture. I am not sure about the prop quality, so sanding to a better shape sounds like a good idea. I never realised a CF prop would be less efficient, so whats the point of using one??
I will be getting a Didel 6.6:1 gearbox for 6mm 4.5 ohm pager soon so i will compare mine to see what the problem is, could be a prop problem. I guess my thrust measurement is'nt totally reliable, but the thrust sure doesn't feel like 14 grams thrust, so 10 sounds about right. Also my 4.5 ohm pager was getting rather hot, which hasn't happened to me before. The gears are not matched pairs and are rather good but not brilliant.
If i am not correct, i should get between 14 grams to 14.8 grams with a GWS 5x3 on 6.5:1 ratio to 6.7:1 ratio? Overall, my gearbox isn't very good, it can be improved and it only relies on the ply as a bearing, what could i use instead? For a 15gram< model (light wing loading), is 10 grams of thrust going to keep it airbourne? That is my bare minimum thrust. Thanks for the expert advice!!
