Old Oct 17, 2004, 11:53 AM
717 is offline
717
Find More Posts by 717
717
717's Avatar
SF Bay Area, CA, USA
Joined Apr 2003
2 or 4 screws to mount Axi 2820/12?
Only 2 of the 4 pre-drilled mounting holes line up with my motor's holes. With cooling holes now drilled, I'm worried that the wood may get too sparse if I redrill the extra two holes.
Should I use all 4 screws or just 2 to mount the Axi 2820/12 to a hardwood mount?
717 is offline Find More Posts by 717
Old Oct 17, 2004, 02:49 PM
John E is offline
Find More Posts by John E
Bristol, England
Joined Aug 2000
Use 4 screws, perhaps it is better to start with a fresh piece of birch ply.
Drill the 4 mounting holes, 4mm at 25mm centres. Next drill 6mm holes between the 4mm holes for cooling. You should find that everything then lines up nicely.
Best regards,
John
John E is offline Find More Posts by John E
Old Oct 18, 2004, 09:20 AM
717 is offline
717
717
717's Avatar
Joined Apr 2003
Thanks John.
For now I've tentatively installed it with only 2 screws for testing purposes. It seems stong but one can never be sure. I may end up using your idea before maiden flight.
Old Oct 18, 2004, 09:56 AM
unbalanced prop is offline
Find More Posts by unbalanced prop
unbalanced prop's Avatar
Washington, PA, USA
Joined Aug 2003
I have been flying two of these motors all summer with just two screws, and it has been working just fine.
Doug
unbalanced prop is offline Find More Posts by unbalanced prop
Old Oct 18, 2004, 12:10 PM
rclark is offline
Find More Posts by rclark
A Clinger
rclark's Avatar
Butte, MT
Joined Sep 2001
Two screws for me...
rclark is offline Find More Posts by rclark
Old Oct 18, 2004, 03:14 PM
717 is offline
717
717
717's Avatar
Joined Apr 2003
Do you two-screw types use any sort of lock-washers or lock-tight? I just used regular flat washers.
Old Oct 18, 2004, 03:34 PM
Washington, PA, USA
Joined Aug 2003
I been using the star type lock washers and have not had them loosen at all. I have used them on AXI and Orbit motors successfully. (Orbits 15s only have two on the motor)
Doug
Old Oct 18, 2004, 05:11 PM
717 is offline
717
717
717's Avatar
Joined Apr 2003
Great! I'll get some star washers and be all set.
Thanks for the help.
Sold AXI 2820/12 With Radial Mount - Good Condition szastoupil Aircraft - Electric - Power Systems (FS/W) 2 Aug 19, 2006 10:31 PM
Found Axi 2820/12 or E-Flite Power 15 Twmaster Aircraft - Electric - Power Systems (FS/W) 4 Aug 19, 2006 06:02 PM
Wanted WTB Axi 2820/12 or 2826/12 and Jeti 40a lipo ESC Greg McNair Aircraft - Electric - Power Systems (FS/W) 1 May 14, 2006 12:10 AM
WTB: AXI 2820\12 - New or Like New bige Aircraft - Electric - Airplanes (FS/W) 2 Jan 15, 2005 12:47 PM
AXI 2820/12 or 2820/10?? Piper Power Systems 0 Jan 23, 2004 09:33 PM
