Old Oct 17, 2004, 02:35 AM
Armchair Bronco is offline
Find More Posts by Armchair Bronco
In EPP I Trust...
Armchair Bronco's Avatar
Issaquah, Washington, United States
Joined Jan 2004
3M 77 alternatives for styrofoam
Too bad 3M started adding acetone to Super 77 a year or two ago. The new stuff doesn't eat EPP, but it'll melt styrofoam.
What should I use to make styrofoam wings tacky for applying packing tape (clear & fiberglass re-inforced)?
Are there any alternatives to 3M Super 77 (other than the obvious answer of tracking an old bottle of the black stuff)?
Armchair Bronco is offline Find More Posts by Armchair Bronco
Old Oct 17, 2004, 03:41 AM
Synth is offline
Find More Posts by Synth
We come in peace.
Synth's Avatar
Canada, BC, Penticton
Joined Feb 2003
Try Elmers. I hear it's much milder and is ok for styro.You should be able to find it at your local hardware store.
Synth is offline Find More Posts by Synth
Old Oct 17, 2004, 06:09 AM
In EPP I Trust...
Joined Jan 2004
There must be some spray on alternative to elmers.
With an old can of '77, I could have sprayed my entire plane in 10 15 seconds. Plus, I don't think I'd get comparable tackiness with elmers: wouldn't it go on wet and mess up the packing tape?
Old Oct 17, 2004, 07:21 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
3M 90 will work. I have heard you can get it at Home Depot, but I haven't checked.
You can also order it from Hillas packaging (www.hillas.com). The trick is, when you click add to cart, it adds an entire case, just change teh number to the number of cans you want. They stock it and will sell it by the single can. SOme stuff in their online catalog is case lots only.
Another neat thing they carry is 9mm wide filament tape. No more spliting 3/4" down to 3/8", 9mm is just under 3/8".
Pinecone is offline Find More Posts by Pinecone
Old Oct 17, 2004, 07:44 AM
M Ashmore is offline
Find More Posts by M Ashmore
Average User
M Ashmore's Avatar
Bakersfield, California
Joined Aug 2003
3M 77 works just fine. All you have to do is hold the can away from the foam about 10 to 12 inches to let the propellent evaporate. You get a much wider spray pattern, of course, so masking is a must. I've used it on all kinds of foam with no issues at all.
M Ashmore is offline Find More Posts by M Ashmore
Old Oct 17, 2004, 07:53 AM
Waldo Pepper is offline
Find More Posts by Waldo Pepper
e-flight in 24½th Century
Waldo Pepper's Avatar
Cypress, TX
Joined Jul 2004
Rumor has it that 3M 78 is the "old" 77 spray. This from foamfly.com
wp
Waldo Pepper is offline Find More Posts by Waldo Pepper
Old Oct 17, 2004, 08:55 AM
omega blood is offline
Find More Posts by omega blood
Will work for planes
omega blood's Avatar
Fullerton, California, United States
Joined Jan 2002
This is true.
This wing is all eps wing and I used the new 3-M77 to spray before covering with out a problem. http://www.rcgroups.com/forums/showp...81&postcount=2
omega blood is offline Find More Posts by omega blood
Old Oct 17, 2004, 09:51 AM
rcmann is offline
Find More Posts by rcmann
rcmann's Avatar
Joined Sep 2003
You can also pull out a length of tape, spray the tape (rather than the EPS), let it dry for 10-15 seconds and apply it to the EPS. I used this method recently and the tape stuck really well.
rcmann is offline Find More Posts by rcmann
Old Oct 17, 2004, 02:44 PM
windtrader is offline
Find More Posts by windtrader
Bay Area, Ca
Joined Jul 2004
Probably fact. Attached is the application guide for the 3M spray adhesives. Nice reference to have around.
windtrader is offline Find More Posts by windtrader
Old Oct 17, 2004, 03:00 PM
rcmann is offline
rcmann's Avatar
Joined Sep 2003
3M78 looks like the ticket, but where do you buy it?
Old Oct 17, 2004, 04:43 PM
Old Man is offline
Find More Posts by Old Man
Master of the figure 9
Old Man's Avatar
United States, IN, Indianapolis
Joined May 2004
I emailed 3M about to old 77 and they told me that they are still making it. The new formula is due to a California environmental law. They gave me a list of suppliers to contact. I contacted Graingers about getting the old fomula. I ordered a case of the old 3M 77 at $6.00 per 16.5 oz can! They list both the new and the old formula in their catolog. The formula you want is 3M id. #62-4437-4930-4.
Old Man is offline Find More Posts by Old Man
Old Oct 18, 2004, 10:41 AM
In EPP I Trust...
Joined Jan 2004
Woo hoo! Thanks for the tips and contact numbers. Figures it would be a California law that got in the way of easy access to "Old School" 3M 77...
Old Oct 19, 2004, 04:16 PM
FRAMEDNLVS is offline
Find More Posts by FRAMEDNLVS
Joined Jun 2004
gone fishing
FRAMEDNLVS is offline Find More Posts by FRAMEDNLVS
Old Oct 20, 2004, 01:58 AM
Ronbo is offline
Find More Posts by Ronbo
Retired USAF, A&P mechanic
Ronbo's Avatar
United States, WA, Puyallup
Joined Jul 2001
use 3m 61, corner bead. is about 5-6$ a can, same size as 3m 77 same stuff, just comes out pink so you can see it.
Ronbo is offline Find More Posts by Ronbo
Old Oct 20, 2004, 11:21 AM
Bay Area, Ca
Joined Jul 2004
@old man -
I just looked at the online Grainger catalog and in their hardcopy catalog #395. Neither shows the original formula. The online 3M catalog shows the stuff you bought but is listed as obsolete (in the 16 oz packaging). They do show it current as the "original" in 24oz cans which does not show in the Grainger catalogs.
You must have gotten lucky and found some of the old stock still in inventory somewhere.
http://products3.3m.com/catalog/Http..._1098289076676
Discussion 3M 77 spray for EPP bobert13581 Australia 17 Feb 13, 2006 11:06 PM
which is better for foam sheeting---3M 77 or probond? splatman Scale Kit/Scratch Built 5 Dec 12, 2003 08:41 AM
for those in CA, alternatives ? to 3M 77 ? epkoncept Foamies (Kits) 5 Sep 16, 2003 12:05 AM
Say goodbye to 3M 77 for foam covering rtideas The Builders Workshop 0 Jan 21, 2003 01:31 AM
3M 77 will no longer be safe for EPS! Ben74 Foamies (Kits) 6 Mar 08, 2002 02:13 PM
