Humor From The Building Bench
I'm in the process of building one of Mike Glass's Hell Raiser Ultimate 3D bipes. This plane is rapidly becoming the latest "must have" at the club flying field. It's not that I don't like flames, but I didn't want to have a carbon copy of everyone elses plane so I ordered an undecorated one and I'm now in the process of painting it.
The Hell Raiser is a Depron foam plane which limits the kinds of paints you use on it without melting the foam. I've been using the Testors and Tamiya foam-safe paints but I don't care for the way they spray (large droplets). My neighbor is a real artsy-crafty type and she suggested the Design Master paint from Michael's Arts & Crafts so I decided to give it a try. The paint goes on nicely and doesn't seem to attack the Depron as long as I apply light coats. It dries quickly and the colors are quite vivid. It doesn't smell like paint, though! It smells more like perfume or air freshener but after all, the target market is artsy-crafty people. To make a long story short, my Hell Raiser will be hard to miss. It will be the red, white, and blue one with the fresh floral scent flying in a cloud of bees. Pete |
Thanks !. You can use it to paint fabric and kitemakers use it on ripstop nylon too.
Company website www.dmcolor.com |
I wished it smelled like paint, though. Pete |
I have found typically droplets are often caused by several factors:
1- the tip of the needle is slightly bent and the media is clumping on the 'hook'. 2- there is too much media being put into the airstream, or, too little air 3- if using CO2 or pre-canned air, the gas is coming out too cold, from expansion, and causes the paint to clump. 4- impurities in the media or the air like dust, dirt or some of the coloring agent is not completely dissolved. 5- the media being sprayed is too thick. |
PGR, get yourself a 5 gallon air take. You can fill it at the gas station if you can't run your compressor. You need a filter trap and regulator with it. I use mine to paint my plastic models. No noise but depending on how much you are using it, it won't last that long before needing refilling.
ZZ |
| Thread Tools | |
| Building Lessons Learned from building my Allegro-Lite | thelocust | Thermal | 10 | Apr 13, 2005 09:41 PM |
| BT Stealth Crutch Tail Flex ??and Observations from building | rickyblaze | Electric Heli Talk | 23 | Mar 29, 2005 10:48 PM |
| Break From Building | sr71fan | Parkflyers | 10 | Oct 26, 2002 09:12 PM |
| Humor from r.m.r.a. newsgroup | Red Baron 47 | Life, The Universe, and Politics | 0 | Dec 10, 2001 08:13 AM |
