Old Oct 15, 2004, 08:00 PM
Gwalch is online now
Find More Posts by Gwalch
Gwalch's Avatar
Australia, VIC, Inverleigh
Joined Mar 2004
Motor Advice for Pattern Plane
G'Day all!!
Many many moons ago I was given this pattern plane.
However.. I have no idea what motor used to run in it.
It has a Wingspan of: 175cm
and a length of: 150cm
It is a fibreglass fuselage and foam core wings.. but I have not weighed it.
I managed to acquire (for the right price ) an Irvine .61 RC-RE rear exhaust motor, still in it's box and unused. Would this be suitable??
Looking at the pics.. the motor was side mounted and appears to have had a tuned pipe.
Any help greatly appreciated.
best regards
Nich
Gwalch is online now Find More Posts by Gwalch
Old Oct 15, 2004, 08:36 PM
N1EDM is offline
Find More Posts by N1EDM
N1EDM's Avatar
Brockton, MA
Joined Nov 2003
Hello Nich, I'll take a stab at answering this one..
The Irvine is a strong engine, and I am guessing that if it's a rear exhaust type, it might have a lot of power. But it is probably the type of engine that you'd only put in if you were starting out and not doing any complicated manuevers.
I think that perhaps a .90 (15cc) might be a better choice. I have recently been looking at Pattern ships and I'm thinking about a CA Epsilon. It weighs in at about 7.5 pounds (not sure how many kg that is) and the engine range on that one is from .60-90.
In reality, I'm only telling you this to 'stir the pot'. I'm sure that everyone else out there will have an opinion different from mine, and will be certain to tell you so.
Just remember - not everyone is an expert.
Some people may suggest engines that are even larger than that, but if you are just starting out, you may not want to go larger than a .90 for now..
That's just my $.02. But hopefully I've stirred the pot for you to get some more comments on this subject. I'll be following it myself.
That is a beautiful airplane. Let me know if you ever find out what make/model it is.
Regards,
Bob
N1EDM is offline Find More Posts by N1EDM
Old Oct 18, 2004, 09:02 PM
Gwalch's Avatar
Joined Mar 2004
G'Day Bob!!
Thanks for the input.
I might weigh the model and do a search on LHS web pages and see what sort of motors are being run in planes that size.
I was thinking the .61 might have been a bit underpowered.. but I might just chuck it in the model and see how it goes until I get something a bit bigger.
Thanks again!
Nich
Old Oct 19, 2004, 07:00 PM
50+AirYears is offline
Find More Posts by 50+AirYears
United States, SC, Irmo
Joined Jul 2004
Funny how things change. For a lot of years, a 7.5 lb plane with a 69 inch wingspan would have been flown all over the world competitively with a 60 or 61 even before tuned pipes came out. Now that's underpowered. Still, whatever works.
50+AirYears is offline Find More Posts by 50+AirYears
Old Oct 20, 2004, 06:34 PM
N1EDM is offline
N1EDM's Avatar
Brockton, MA
Joined Nov 2003
That's a good point, 50+. I was reading an old article on Ed Kazmirski's Taurus and that plane was about the same size, powered by a .45. Still, pattern styles have changed over the years which made folks want to have the extra power, I suppose. I'm speaking as a 'historian', not as a pattern pilot (of which I'm not). It's just something I've followed over the years.
For example, Nich, that Epsilon that I'm thinking about has a 63" span, a 65" fuse, and the target weight is 7.5 lbs. It's rated for .60-.90. I'm thinking about putting a .75 ST in it, just to learn pattern.
You can see it at http://www.camodel.com.ar/Ingles/models1.htm
Let me know what you think...
Bob
Motor Suggestion For Bi-Plane Scratch BobFlyer Foamies (Kits) 4 Nov 30, 2004 09:27 AM
Advice for new plane josedel_1 Electric Sailplanes 2 Jul 06, 2004 10:31 PM
wanted-brushless motor/esc for 2m plane kjw03 Aircraft - Sailplanes (FS/W) 0 Jun 01, 2003 08:17 PM
suggetions for pattern plane mikesayer Sport Planes 10 Apr 28, 2003 12:16 PM
Airfoil for pattern plane? DeaninMilwaukee Sport Planes 14 Sep 16, 2002 08:58 PM
