Old Feb 15, 2002, 05:56 PM
tpstorey is offline
Find More Posts by tpstorey
Saint Louis, MO
Joined Jan 2002
planes that can use the GWS DXA and Qualcomm 830s
I am SO happy with the cost, flight times and performance of the GWS DXA and Qualcomm batteries that I am looking for more birds that can use this power setup. Here is the list of planes so far that people have used the GWS DXA geared motor and Qualcomm 830 battery pack in. Any more?:
trainer ifo: http://www.flyifo.com/htmlpages/tifo.html
mini ifo: http://www.flyifo.com/htmlpages/miniifo.html
duskstick: http://www.users.qwest.net/~mkaren4/duskstik.htm
bud: http://12.45.56.6/~birdworks/bwbud.htm
tilde: http://www.harborside.com/~birdworks/bwtilde.html
flitter-b: GSutz@aol.com
pf-5: http://www.davesaircraftworks.com/
tiny: http://www.toddsmodels.com/slowflykits.htm
tpstorey is offline Find More Posts by tpstorey
Old Feb 15, 2002, 06:11 PM
RCFlybry is offline
Find More Posts by RCFlybry
Faster Faster!!
RCFlybry's Avatar
Kaysville Utah, U.S.A
Joined Oct 2001
The Tiger Moths work very well with them also.
http://www.horizonhobby.com/products...p?prod=GWS1020[/url]
RCFlybry is offline Find More Posts by RCFlybry
Old Feb 15, 2002, 06:48 PM
Roninfla is offline
Find More Posts by Roninfla
Stuart Fl
Joined Jan 2002
I've used these in my Pico FD Cub with great results. 20++ min with more to go. I'm not sure which will cut off first the batteries with circuit board or the BEC/ESC..Luv these Q830s
Roninfla is offline Find More Posts by Roninfla
Old Feb 15, 2002, 07:23 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
And_Now: http://www.geocities.com/genebond/
PFC, SoSlo2, WingThing: http://www.geocities.com/azchuckrc/AZ_Chuck_RC.html
Gene Bond is offline Find More Posts by Gene Bond
Old Feb 16, 2002, 06:44 AM
Harm Botman is offline
Find More Posts by Harm Botman
Harm Botman's Avatar
Hillegom, Netherlands
Joined Sep 2001
This one flies great with this combi also!
http://www.rcgroups.com/forums/showt...ht=glass+fiber[/URL]
Harm Botman is offline Find More Posts by Harm Botman
Old Feb 16, 2002, 06:24 PM
tpstorey is offline
Saint Louis, MO
Joined Jan 2002
Here's a Kolibri/Stubenfliege type: http://www.geocities.com/spiderflyairplane/
Old Feb 17, 2002, 11:51 AM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
GWS J3 Stick (or whatever the name is), GWS 10X4.? prop, GWS 2 amp speed control. Battery cuts off before speed control does, so beware, but it still will fly maybe 40 minutes or more (depending on how much throttle you use). Battery gets weak before it cuts off. In practice I use a stopwatch and stop flying at 25 or 30 minutes.
lincoln is offline Find More Posts by lincoln
Old Feb 17, 2002, 12:17 PM
Hippo is online now
Find More Posts by Hippo
The effect is sadly temporary
Hippo's Avatar
Ann Arbor, Michigan
Joined Oct 2001
It's designed around them.
The Frog is completely designed around the DX-A and the GWS pico gear. I've been flying it on the Qualcomm 830's since the beginning.
http://www.rcgroups.com/forums/showt...threadid=26345
I routinely get 30+ minute flights. I've never run out of battery in the air (By ESC, or protection circuit) I guess it's too cold outside, and flying in the golf dome you get 20 minute slowflyer time allotment, and 20 minutes for Parkflyers. I usually go that entire time with a short break on one battery pack.
I used to fly my GWS Cub FD on the same motor and batteries, and did have the BEC cut off before the pack did once. No problem.
-Dan
Hippo is online now Find More Posts by Hippo
Old Feb 23, 2002, 10:14 PM
Clu is offline
Clu
Find More Posts by Clu
Clu
Glavin!
Clu's Avatar
Southern NJ
Joined Aug 2001
Hey Genebond:
How does the And_Now fly on the GWS and 830 setup? Good setup for indoors? (Like a one basketball court sized venue?)
What prop should I use?
Thanks!
Clu is offline Find More Posts by Clu
Old Feb 24, 2002, 10:36 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
I've never flown indoors!
The qc 830's on the And_Now are a little soft. Need to go to a 10x8 prop for decent performance. I like an 8x300 w/ 9x7 better, but it works.
I have trouble staying focused longer than the 300's last anyway on these twitchy-psyco planes!
I could fly it in a single basketball court, but I garantee I would break something eventually! It likes speed. The Tiny would be better for this small area. It's a lot lighter.
Old Feb 24, 2002, 07:35 PM
Clu is offline
Clu
Clu
Glavin!
Clu's Avatar
Southern NJ
Joined Aug 2001
Thanks for the reply! I'll give the Tiny a try instead, I think.
Do I have to scale it up or down to suit the GWS-A setup? I wouldn't think so... but I thought I'd ask.
Any gotchas or tips for this set up?
Old Feb 24, 2002, 10:06 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
The standard Tiny works fine w/ DX-A. I added a little to the chord on my BluCor version, to try to make up for extra weight.
Old Feb 25, 2002, 06:44 AM
bsumpter is offline
Find More Posts by bsumpter
Crash Test Dummy
bsumpter's Avatar
Greeneville, TN USA
Joined Mar 2000
Add the Dumas Kestral to the list. Flys great on a DX-A / 10x4.7.
bsumpter is offline Find More Posts by bsumpter
Old Feb 27, 2002, 09:23 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Oh yea, you could add the Hissy-Fit, if that desert rat would get off his butt and update his web page, so guys could buy the plans!
Yea, you, AZ Chuck! The plans I got were better than what a lot of guys sell for twice the anticpated price, so get busy selling! Unless of course you are scared of the higher tax bracket....
3D planes that can use the Mega 16/15/3 scrappyfly8 3D Flying 4 Nov 16, 2004 08:58 AM
Can I use GWS Props in place of APC Slowfly props? mrebman Parkflyers 1 Mar 26, 2003 01:21 AM
Need Aerobatic-al park flyer that can use this equipment. A tiny?? Tram Parkflyers 9 Sep 29, 2002 03:04 PM
Any Planes that will use a Single EDF Unit + Qualcomms? mrebman Parkflyers 7 May 21, 2002 12:00 PM
List of planee that use GWS DXA tpstorey Parkflyers 11 Feb 13, 2002 06:56 PM
