Old Oct 14, 2004, 07:28 PM
Magna is offline
Find More Posts by Magna
Malaysia
Joined Jun 2001
How do program reverse aileron differential on Fut 9C?
Hi
I want to program reverse aileron differential when my spoileron is deployed? How do you do it?
Can you share out the specific steps?
Reverse differential: The down travel of aileron is more when I deployed the spoileron (both aileron up) and up travel is lesser. On normal flight mode, the down travel is less than Up =>this is the normal aileron differential.
Thanks!
Magna is offline Find More Posts by Magna
Old Oct 15, 2004, 06:25 AM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
Originally Posted by Magna
Hi
I'm almost sure you can't. (no longer have a Futaba) . But there is a workaround: switch your aileron servo's around ( 2 to 5 and 5 to 2 or something), and your "normal" differential will be reversed....
WimH is offline Find More Posts by WimH
Old Oct 17, 2004, 08:48 PM
Magna is offline
Malaysia
Joined Jun 2001
Hi Wimh
What I meant was using mixes. I want to know the steps.
BTW, what is your Simprop LO 1.9m CG? I have not maiden yet, but the plane is ready.
Old Oct 18, 2004, 02:50 AM
WimH is offline
WimH's Avatar
Joined Dec 2001
Hi Wimh
Oops, did not read the question well enough, you only want reverse diff. with spoiler deployed I see... Can't help you there I'm afraid.
As for the CG, my latest LO is @ 78 mm from the leading edge, but it needs to go back more. My older LiftOff flies better, but I have no idea where the CG is...
Old Oct 18, 2004, 07:58 PM
Magna is offline
Malaysia
Joined Jun 2001
78mm?? The plan indicated 65-71mm only for the LiftOff.
What you mean by latest LO or older LO? Are they different plane?
Discussion how do you reverse the shaft on a brushless motor? suitcase Power Systems 4 Jun 18, 2007 06:12 AM
Question How Much Aileron Differential on 2m Blade? screamin' eagle Slope 0 Apr 06, 2006 02:42 PM
How and what is best way of reverse aileron diff on Fut 9c? Magna Electric Sailplanes 4 Sep 28, 2004 11:09 AM
Alert How do I program Differential Ailerons on a Flash 5 PLANE FREAK Hitec/Multiplex USA 4 Aug 05, 2004 10:14 PM
How much aileron differential on F4 phantom? MtnGoat Modeling Science 1 Apr 18, 2003 12:38 PM
