| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
Just one more plane!
How do YOU measure thrust?
Hello all!
After giving much thought to measuring thrust on an electric setup and seeing many posts, scattered all over this forum as well as others. I wanted to get some input from the many forum members who have given their time and knowledge to help others and to also say thanks for all that help! I am not looking for anything dealing with software here. I am looking for those devices which are used in actual testing by using the motor/prop setup and some type of guage to measure the thrust. Myself, I have used the software programs to calculate intial setups before purchase and they have helped with a ballpark motor and prop setup for a particular plane. But generally, I find the motor/prop selection to be off in some way and another motor/prop selection was needed. So, if you have a homemade device or one you have bought, which you use to measure thrust in real world testing, I would like to see a few examples. I am not really sure how to go about making one which will give an acurate result. I have seen alot of debates on just how to make one, which is correct, I sure don't want see any of that here. So, please, NO fellow R/C'er bashing! Thanks in advance for your post. P.S. Pictures please! Some of the photos I have seen in the threads are outstanding by the way! John |
#2 |
Average User
http://www.rcgroups.com/forums/showt...=271490&page=1
See post #6. Made this setup in less than an hour with scrap wood and a cheap kitchen scale. |
#3 |
Kickin It Ol'Skool
My setup
Here is a pic of my thrust test bed. Tests are done in pusher mode. Works fine for brushless motors. If I need to do a tractor test I have a lever setup that I use with the same scale. I dont have a pic of it.
Len |
#4 |
Dance the skies...
Here's mine:
http://www.rcgroups.com/forums/showthread.php?t=252722 Works great. The scale measures in either grams or pounds/ounces (to the nearest 1/10th oz). It doubles as a prop balancing rig as well. |
#5 |
Heres mine
#6 | |
I have done that but seriously... I use a long board suitable for the power system. (A 1X4 or 2X4 for bigger motors) The power system is mounted all the way at one end of the board. Next I place the board on something that it can pivot on top of. Then power up while sliding the board to find the "neutral" point. Power down and take a weight reading at the shaft. Not perfect but it's quick and works. |
#7 |
Here's my system complete with crude working drawing if you want to copy it!
http://www.rcgroups.com/forums/showt...t=Thrust+stand Cheers, Phil |
#8 |
De-Brushed user
Get on the Zone and ask or search for anything posted by Dr Kiwi, of course!
I really do need to get a test stand, though, but the Dr is a great resource for anyone without the tools to do it themselves. Or I pull the plane vertical and hit the throttle, if it goes up for a long time my thrust measurement is 'Alot!' Jonathan Last edited by CAFplanekid; Oct 14, 2004 at 09:55 PM. |
#9 |
Dammit Jonathan, you can make a stand like mine in less than an hour for $5 in materials - get to it!
#10 |
De-Brushed user
I know, I really need to do it. I also need a whattmeter and I would be set. I guesss I should get it done this weekend and sell something for a whattmeter.
Jonathan |
#11 |
Live to ride... and fly!
Here's mine. Pretty fancy, huh?
The top one was the first one I rigged up, it was actually my balance stand which I would tape down to the scale and then tape a rod with a motor mount across it. Problem is I was always taking it apart and putting it back together depending on whether I was balancing planes or doing thrust tests. I finally built a permanent stand out of CF rods (bottom pic). I use an old feather receiver and just let everything hang off to the side as in the top pic. Then when I'm ready to test I turn on the scale. It automatically zeroes out all the weight, so when I power up the motor the scale reading is giving me thrust only. Very simple, but it works great.
#12 |
BTW, I tape the stand to the scale when I'm doing tests. The rods are set far enough apart to where I can run a 14" prop. The height is enough that I can change props without removing the motor from the stand. I've used it to test EDFs by taping the EDF to the mount. I've also checked IPS gearboxes, I have a smaller mount that screws to the big mount for those.
#13 |
Jonathan, if you like to fool with computers, get the Medusa Power Analyzer Plus, with the cable link for your laptop and you can graph amps/volts/watts etc. More displacement activity!
Cheers, Phil |
#14 |
Thanks to everyone who has posted so far! I did'nt think I would get this many responces. I have ordered a scale and have a design in mind. As soon as the scale arrives I will start building and share in this thread.
Thanks again John |
#15 |
Here's mine with an "adapter block" for EDF 40's and EDF 50's.
Cheers, Phil |
| Thread Tools | |
| How do you measure voltage under load? | Terkan | Electric Heli Talk | 3 | Jan 21, 2003 12:04 AM |
| How do you measure motor temperature? | Downwind | Power Systems | 9 | Jan 20, 2003 12:38 PM |
| How do you measure engine/prop thrust? | Slow Riser | Power Systems | 0 | Jul 30, 2002 08:19 PM |
| How do you measure thrust | epilot | Indoor and Micro Models | 2 | Dec 24, 2001 02:50 PM |
| How do you measure motor contstants? | Aero-BearAZ | Power Systems | 4 | Jul 19, 2001 12:33 PM |
