Old Oct 14, 2004, 09:21 AM
Ron D is offline
Find More Posts by Ron D
Harrisburg, PA - USA
Joined May 2001
How about afixin' the Yard Stik wing to the SS?
Anyone try this? The Yard Stik wing is only slightly smaller than the SS wing. I would like to try this for its added durability. I fly my SS from my backyard and weaving my way through the trees sometimes gets a bit hairy. It seems to me that the Yard Stik tail feathers could also be mounted satisfactorily. I fly mine with the 400 motor setup so power is not a problem. I also use 3s 1200 lipos and KAN 1050 7 cell packs - again no problem with power.
Ron D is offline Find More Posts by Ron D
Old Oct 14, 2004, 09:21 PM
PRINCE ALBERT is offline
Find More Posts by PRINCE ALBERT
Joined Sep 2004
I did and it works great. Flies a little faster and looks better with the new wing. I fly mine with a park 380 brushless, GWS 1080 prop and 7cell 1100 ma nimh.
PRINCE ALBERT is offline Find More Posts by PRINCE ALBERT
Old Oct 15, 2004, 08:52 AM
Ron D is offline
Joined May 2001
Hail Prince
Did you glue the wings together at the center or mount them using the Yard Stik brackets?
Old Oct 15, 2004, 09:35 PM
Joined Sep 2004
I bent copper tubing to fit the Slo Stick (same length and angle as the aluminum ones on the original wing) and epoxied the yard stick wing rods into them. Then use rubber bands to attach the wing.
Old Oct 15, 2004, 09:49 PM
Lorddrek is offline
Find More Posts by Lorddrek
I Need help. Dont sell!
Joined Aug 2004
The tail feathers fit perfect with no mods needed. The wings well....they didn't make it.
D
Lorddrek is offline Find More Posts by Lorddrek
Question Question? How about an Easy Star wing on a Slow Stick? Sparrowhawk Aerial Photography 4 Nov 07, 2005 04:53 PM
How about Twinstar wing on SS worzul Aerial Photography 0 May 01, 2005 03:11 PM
how about a Slow Stick ripstop wing. uglyplane Electric Plane Talk 0 Mar 26, 2003 09:21 PM
Is Elipsoid's wing that bad? How about XL3200?? Magna Electric Sailplanes 2 Jun 07, 2002 01:04 AM
How about a Rocket Wing brudford Foamies (Kits) 2 Jan 03, 2002 02:03 AM
