Old Oct 12, 2004, 03:15 PM
nanoflite is offline
Find More Posts by nanoflite
Belgium
Joined Jun 2004
What to do if you have more planes then receivers?
Hi,
I would like some advice ... I just finished a EFF foamie conversion to RC (the estes spicy wing, called eaglets from conrad).
I had the idea to use connectors (PCB headers) to make the Rx removable and reusable in another plane. Now ... it turns out that it is very involving removing the Rx and inserting it again into the plane. Also, the connectors introduce some extra weight ...
How do you cope with this? Do you buy a Rx per plane - which is too expensive for me - or do you solder the wires on or do you use connectors ...
I would go for soldering, but that would be hard to do when you go out to a gym to fly the planes ...
Johan
nanoflite is offline Find More Posts by nanoflite
Old Oct 12, 2004, 04:03 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
i usually just fly the plane untill i either get bored with it or crash it too bad to repair and then move to another plane. but i agree it would be nice to have more than one RX.
Derrik
derk is offline Find More Posts by derk
Old Oct 12, 2004, 04:25 PM
66tbird is offline
Find More Posts by 66tbird
To many projects
66tbird's Avatar
USA, AZ, Litchfield Park
Joined Aug 2004
I have chosen to pay the weight penalty and make the rx and actuators removable via connectors. Helps in trouble shooting also. For me, I'm in the 28-30 gr. range and the connectors add a gram or so, which is about 5% of the AUW. Small price to pay if moving stuff from one re-kitted plane to a ready to be flown plane
66tbird is offline Find More Posts by 66tbird
Old Oct 12, 2004, 05:46 PM
snakeX2 is offline
Find More Posts by snakeX2
Flap chap
snakeX2's Avatar
Most Southern England, Brighton UK
Joined May 2004
Can't you just twist/bend the wires to connect it up. Doesn't add any weight, may not look nice or be absolutely reliable, but it works!!
snakeX2 is offline Find More Posts by snakeX2
Old Oct 13, 2004, 05:54 AM
Belgium
Joined Jun 2004
snakex2:
Just twist the wires together? Man, that seems unreliable .
I think I'll be out shopping for some very small connectors and some very thin wire to connect all things together.
Another problem I'm having with taking removing/installing an Rx is that it is difficult to make the Rx pluggable. For example on my eaglet conversion, I have to cut the fuselage open - held togther with some clear tape - and that totally destroys the trim I have on the ailerons ....
Probably i need a more clever method of attaching the rx to that one ...
Johan
Old Oct 13, 2004, 06:18 AM
Pjotrrr is offline
Find More Posts by Pjotrrr
Me likes Depron...
Pjotrrr's Avatar
Amsterdam Schiphol, Netherlands
Joined Mar 2003
www.aircraft-world.com sells a set of antenne connectors, that was you can disconnect the antenna near the RX and take it out to another model, if you mark the servo/ESC connectors it's not that much work...
Of course every model needs it's own antenna, just be sure the wire has the same length
It's advisable to secure the connectors from the antenna with same tape too
Peter
Pjotrrr is offline Find More Posts by Pjotrrr
Rave Blucor foam Do's & Don't - Chime in if you have more! Punkbrad Foamies (Kits) 6 Jan 03, 2015 04:49 PM
What happens if you have a lipo in your back pocket! 1987tc Humor 8 Nov 13, 2005 10:54 PM
Yippee! I have more Planes then RX Morb Castle Creations 10 Aug 21, 2005 03:41 PM
What do you do if you have no materials? davidcollins001 Scratchbuilt Indoor and Micro Models 7 Feb 16, 2005 01:54 PM
What do you do if you have EPS's, but dont want to buy a new plane with new EPS's? BytheBookie3 GWS (Grand Wing Servo) 7 Jun 01, 2004 12:13 AM
