Old Oct 12, 2004, 12:06 PM
gerns is offline
Find More Posts by gerns
RCAirWorks
Power system for 40-size Super Cub
I need some help. I want to convert my super cub to electric power but I am not sure of the motor/battery combo. The model weighs around 7-8 pounds but it is a cub with a lot of wing area and low loading. I want to power it with a brushless motor and a Li-po but which setup I don't know. That is where I hope someone who has done something similiar to this can help. I would like to get around 15 minutes of flight time. Any suggestions?
gerns is offline Find More Posts by gerns
Old Oct 12, 2004, 12:44 PM
IsToR is offline
Find More Posts by IsToR
IsToR's Avatar
Stockholm, Sweden
Joined Aug 2004
Motor:
AXI 2820/12 should match a .040 size engine. Draws about 30-40 amps WOT.
Battery:
If you go with LiPo you'll have to get at least a 3s2p or maybe even a 4s2p. The E-tec 1700 SHP cell can deliver 17-20 amps continously and 25-30 amps in short bursts. A 4s2p E-tec 1700 SHP pack can sustain currents of 34-40 amps, so it should be very suitable for the axi. That should give flight times of 5-10 minutes if you fly full throttle all the time (which I assume you don't).
However you could get a 14 cell 3300 mAh NIMH pack and get the same flight time, but with increased weight
IsToR is offline Find More Posts by IsToR
Old Oct 12, 2004, 12:45 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
gerns
About the second most converted glow model around.
Pop down to the scale forum, do a search on Cub
That's a Sig 1/5th J3 in my avatar - slightly larger and much more scale than the endless round of 81" IMAA legal ready-to-fix jobs, 8lb 2oz, MaxCim 13Y / 3:1 gearing / 15 x 8 on 16 GP3300 nimh cells. Virtually no mods to the kit, flies like a Cub for 15 mins on the above.
Am waiting for "Saphion" technology cells to move on up before converting - these promise much of the advantages of lipo without the tedious tendency to burst into flames if upset. For the meantime, will leave models like this with nimh!
regards
Dereck
Dereck is offline Find More Posts by Dereck
Discussion Power System for 60 Size Warbird UnPossible Power Systems 2 Jun 10, 2007 01:37 PM
Question Good-quality .40-size Super Cub kit?? Moerdogg Scale Fuel Planes 16 Nov 27, 2006 08:14 PM
Need help selecting power system for 40 size conversion... WreckRman2 Power Systems 53 Dec 02, 2004 10:42 PM
Power systems for new 40" Super Cub Adrian Page Power Systems 2 Jul 02, 2004 04:18 PM
Is this enough power/rpm for a 40 size TM? Magna Sport Planes 5 Jun 07, 2004 04:09 PM
