Old May 05, 2001, 10:23 AM
NipponDave is offline
Find More Posts by NipponDave
http://www.aircraft-world
NipponDave's Avatar
American in Japan
Joined Mar 2001
Attack in my Garage - Futaba Rx/ESC Question
I recently discovered my "Attack 4 AM" (FP-T4NBL) in storage after it had been missing for eight years.
It originally came as a set with two micro servos and an integrated Rx/ESC with BEC (# MCR-4A). I've lost the manual. I'm most interested in the specifications of the speed controller and its BEC unit. Anybody know...
1) What is the max continuous amperage rating? Peak?
2) How many battery cells can I use? 6 to 7? 6 to 8?
3) Does it have auto motor cut-off at low battery voltage?
4) How do I set the throttle end-point? Is it the screw that's visible from the top? If so, technique?
Thanks in advance for any help you can give.
NipponDave is offline Find More Posts by NipponDave
Old May 05, 2001, 10:47 AM
Looooeeee! is offline
Find More Posts by Looooeeee!
Heli Bouncer
Looooeeee!'s Avatar
At the Discount Clambake
Joined Feb 2001
Hi Dave
I seem to remember that it was a low frequencey (Frame rate) speed control that did have BEC and was rated for 05 ferrite can motors of the time. as far as auto cutoff...?
Looooeeee! is offline Find More Posts by Looooeeee!
Old May 05, 2001, 03:17 PM
Daveairway is offline
Find More Posts by Daveairway
Santa Rosa, Northern CA, USA
Joined Oct 1999
It has been a long time since I had one, but I think 7 cells was the max suggested. The Esc part will not handle to many amps, maybe 20?, it is a "frame rate" so use it a at full throttle, not partial for best results, does have a cutoff(I think), but no brake.
The screw at the top is the throttle adjust.
Should be fine for Speed 400 use, but the new stuff is much better.
Dave
Daveairway is offline Find More Posts by Daveairway
Old May 05, 2001, 03:32 PM
rscamp is offline
Find More Posts by rscamp
rscamp's Avatar
Dundas, ON Canada
Joined Feb 2001
I still have an operational MCR-4A in a Teddy.
It is definitely frame rate (fairly soft though) and stops completely (won't restart) when the voltage from the motor pack voltage gets low. It has an arming switch and the adjustment screw sets the idle point.
Not a sophisticated unit by today's standards, but fine for lower current direct drive applications like a Teddy.
Here are the specs exactly as written in the Instruction Manual for the FP-4NBL TX:
AMP
Operating System:Idle to maximum speed, no brake, idle point trimmer
Voltage: 6.0 to 8.4V
Continuous Maximum Current: 100A (!)
Momentary Maximum Current: 450A (!!)
Resistance Loss: 0.01 Ohm
How did they arrive at those current ratings??? 8) I would divide them by 4 or so...
Rob
rscamp is offline Find More Posts by rscamp
Old May 05, 2001, 08:17 PM
Hal Ray is offline
Find More Posts by Hal Ray
Older but not wiser
Richland, MI, USA
Joined Jan 2001
I use mine with a geared 600 size motor, it needs some air cooling so it won't cut out. 7 cells is max for it.
I also use the TX on a bigger plane with a geared Astro 25G and 16 cells. A new am RX costs about $70.
HRH
Hal Ray is offline Find More Posts by Hal Ray
Old May 06, 2001, 12:02 AM
NipponDave's Avatar
American in Japan
Joined Mar 2001
Thanks to all for the info...
I know it isn't Hi-Tech, doesn't do anything but reverse the servos, but I sure was happy to find it the other day. Paid $220+ for it 10 years ago and I think I had about 20 flights on it - flew in my first EP, the PT-Electric, which still hangs pristine in the rafters back in the States.
Now! What am I gonna build for it?? Heee.
Old May 06, 2001, 12:50 AM
BobK is offline
Find More Posts by BobK
Rhode Island
Joined Oct 2000
AMP
Rob
Hmm, 100A and 0.01 ohm internal resistance? That works out to 100 watts! Sure sounds funny to me.
BobK is offline Find More Posts by BobK
Old May 06, 2001, 11:24 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Those are metric watts. Divide by 25.4..
At 100 amps, the wiring needed for the load would weigh more than a Buick!
The MCR-4A is a handy receiver.. I have two, and use them occassionally.. one has a slightly melted case from abuse..
A bit larger and heavier than is fashionable now.. after a mere 10 years.!
Sparky Paul http://www.angelfire.com/indie/aerostuff
PJB's Seriously Aeronautical Stuff http://www.networkone.net/~pjburke/index.html
Sparky Paul is offline Find More Posts by Sparky Paul
Old May 06, 2001, 11:39 AM
rscamp is offline
rscamp's Avatar
Dundas, ON Canada
Joined Feb 2001
Sure does. The controller has some sort of automatic shutoff if the current is too high. Maybe they were sneaky and took this into account. I have some tiny little speakers like this. Rated at 100W continuous (and they mean it), but they have a built in protection circuit...
Rob
Old May 06, 2001, 11:52 AM
rscamp is offline
rscamp's Avatar
Dundas, ON Canada
Joined Feb 2001
Hey Sparky.
You can't fool me. We buy gas in litres and post speed limits in KPH up here.
I'm pretty sure metric watts are only used by clever scientists in long white lab coats and thick glasses doing research on perpetual motion...
Rob
Discussion A question about jumpers in stock F27 B rx/esc randall1959 Flying Wings 2 Nov 13, 2006 10:09 AM
I found a Tl-01 in my garage. silttony On-road Cars 4 Aug 24, 2005 12:28 AM
Help! Iam Not Sure If This Is A Problem In My New Jmp Rx Prashanth Scratchbuilt Indoor and Micro Models 9 Apr 06, 2004 07:44 PM
Attack in my Garage - Futaba Rx/ESC Question NipponDave Electric Sailplanes 8 Oct 19, 2002 10:07 PM
Futaba RX Range Question: ExecPilot Beginner Training Area (Aircraft-Electric) 0 Jul 25, 2002 10:25 PM
