Feb 14, 2002, 10:22 PM
Loveland, Colorado
Joined Mar 2000
Thanks. I only had a bunch of 13T pinions, but I thought since the ELMH has a much shorter rotor than the Corona it would be fine. I did a motor run test today with a cheap 1500mah 7-cell pack. I held it and advanced to full throttle, it felt quite a bit more stronget than the .061 engine. Motor run lasted around 6 minuted before power began to fade and motor cut off around 7 min. I hope to get better batteries and a heli speed control if the test flight goes half way decent tomarrow. Right now I'm using an airplane esc but it deosn't have BEC so I have to lug around a 350mah battery for the radio gear.
The black material is some pipe insulation cut down and wrapped with electrical tape. No more bent booms from boom strikes
-- Acer
