Old Nov 11, 2004, 08:18 PM
slowflyer90 is offline
Find More Posts by slowflyer90
Joined Sep 2004
Here's another circuit layout. Take a look and let me know what you think.
slowflyer90 is offline Find More Posts by slowflyer90
Old Nov 12, 2004, 01:38 AM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
There are several problems with using mosfets like you show. The first thing is that driving directly from the logic that way, your motor voltage could be no higher than your logic voltage, or the top mosfets would never turn off. Also, mosfets have very high input capacitance, so at a bare minimum, you would need a series resistor to limit the current from the logic to prevent damage to the logic and you would have slow switching times on the mosfets which would cause them to heat up more. Also, you generally would use nmos for the bottom mosfets. The way you have it shown with pmos on the bottom in the common drain configuration, the bottom mosfets would never fully turn on. To turn them on fully you would need to drive the gates below ground.
jeffs555 is offline Find More Posts by jeffs555
Old Nov 12, 2004, 07:22 PM
Joined Sep 2004
To tell the truth, I'm kind of walking in the dark on how you're supposed to wire the fets. Can you help me with this? Any examples would be greatly appreciated.
Old Nov 14, 2004, 08:40 PM
Joined Sep 2004
Here's a correct picture of a p-fet. Thanks for pointing out that the fets in my picture were connected wrong.
A few questions:
Does the gate voltage have to be at least as high as the source voltage? For example, if the source voltage is 9v and the gate is 5v, then will the output be ~9v or ~5v?
Old Nov 14, 2004, 09:58 PM
jeffs555 is offline
Raleigh,NC
Joined Nov 2000
For a P-channel mosfet, the source has to be positive and the drain negative. To turn on, the gate has to be negative relative to the source. In the specs for the mosfet, there will be a threshold voltage. When the gate is more than the threshold voltage below the source, the mosfet will turn on, if it is closer to the source than the threshold voltage, the mosfet will turn off. For the low voltage mosfets generally used, the threshold voltage will probably be less than 4 volts. Therefore if the source is at 9 volts, and the gate is at 5 volts, the mosfet will be turned on, and the drain will try to pull up to 9 volts, so with 5 volt logic the high side mosfet will never turn off.
With the P-channel on the bottom, the drain will be tied hard to ground and the source will be free to move. This is the common drain configuration which is equivalent to the emitter follower with bipolar transistors. With this configuration, the source will try to stay above the gate by the level of the threshold voltage. If you pull the gate to ground, the source will not go lower than the threshold voltage.
Normally you would use an N-channel on the bottom. On the top, you would use either a P-channel, or because N-channels are usually cheaper and better, another N-channel on the top in the common drain configuration with a charge pump driver so the gate voltage would go above the motor voltage.
Either way, you need a high voltage driver for the top.
Old Nov 15, 2004, 04:24 PM
Joined Sep 2004
Thanks for the explaination jeff, it makes more sense now.
Old Nov 15, 2004, 10:59 PM
zagisrule! is offline
Find More Posts by zagisrule!
Senior Member
zagisrule!'s Avatar
Edgewood, NM
Joined Jan 2002
Use logic-level MOSFET's and now you are all set to use logic-level control inputs to your N and P channel MOSFET's.
-Matt
zagisrule! is offline Find More Posts by zagisrule!
Old Nov 16, 2004, 09:09 AM
jeffs555 is offline
Raleigh,NC
Joined Nov 2000
One thing you need to watch for with the circuit Matt posted, is the the maximum Vgs spec for your P-channel mosfets. Vgs is the voltage differential between the gate and the source, and the mosfet will be damaged if you exceed the max Vgs. On many logic level mosfets, max Vgs is only 12 volts, and on some it is as low as 8 volts. Since the npn transistor pulls the gate to ground, the full motor voltage is applied across the gate and source of the P-channel mosfet, so supply voltages higher than max Vgs will damage the P-channel mosfets.
It is even worse than that, because the current stored in the windings of the motor will cause a voltage spike when the mosfet is opened as the motor is being commutated. This is recirculated thru the power supply by reverse protection diodes built into the mosfets. That is why you need a very good capacitor with a low ESR(equivalent series resistance) across the power supply right at the mosfets. Section 2.3 of this app note describes why the capacitor is needed, and how to choose it. http://www.st.com/stonline/books/pdf/docs/9214.pdf
Jeff
Old Nov 17, 2004, 05:17 PM
Joined Sep 2004
Zagisrule: thanks for diagram, I appreciate it.
Jeff: I didn't know about the voltage spikes, and I'll include capacitors in my next diagram. I should be able to easily get fets that can handle 10 amps, which should be plenty for the small motor on my plane.
I'll post a revised diagram sometime in the next day or two. Working on a spanish project for school tonight. Adiós!
Old Nov 17, 2004, 09:12 PM
Joined Sep 2004
Well, spanish didn't take as long as I thought it would.
Heres another diagram. If I messed up, let me know. The fets should be wired correctly in this one.
Old Nov 17, 2004, 11:18 PM
Senior Member
zagisrule!'s Avatar
Edgewood, NM
Joined Jan 2002
I have no clue as to whether or not this logic-driven circuit would function at all? I am not at all familiar with digital logic devices, my digital experience has been with PIC's and with those I make them do exactly what I want.
I guess it would not be hard to try this out, it is quite simple and it would be neat if it worked!
-Matt
Old Nov 17, 2004, 11:26 PM
Senior Member
zagisrule!'s Avatar
Edgewood, NM
Joined Jan 2002
While I am thinking about it...
1. Why bother with switching the rail anyway? Just wire the center tap of the motor to Vcc (the wye connection to the + rail) and switch only the ground to each of the motor leads to accomplish commutation. This means you can get rid of all the P-channels and their inverting transistor drivers.
2. Can you explain the thought behind your digital logic switching? I am thinking that it is not going to work. I have started writing sensorless control code (a failure as of yet...can't get rotor lock) for 3-phase motors and frankly I just do not see the logic solution working unless I am missing something on what exactly it is doing. From the looks of it you are just selectively energizing the coils based on the hall inputs.
-Matt
Old Nov 18, 2004, 04:51 PM
Joined Sep 2004
This'll be a long post.
To start off with, I left capacitors off in the diagram because my circuit design program is a demo and it doesn't want to put more than 50 components in one picture.
Matt, your question is a good one, I thought of the same thing when I first started this.
Short answer: Your way energizes 1 coil at a time. The standard way energizes 2 at a time, giving greater power.
Long answer: Brushless Motors are wired so that one coil will attract and one will repel when a phase is energized. If you connect the wye connection to ground, then all coils can only be energized in the same direction (+ to -). If you energized 2 coils in the way you specified, then they would be fighting against each other. This makes it so that only one coil can be energized at a time. If the coils are wired in the standard way, then 2 coils will be energized that will help each other; thus making it more powerful. This may not be too clear, so I hope the diagrams help. The first is with the wye connection connected to ground and one phase energized. The second is an example of a standard motor with one phase energized.
As for your second question, that is exactly what this circuit does. Coils are energized based on the position of the rotor (which is detected by the hall sensors). If the controller were to be connected directly to the battery, it would spin the motor as fast as it could. A normal speed controller needs to be connected to this controller's power wires to regulate the voltage. Therefore, the controller will still spin the motor as fast as it can, but this speed is based on the voltage applied to the coils. If the imput voltage is dropped, then the speed is cut also.
Old Nov 18, 2004, 06:39 PM
Senior Member
zagisrule!'s Avatar
Edgewood, NM
Joined Jan 2002
Yes, I am aware of the techniques of commuatating and switching a normal BLDC motor as well as the principles behind how it works.
I simply suggested to tie the center high to simplify your design, as it eliminates half the physical circuitry as well as some of the complexity. I only suggested this because you are obviously only going to be using one-off homemade motors with this. This would cut your number of commutations in half, so you only need 3 commuations per revolution, while a conventional connection scheme requires 6 commuations per electrical revolution.
Also, by energizing two coils you are not actually gaining any power. The two energized coils act as series resistors essentially creating a voltage divider that halves the voltage to each coil. Delta wound motors actually produce more power per wind than wye motors for the simple reason that the driven coil is receiving the full rail voltage rather than half of it. The primary reason people wye wind is for less current draw than a delta wind because driven resistance is higher.
Also, you might consider running your logic and hall sensors straight from the BEC of the ESC, I doubt they would continue function as PWM duty cycle drops and average voltage falls.
Perhaps a good solution would be a commercially available sensored brushless controller IC, there are a ton of options if you choose to go this route that might actually be simpler than your circuit and in my opinion more likely to work. If price is a concern I am sure free samples are available for almost all the options.
-Matt
Old Nov 19, 2004, 05:48 PM
Joined Sep 2004
Your way makes sense, as it would require less circuitry.Running the logic from the battery would be a good idea, because the voltage will certainly drop below 5v around 50% throttle. As for IC's, they would be nice, but I haven't heard of any companies giving out free samples. I'll look around and see if any companies have any that would be suitable.
FAQ five(5) diy brushless ESC designs Ron van Sommeren DIY Electronics 108 Jun 14, 2015 04:29 AM
Best DIY Brushless ESC Kit? gfcermak DIY Electronics 10 Aug 25, 2004 01:23 AM
group order for diy Speedy-BL brushless ESC family Ron van Sommeren Electric Plane Talk 5 Jul 27, 2003 10:56 AM
group order for diy Speedy-BL brushless ESC family Ron van Sommeren Power Systems 0 Jul 24, 2002 08:15 AM
