Old Oct 10, 2004, 07:29 PM
mikeb33 is offline
Find More Posts by mikeb33
Tell that to George Zipp!
mikeb33's Avatar
United States, IL, Inverness
Joined Oct 2000
Anybody got a stronger mount for a Formosa wing?
My last one tore the mount out on a gentle crash. I considered gluing it together, but I want to be able to access my gear under there. I plan on hand launch and belly landling, so I would like a idea for a stronger mount.
mikeb33 is offline Find More Posts by mikeb33
Old Oct 10, 2004, 09:51 PM
FoamCrusher is offline
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
You could go with bamboo skewers and rubber bands like many other planes (e.g. Tiger Moth).
Unless your plane is way overpowered, it should work. I am in the middle of a Formosa build and am considering doing this. If you try it, and it works for you, post the results.
FC
FoamCrusher is offline Find More Posts by FoamCrusher
Old Oct 27, 2004, 03:02 PM
waltj2k is offline
Find More Posts by waltj2k
3DHobbyShop disciple
waltj2k's Avatar
Dallas Intl, Texas, United States
Joined Aug 2004
FC
I broke my mount long ago. Basically screwed it up upon the build.
I cut out the foam where the bolt enters the fuse. I replaced that with a 2 inch piece of basswood. I epoxied the basswood to the back wall of the fuse where I removed the foam. I then drilled a hole the for the bolt. Voila the best mount for the formosa.
Check out the GWS section of the forum. Search for Wing Mount. You should see some othere options. Good luck.
Walt
waltj2k is offline Find More Posts by waltj2k
Old Oct 27, 2004, 07:59 PM
mikeb33 is offline
mikeb33's Avatar
Joined Oct 2000
I ended up using 3 rare earth magnets to hold the wing on. I have a AXI 2212/26 and 3S lipos and haven't had a problem in about 10 flights. Well I did crash a few times, once breaking the elevator off. many time the wing was just laying a few feet away and undamaged.
I reccomend it.
Old Oct 28, 2004, 12:55 PM
waltj2k is offline
waltj2k's Avatar
Joined Aug 2004
Brilliant solution. I may have to try this.
Old Oct 28, 2004, 04:04 PM
milky2971 is offline
Find More Posts by milky2971
FLY PEMBREY (PFC)
milky2971's Avatar
Wales (UK)
Joined Aug 2004
ha!
A lovely Pink Floyd Formosa
Trev
milky2971 is offline Find More Posts by milky2971
Old Oct 28, 2004, 07:22 PM
mikeb33 is offline
mikeb33's Avatar
Joined Oct 2000
Thanks, I'm looking for a pig to put on the wing
Anybody got a exite 400 with inbuilt wing servos treehog High Performance 9 Oct 10, 2005 12:50 AM
Outrunner mount for Zagi wing livinma1 Flying Wings 6 Sep 29, 2005 08:37 AM
Anybody got an 010 on a formosa? Lammergier Parkflyers 8 Jan 20, 2004 03:44 PM
PJS motor mount for Formosa A Monell Power Systems 28 Jan 03, 2004 02:36 PM
Hacker motor mount for foamy wing RD Blakeslee Foamies (Kits) 8 Oct 04, 2002 06:59 PM
