Espritmodel.com Heli Air
Old Oct 09, 2004, 08:40 AM
Lancaster
Joined Dec 2003
Help with Brushless Glider set up Please.
Hi,
I'm about to buy a J Perkins Seagull 2200 2.2m powered glider. I've had one before, running on an Irvine Cobalt 05 turn, Jeti Eco (30/35amp) ESC, and using Sanyo 7-cell, 8.4v, 1600 mAh packs for power, all-up weight was 1430g. It was nowhere near a vertical climb out - more like 10-20 degrees, but it flew beatifully. Once I got 'very' high i could glide down to about 80ft, and then take her back up a second time - but that would be it on the power, bar for the odd burst the ESC would allow for approach to land.
So, this time round, i'd like to invest in better gear to (hopefully) transform the glider. Not realy looking to actualy do vertical climb-outs - this is not an aileron aerobatic model, but i would like to get more oomph generally, and increase flight times.
Here's what i'm thinking..... let me know what you think....
Motor: AXI 2820/12 (Was looking at the 2820/10, but read that the '/12' was better...) Only concern is that the Seagull 2200 is rated for a 6-7cell pack, albeit probably the standard cell size rather than the Sanyo 'Sub-C'. And i think the '/12' needs 10-14cells.?
ESC: As required - probably Jeti 40.?
Power: Was looking to use 7 or 8 cell 2400Nicads or 3300NiMhs, but have heard whispers that Lithium Polymer batteries are 1/3 the weight, with the same power - but would this route knacker penetration, due to low weight, when gliding with power-off..??
Prop: Not a clue - would guess 10x7 / 12x8..??
Ok, those are my thoughts. The Seagull 2200 costs app £70 so is good value - and beautiful to fly. Do you see what I'm looking for..?
Basically a powered glider that i can take high, shut-off and glide down, then take high again. NOT looking for low level aero's, although ailerons would be nice, just a nice strong (don't want to exceed wing loading...) enjoyable glider - with power/duration to spare.
Please share your views and experience, idealy if you could provide a 'set-up' suggestion for all components (Glider/Motor/Power/ESC/Prop). I'm not a competition flier, so just something that would keep your average flier entertained - even if you have a better option than the Seagull 2200 Glider, which may come to mind.
Hope I'm not asking too much...
Many Thanks in advance.
Chris W.
seagull2200 is offline Find More Posts by seagull2200
Old Oct 10, 2004, 04:34 PM
Hong Kong
Joined Apr 2003
Anything similar to Mega 16/15-size/4~5 Direct drive + 10x6 folder does what you need,or a hotter motor lower winds, with a gear box which can spin a larger prop is better for eff. of prop. thus lower the amp draw. which in turn help to reduce the batt. size, thus weight.
Outrunner like 2810 is overkill and will tear apart the wing if properly prop., also mounting of outrunner needs some works to secure the wires.
I know this for this is the one which makes me come back to r/c scene, and mine had its wings folder in a gusty day , I was not making any vigourous manueovers but perhaps the extra weight claimed it. Though may not be the fault of maker, cos' I used 8 gp3300 with its power set up. So remember not to overpower it then you may enjoy it. Hope this help.
David
C-MIC is offline Find More Posts by C-MIC
Old Oct 10, 2004, 05:21 PM
Joined Sep 2002
Gliders tend to use a motor/gear box combo in order to spin a large diameter prop efficiently. However, outrunners are being used more, from what I read.
As an example - I fly a 2M Aspire running a Hacker B20 L18 with the Maxon 4.1:1 GB, 12 x 6 folder prop, and a 3S TP 2100 Gen 2 (10-12C) LiPo pack.
The AUW is 38 oz which is acheived by using the above and Hitec HS 85 servos, 555 receiver, and CC Phoenix 25 ESC. The glider flys well and I get 7-8 climb outs (50-60 degree) per charge. On a decent thermal day I get all the flying I want on one pack.
The Aspire has about a 650 sq. in. wing area and at 38 oz. has about an 8 oz./sq. ft. wing loading. I use it primarily for sport thermal soaring. It is a R,E sailplane. If you plan on doing more slope soaring, then a heavier wing loading might be an advantage.
Sierra Gold
sierra-gold is offline Find More Posts by sierra-gold
Old Oct 10, 2004, 07:24 PM
mattg's Avatar
Sydney, Australia
Joined Feb 2003
Hi Chris,
I'm sure if you e-mail John Emms at Puffin or Gordon Tarling they could both suggest a setup for you that would be close to ideal.
The only thing I'd say is to choose your cells first and keep them as light as possible. FAUP1950s or GP2200s will save you some weight and still provide plenty of power and duration for what you want.
Good luck, Matt.
mattg is offline Find More Posts by mattg
Old Oct 11, 2004, 11:59 AM
LSF186
neonbutterfly's Avatar
Wayne, NJ
Joined Jan 2003
i have a filip 600 2 meter t tail r&e. here is my setup
axi 2820-10
graupner 12x6 folding prop
tmm 40 amp speed control
1700 mah aup nimh 8 cells pack
i am going to li-poly and will run the following setup
axi 2820-10
phoenix 45 amp speed control - castle creations
poly quest 3 cell 1800 mah li-poly pack.
with the phoneix 45 u can program the volts where the sped control will shut off the motor when it reaches 9.3 volts. below that u blow the pack. i bought the poly quest pack and put it in the sailplane with the tmm spedd control and ran it.
i did not read the directions, like i should have and the pack went below 9 volts. go bye pack. the climb in impressive. the filip 600 has 5 degrees of downthrust in the motor and i programmed 5% down elev when at full throttle in my futaba 9c tx (master/slave arrangement).
when i launch at full throttle the plane does a very gentle climb not a zoom launch. i just pull back on the stick and up she goes. very impressive climb. hope this helps.
bob
neonbutterfly is offline Find More Posts by neonbutterfly
Old Oct 12, 2004, 02:09 AM
Crash master...
Lazy's Avatar
Joined Apr 2003
Chris...
I have similar setup like you.
AXI 2820/12, Model Motor TMM 4012-3. Most my gliders flew with 12x6 props and Sanyo 10x1950 FAUP battery pack. Enough power for 5-6 climbs.
My opinion - not use any other ESC for AXI motors instead original Model Motor. Advanced series had a full programming features ( LiPo support, timing and other ...).
I bought all on www.e-flightRC.com, prices really good, specially for "COMBO" packages.
Regards
Lazy is offline Find More Posts by Lazy
Help! Having a problem with BEC/ESC set-up please help! conceptmachining Electric Plane Talk 11 May 24, 2008 05:06 PM
help with buddy box set-up chris-miranda Radios 1 May 13, 2004 02:48 AM
help with front brake set-up JANSSENM Motorcycles 16 Apr 16, 2004 10:45 AM
Please help with brushless Hummingbird set up guillaume83 Micro Helis 25 Nov 17, 2003 08:21 AM
Help with new power set up please! Guinea_Pig Power Systems 2 Apr 06, 2003 05:55 AM
