Old Oct 09, 2004, 03:58 AM
chris-miranda is offline
Find More Posts by chris-miranda
registered republican
chris-miranda's Avatar
In a van, down by the river
Joined Oct 2002
rudder & elevator only nitro planes
hi ive been flying electrics for awile now and ive mastered rudder , elevator and throttle but still a novice when it comes to ailerons so im looking for suggestions to a nice nitro powered plane that has no ailerons any help will be appreciated
thanks chris
chris-miranda is offline Find More Posts by chris-miranda
Old Oct 09, 2004, 05:57 AM
mpj220 is offline
Find More Posts by mpj220
Joined Apr 2001
If you want to build one, the Sig Kadet Seniorita is, imho, the best flying trainer kit ever produced.
It can be built with or without ailerons. I believe kit drawings contain both.
mpj220 is offline Find More Posts by mpj220
Old Oct 09, 2004, 08:11 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Ditto Seniorita, or it's bigger brother the Kadet.
GregG is offline Find More Posts by GregG
Old Oct 09, 2004, 09:12 AM
New Park Pilot is offline
Find More Posts by New Park Pilot
Norhteast Arkansas
Joined Jul 2004
I agree that these are some of the best trainers out there. If you do go with one of these, why not build it with the ailerons and you can grow into it. Sooner or later, you are going to have to learn to use ailerons anyway. Good luck!
New Park Pilot is offline Find More Posts by New Park Pilot
Old Oct 09, 2004, 09:52 AM
Bako is offline
Find More Posts by Bako
BAKO
Bako's Avatar
Tbilisi, Georgia
Joined Jul 2004
I learned to fly on grauoner AMATEUR II. it hase 15ci engine. perfect plane.
Bako is offline Find More Posts by Bako
Old Oct 09, 2004, 12:14 PM
Flying kevin is offline
Find More Posts by Flying kevin
LowbudgetFlyer
Flying kevin's Avatar
Morristown, TN
Joined Mar 2004
Why dont you want to fly with alieron?? like how you goin to turn?
kevin
Flying kevin is offline Find More Posts by Flying kevin
Old Oct 09, 2004, 01:53 PM
rayfisher is offline
Find More Posts by rayfisher
Northampton Sywell, Great Britain (UK)
Joined Jan 2004
kevin
You really must learn some BASIC aerodynamics - What do you think the rudder is for decoration?
rayfisher is offline Find More Posts by rayfisher
Old Oct 09, 2004, 02:41 PM
glen is offline
Find More Posts by glen
glen's Avatar
new zealand
Joined Sep 2003
Get a plane with ailerons; personally I think sometimes you should only learn that way. In the slightest bit of wind ailerons win every time.
MUCH easier. Don't be put of by all this stuff around about three channel planes. They only work under ideal conditions. (Thatís a little exaggeration but not too much)
Cheers
Glen
glen is offline Find More Posts by glen
Old Oct 09, 2004, 03:26 PM
LowbudgetFlyer
Morristown, TN
Joined Mar 2004
hahaah you got joke. i just relize it now i wasn't thinking about it. i was thinking about the rudder moving the plane on the ground.
kevin
Old Oct 09, 2004, 07:05 PM
flyboy2610 is offline
Find More Posts by flyboy2610
Mumbling in the corner.
flyboy2610's Avatar
Lincoln Municipal, Nebraska, United States
Joined May 2004
The Great Planes PT40 can be built with ailerons, then you can 'lock' the ailerons into a neutral position until you are ready to use them. You will need to build the 'trainer' wing to do this in order to maximize your dihedral.
flyboy2610 is offline Find More Posts by flyboy2610
Old Oct 09, 2004, 07:23 PM
mpj220 is offline
Joined Apr 2001
I sold a SIG Seniorita for a friend a couple months ago.
It had two wings already built - best of both worlds.
http://www.rcgroups.com/forums/showt...ight=seniorita
Discussion 2m Blade Elevator Only? (no rudder) screamin' eagle Dynamic Soaring 24 Feb 10, 2007 05:27 PM
Discussion Great Planes Electric Cub (rudder and elevator version) rcozstyle Australia 3 Jan 06, 2007 06:52 PM
E-Starter rudder & elevator only Lammergier Parkflyers 9 Aug 10, 2003 12:37 AM
Aerobatic Flying for Rudder/Elevator planes genovia Parkflyers 3 May 10, 2002 09:59 PM
Why rudder/elevator on two servos? Fred Bronk Electric Plane Talk 30 May 15, 2001 12:56 AM
