Old Feb 13, 2002, 12:06 PM
hyperbot is offline
Find More Posts by hyperbot
!sdrawkcaB ylF
Atlanta, GA
Joined Feb 2002
BEC Controllers - Best for $$ ?
Hi all,
I am in the process of upgrading from a 280 motor to a 370 with better gearbox. In that upgrade, I "almost" forgot to upgrade my speed controller, which would need about a 15A to 20A BEC. (I'm trying to slip this one under the budgetary radar)
Does anyone know of an inexpensive brand that is ok? I have seen the big stores with prices of $30, but wanted to challenge myself to locate the cheapest (but good) 15A-20A.
20A is preferred.
Thanks in Advance
hyperbot is offline Find More Posts by hyperbot
Old Feb 13, 2002, 06:39 PM
Dauntae is offline
Find More Posts by Dauntae
Dauntae's Avatar
New Bedford, Ma. USA
Joined May 2001
Take a look at the Kontronik SUN 1000, I have one and it has worked flawlessly, AND It is only $24 at Northeast Sailplane Products. It is a 18a esc with a 2 Amp BEC so it can be used with up to 4 servos. Some of the tech data is wrong on his website but it is a good esc and has had no problems for me and I plan on getting another especially for the price.
http://www.nesail.com/kontronik/sunkontronik.htm
Best of luck
Dauntae
Dauntae is offline Find More Posts by Dauntae
Old Feb 13, 2002, 07:02 PM
RRD is offline
RRD
Find More Posts by RRD
RRD
United States, NC, Asheville
Joined Oct 2001
I second Dauntae's recommendation of the Kontronik SUN 1000. I've got two of them and they're my favorite speed 400 (or light load 480) speed control at any price. And they're about as inexpensive as you can get. I like the fact that they don't have an arming switch. I hate having to cut an extra hole for those things and I don't trust them. I prefer to treat a model with a plugged-in battery pack as a loaded bomb - switch on or not. I've also accidentally switched one off as I handlaunched it. Not fun.
The SUN 1000 is hard to beat.
Bob
RRD is offline Find More Posts by RRD
Old Feb 13, 2002, 09:04 PM
sgil2001 is offline
Find More Posts by sgil2001
R/C Enthusiast
sgil2001's Avatar
Craley, Pennsylvania, United States
Joined May 2001
The Kontronik Sun 1000 is a great ESC. The Dymond ESC's are also good and very reasonable.
sgil2001 is offline Find More Posts by sgil2001
Old Feb 13, 2002, 11:32 PM
raythomas is offline
Find More Posts by raythomas
KZ RIDER
raythomas's Avatar
Confederate States of America
Joined Nov 2001
The FMA Mini20 is a good one. Its a little more than 30 dollars though, more like 40. But they are really tiny and light!!! Thanks Ray
raythomas is offline Find More Posts by raythomas
Old Feb 14, 2002, 11:46 AM
hyperbot is offline
!sdrawkcaB ylF
Atlanta, GA
Joined Feb 2002
Futaba?
I checked out the Kontronik link....sounds like it would do the job well, however, when I drilled down on the price link, it only displayed (JR) connector. Does anyone know if there is a Futaba connector available?
Old Feb 14, 2002, 01:44 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
The Sun 1000 would be my first recommendation as well.
The JR connector will plug into your Futaba equipment just fine and the wires are all in the proper order. The main difference between the connectors is that the JR/Hitec connector doesn't have that little tab sticking out of one edge.
Just pay attention to which way you plug it in and it will be fine.
Others to consider: WattAge IC-30A and Great Planes C20, but if Sal's selling the Sun 1000 for $24 you just can't beat it.
BEC is offline Find More Posts by BEC
Which sensorless SC will work the best for an F7LMR and 10 cells? GregG Electric Plane Talk 6 Nov 18, 2013 09:21 PM
Help needed: Hacker 50L 16 Turns.DS-51 3ph,Best controllers,cells for my F-14? bipeflyer Electric Ducted Fan Jet Talk 33 May 22, 2002 02:36 PM
Question Engine size or Area of controls best for aerobatics??? Don Sims Fuel Plane Talk 2 Oct 20, 2001 12:16 AM
Reflex or Washout best for "flying" wing? hardlock Power Systems 14 Jul 06, 2001 12:50 PM
what motor combo is best for IFO mk3 and mini. Paul15 Parkflyers 4 May 12, 2001 01:57 AM
