Espritmodel.com Heli Air
Old Feb 13, 2002, 10:14 AM
hem.bredband.net/b254298
Nicke's Avatar
Sweden, sthlm
Joined Nov 2001
Depron X-wing
Hello.
Built this in a couple of hours.
Wingspan is 70cm, and length 55cm.
Uses a DX-A with 10x4.7 prop, 2 pico servos, pico receiver, 6-7 cell 120 mah, or 7cell 700mah nimh.
I haven't flown it yet, so maybe it won't fly at all. but it glides real nice and slow in my living room.
I'll tell you if it works, hopefully i can try it today, but my girlfriend just told me we need to clean up the apartment...
Nicke is offline Find More Posts by Nicke
Old Feb 13, 2002, 10:15 AM
Nicke's Avatar
Sweden, sthlm
Joined Nov 2001
another pic
Old Feb 13, 2002, 10:16 AM
Nicke's Avatar
Sweden, sthlm
Joined Nov 2001
and another
Old Feb 13, 2002, 10:34 AM
Micro FPV
Durango Colorado
Joined Sep 2001
Looks pretty cool. Looks like you are using elevon mixing on the bottom wing only.... I would be interested in seeing how this performs. I would like to build something with the GWS pico flight pack
cactus is offline Find More Posts by cactus
Latest blog entry: FPV mQX
Old Feb 13, 2002, 12:25 PM
Nicke's Avatar
Sweden, sthlm
Joined Nov 2001
flight report
ok, tried flying.
Wind was calm, but when i threw it, a gust slammed it to the ground. sigh... No damage.
Some more tries...
At last, after getting the CG right it actually flew. But it was a bit too windy, and the upper wings flexed a lot. As you can see i taped the lower wing, and that was enough to keep it stiff, so i've done that to the upper wing too.
I guess the sticky thing on the tape hadn't 'set' yet, so it came off because it was cold. First receiver came off, then velcro holding the battery. So all i could do was walk home again.
I added 1mm carbon rod piece in the nose as 'front gear', to protect the foam when landing.
cactus:
Yes, it's elevon mixing on lower wing. First i was going to put it on upper wing, but because it's a kind of V-tail, it would give a rudder effect in the opposite direction as aileron. So i put them on lower wing, so rudder and aileron cooperates.. Guess it kind of makes an elevon v-tail or something... It was controllable anyway.
Old Feb 13, 2002, 04:25 PM
nolasco's Avatar
New York, NY
Joined Dec 2000
That's cool.
Now, how about a TIE fighter? Any takers?
Jun Nolasco
nolasco is offline Find More Posts by nolasco
Old Feb 13, 2002, 08:42 PM
Alberta, Canada
Joined Sep 2001
Ducted fan tie fighter?
Mikey-flies is offline Find More Posts by Mikey-flies
Old Feb 14, 2002, 05:42 AM
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
I think to make a tie fighter fly you would have to fly on your side. Which would be interesting.
Don't forget to add R2D2 to the model when is up and running.
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Feb 14, 2002, 09:13 AM
Strange Plane Central
frankenfoamy's Avatar
Poway (near San Diego), CA US
Joined Dec 2000
VERY COOL
Perhaps a rib at the tip will help keep the airfoil, maintaining the wing stiffness.
RCMicroflight is having a design contest that you should consider.
frankenfoamy is offline Find More Posts by frankenfoamy
Old Feb 14, 2002, 01:37 PM
nolasco's Avatar
New York, NY
Joined Dec 2000
Well, since I have 2 EDF50s and one KP44, I am also thinking along the lines of an EDF TIE Fighter. I am also thinking that since the "Flying Cube" seems to fly just fine in "diamond" attitude, a TIE Advanced or TIE Interceptor might just do the trick. That central sphere also seems to be the best place to place an EDF unit on.
Ah! Too many things to do and not enough time, not to mention that thing called "work".
Jun Nolasco
FS: Who want's an X-Wing interceptor? harryo Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2004 07:57 AM
Depron X-bow NightSwan Foamies (Kits) 2 Apr 17, 2003 05:57 PM
Micro Max Wing, my first indoor flying(..X,) wing Sparr Indoor and Micro Models 5 Aug 28, 2002 02:25 PM
X-WING byebyeplane Power Systems 7 Apr 28, 2002 11:39 AM
UFO? Starship? X-Wing? gzmtyl Electric Plane Talk 11 May 31, 2001 02:25 PM
