Old Jun 02, 2001, 12:25 AM
jnyoun is offline
Find More Posts by jnyoun
Spritual Pilot
Silicon Valley, CA
Joined May 2001
How to fix a crack of foam wing ?
My simple 400 have a crack in the wing.
What is the best way to fix (or glue) this
crack ? Is there any glue that has a good
penetration, but doesn't melt the foam ?
<img src=http://students.washington.edu/jnyoun/simple400/crack.JPG>
jnyoun is offline Find More Posts by jnyoun
Old Jun 02, 2001, 12:34 AM
sf_247 is offline
Find More Posts by sf_247
Austin, Texas USA
Joined Mar 2001
Epoxy works pretty well with this type of foam if you think you can "smoosh" it into the crack.
I think there are some foam-safe CA adhesives, but I have not used them on this type of foam.
Shawn
Eflightpower.com
sf_247 is offline Find More Posts by sf_247
Old Jun 02, 2001, 01:08 AM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
If it's just cracked and not completely severed I think thick foam-safe CA would work OR Pro-Bond polyurethane glue because it expands while curing and will seep into the pores of the foam well. It is light and sands decent too.
Troy is offline Find More Posts by Troy
Latest blog entry: Flying Ghost
Old Jun 02, 2001, 07:30 AM
poobs is offline
Find More Posts by poobs
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
Sorry about the damage - hang in there.
I use epoxy. Drip it in the crack, push it a bit with a tooth pick etc. You can smooth it out on the surface with a thin piece of scrap ply or cardboard like a spatula.
When it dries, try to heat the covering back over it or patch it up.
good luck!
poobs is offline Find More Posts by poobs
Old Jun 02, 2001, 08:41 AM
bidule is offline
Find More Posts by bidule
jean-claude Terrettaz
bidule's Avatar
Carp, Ontario, Canada
Joined Mar 2000
I will fix with epoxy and ligth cloth .5 oz , 1 inch wide .Good luck. J-C
bidule is offline Find More Posts by bidule
Old Jun 04, 2001, 07:44 PM
jnyoun is offline
Spritual Pilot
Silicon Valley, CA
Joined May 2001
Thanks everyone. The CA attracted me. However, I fixed with Epoxy mainly because I have it. I also enforced the leading edge with balsa wood. It looked too weak to me.
Discussion Question how to fix warp foam? DanT Foamies (Scratchbuilt) 5 Aug 21, 2007 09:48 AM
How to fix a sheet balsa wing warp? NitroCharged Scratchbuilt Indoor and Micro Models 11 Jun 21, 2004 01:56 AM
How to fix Alfa Corsair Wing MadJocko Parkflyers 7 Jun 19, 2004 10:33 PM
How to fix Omega wing ?? danny_isr Electric Sailplanes 17 May 30, 2002 05:04 PM
How To Build Foam Wing - Really Neat! hoppy Foamies (Kits) 0 Feb 17, 2002 08:35 PM
