Old Oct 05, 2004, 07:31 PM
RcAroPlanes is offline
Find More Posts by RcAroPlanes
Joined Sep 2004
My New GWS F4-U
Hey I picked up the Corsair today even though the only video I have seen showed a nasty tip stall. So I serched for along time and still no videos So If you have a Corsair video post it here plz. After the video I saw I doubt that I can land this thing lol. Well off to work on it I'll keep you posted with pics!
RcAroPlanes is offline Find More Posts by RcAroPlanes
Old Oct 05, 2004, 08:01 PM
Joined Sep 2004
A quick qustion, after installing the wing hold down nut,pushrod tubes and the tail wheel do you glue the fuse halfs together? The manual never says anything about glueing the fuse halfs in the whole book....????
Old Oct 05, 2004, 08:17 PM
AirDevil is offline
Find More Posts by AirDevil
Joined Jun 2004
the gws corsair is a very stable bird, its the p-51 that likes to tip stall. ck out the videos at www.e-flightline.com. landing is a piece of cake.just make sure your field has plenty of room, bring it in hot and flare slightly at the last second.
AirDevil is offline Find More Posts by AirDevil
Old Oct 05, 2004, 08:19 PM
Dave K is offline
Find More Posts by Dave K
Dave K's Avatar
Sebastopol, Ca
Joined Jun 2004
Yes you glue them. You will like your Corsair they fly great. If you do not think you can land it you could leave the landing gear off and belly land till you get a feel for the plane.
Dave K is offline Find More Posts by Dave K
Old Oct 05, 2004, 09:07 PM
xmech is offline
Find More Posts by xmech
xmech's Avatar
United States, TN, Memphis
Joined Apr 2003
With a Brushless motor and a 3s lilpoly it rocks.Don't worry, it's not prone to tip stalling at all, keep it light and leave that gear off!
Off course with all GWS WarBirds watch the C/G.
Don't expect good aerobics if flying stock motor, it likes "speed" for that.
Good Luck you'll love it.
George
xmech is offline Find More Posts by xmech
Old Oct 06, 2004, 05:41 PM
Joined Sep 2004
I got the tail section rudder, elv, tail wheel, done and the fuse is glued. I am started the wing, I am setting up for single servo. I think this is the hardest step did you guys bend the rod going from the servo to the alieron? I know I can't speel opps spell lol .
Old Oct 06, 2004, 05:49 PM
PlagueWulf is offline
Find More Posts by PlagueWulf
F4U Corsair
Kristiansand Kjevik, Norway
Joined Sep 2004
If you have a piece of wire (from speakers or other), pull out the metal and use the rubber (?) part of the wire (the covering) and use this for the aileron pushrods. Use this all the way inside instead of three small ones. The three small pieces recommended is very likely to get glue inside and become hard or impossible for the servo to move.
When you glue them use epoxy (5-15 min) and push down in the middle with a pencil or something and hold it until it`s dry.
PlagueWulf is offline Find More Posts by PlagueWulf
Old Oct 09, 2004, 01:56 AM
Joined Sep 2004
I got it done tonight at 11:58pm..... I am going to fly her in the AM wish me luck pics to follow.
Old Oct 09, 2004, 07:50 AM
agriebel is offline
Find More Posts by agriebel
agriebel's Avatar
Madison WI
Joined Aug 2003
check out www.hobbyhorse.com/movies.shtml for a good GWS F4u Video
agriebel is offline Find More Posts by agriebel
Site Sponsor
Old Oct 09, 2004, 03:47 PM
Joined Sep 2004
Wow what a great bird!!!!!!!!! I had two flight and I got some video but will post it latter. This thing loops so tight I might cut out some elavator to make it scale. The rolls are slower than scale and they suck. I am only useing one servo for the wing I might change this to roll better. Some one told me that they have to land hot, mine floats good I almost blew off the park on my aproch. Keep an eye out for my video I hope to post it before tonight!!
thanks to all that helped me this fourm rules!
Old Oct 10, 2004, 01:08 AM
RCDad is offline
Find More Posts by RCDad
Bay Area
Joined Feb 2004
Congrats on your maiden!!
Seems to me if you build the Corsair right it flyies like a dream. My single aileron servo Corsair also does a slow roll. I just replaced the HS55 sub micro servo with a larger (and heavier) micro servo for more power to drive those binding ailerons and more throw. Unfortunately I'm using the receiver in my new Spitfire. So I'll have to buy another RX to fly the Corsair again.
RCDad is offline Find More Posts by RCDad
FS- New GWS F4-U corsair and ESC Etonic Aircraft - Electric - Airplanes (FS/W) 1 Dec 30, 2003 10:23 AM
Ordering my new GWS Beaver tomorrow AM...what should I get in addition? Kodiak Flyer Parkflyers 1 Feb 10, 2003 01:07 AM
Can I use my new GWS MC2002 Charger to charge my Transmitter Batts? mrebman Batteries and Chargers 16 Jan 09, 2003 10:12 AM
My new GWS-EPS-300C IFO MM (IFO motor mount) William A Scratchbuilt Indoor and Micro Models 2 Apr 22, 2002 04:54 PM
Cool Jack is my new GWS Tiger Moth pilot Fly Parkflyers 8 Dec 21, 2001 08:46 AM
