Old Oct 05, 2004, 03:16 PM
superdave42 is offline
Find More Posts by superdave42
Designer
superdave42's Avatar
morgan hill california
Joined May 2004
3D fusealage design in CAD where to start??
Hello I wanted to try my hand at creating a vacum form for a custom fuse design. I am very fluent with 3D modeling and mostly use solidworks. I found an actuall model of the fuselage I want to make, but it is an actual display model that you glue together. what is the best way to dimension it and re-create it in CAD, can be a surface model or 3D solid. I appreciate any help you all can give.
or if someone has done this , please point me in the right direction/thread.
Thanks guys :-)
superdave42 is offline Find More Posts by superdave42
Old Oct 05, 2004, 06:36 PM
OzDragonFlyer is offline
Find More Posts by OzDragonFlyer
Model Bender
OzDragonFlyer's Avatar
Australia, NSW, Newcastle
Joined Jun 2004
Never built an accurate replica from scratch but have seen it done from tri-view drawings. Sketch around the 3 views from a scanned document and create cross sections at regular stations from front to rear.
Use a controlled boundary blend or loft between these sections to create the surfaces. This is only one way to do it but pretty much my favourite as it's very quick to build complex surfaces with compound curves.
If you really need accuracy take it to someone who has a 3D digitiser that outputs point clouds, might take a little while to do something as big as a glider though
OzDragonFlyer is offline Find More Posts by OzDragonFlyer
Old Oct 05, 2004, 06:40 PM
Designer
Joined May 2004
Thanks Oz, I think I need to get more into surface modeling.. everything I do is SOLID. good info though., still looking for more.
Old Oct 05, 2004, 10:41 PM
Model Bender
Joined Jun 2004
I'd like to see how you solve this problem as I haven't the patience to duplicate an existing model exactly If you work out a good technique let us know! There's a plastic Mig29 kit at home I've always wanted to copy into a full size slopie
Old Oct 06, 2004, 10:43 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Check this model out...
I did this from just a set of 3 views and pictures I gathered doing research on the net for it. I will post more pictures of the process if you are interested.
Eric b.
I used a combination of surrface and solid modeling from AutoCAD and AutoDesk Inventor to derive the parts shown. It is a pusher model of the A-4 Skyhawk II and will be done in 65mm fan sized when the pusher version is finished.
AirX is offline Find More Posts by AirX
Old Oct 08, 2004, 05:41 PM
Designer
Joined May 2004
Hey air X I am interested keep posting dude :-)
Old Oct 08, 2004, 05:42 PM
Designer
Joined May 2004
I am trying to model a helicopter fuselage and need to create a vaccuum form.
I was going to model the cannopy and create then print it out in 3d stereo lith.
then use that to create the modl from.
Old Oct 08, 2004, 05:59 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Hi Dave,
Do you know AutoCAD 3d, without that it would take a full AutoCAD course to bring you up to speed on it.
Eric B.
Scratch that, I went back and started reading from the first and saw that you are fluent in 3d so I will start a few posts that will help to define what needs to be done to model in 3d starting with simple aircraft shapes.
Old Oct 08, 2004, 06:12 PM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
If your are going to get into complex surface modeling and point clouds in SolidWorks, try and find a copy of the ShapeWorks plug in. here is a link for more info:
http://www.baren-boym.com/pages/solidworks_sa_sw.htm
The only problem with it is how time seems to go awry when you start playing with it....
Oh, yes, they have an evaluation version
mark_q is online now Find More Posts by mark_q
Old Oct 08, 2004, 06:22 PM
Designer
Joined May 2004
Yes airX VERY fluent with 3D SOLID modeling. no surface experience..
I appreicate your help guys.. very much
I am a mechanical designer.
Tis is my first surfaceing job....
Thanks for the link Mark...
Old Oct 08, 2004, 06:34 PM
LiftVsGravity is offline
Find More Posts by LiftVsGravity
Gravity is Winning.......
LiftVsGravity's Avatar
Jacksonville
Joined Jun 2003
I agree with the AirX. It has taken me 6 or 8 months of lunch hours to learn enough to do this little bit. I am proud of it, but I have learned so much doing it, I think it stinks now and want to redo it.
At work we are on AutoCAD 2002 and are now moving up to 2005. It takes quite of bit of work, but it so worth it. This file as it is in the picture is 10mb. One of my coworkers (AutoCAD monster, taught me the basics) said the other products of AutoDesk work better for 3D modeling.
LiftVsGravity is offline Find More Posts by LiftVsGravity
Old Oct 08, 2004, 08:53 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Ok, tomorrow I will get the first part read for a little fuselage modeling. I wont go into great depth but enough to translate over to other platforms. I will be using AutoCAD v2000, so the AutoCAD people will probably get more out of it but the general ideas are translatable to Solidworks and Rhino etc.
Eric B.
Old Oct 08, 2004, 09:22 PM
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Hey Dave,
Here is another RCgroups link called "SolidWorks, Show your Stuff"
http://www.rcgroups.com/forums/showthread.php?t=155581
Mostly SW, but others as well. Some good contacts for questions here too.
And another: http://www.solidmag.com/
This is the SolidWorks Users official publication and a great resource.
And lastly there is always Solid Solutions Advanced: http://www.d-digest.com/ssa/v3i2/model_tips_review.html
Another good pluggin if you can get it is FeatureWorks which does a great job of file conversion from all formats including converting AutoCAD 2D drawings into full featured parametric models. (providing of course the drawing was done fully associated to begin with).
Enjoy - Mark
Latest blog entry: X-UAV Mini Talon #2
Old Oct 08, 2004, 09:42 PM
Mike James is offline
Find More Posts by Mike James
Mike James's Avatar
Anchorage, AK.
Joined Jan 2003
3D models from 3-views and/or plastic display models
If you're excellent, you can use your eyes, along with some good photos and 3-views to create a 3D model that's very close to the original. My general technique for creating a 3D model from 3-views is at http://www.nextcraft.com/3drcdesign.html
If you have a plastic display model that you believe is accurate enough for your needs, then you might try building it and slicing it up, then scanning the slices for import into your 3D software as cross-sections. The method I use for this is posted at http://homepage.mac.com/mikejames/pl...c_to_rc01.html
Mike James is offline Find More Posts by Mike James
Old Oct 08, 2004, 11:34 PM
Apivat J is offline
Find More Posts by Apivat J
Kamen Raida Buisuri
Apivat J's Avatar
Bangkok Int, Thailand
Joined Sep 2004
Hi Mike,
I discovered your website about a year ago and tried you technique but the problem is I couldn't get go enough resolution on the raster image like you have above without renderring it. So, the image appear jagged and it's impossible to trace accurate lines over it. Do you mind explaining about how did you do that in Rhino? I can only come close to your above image when I use 3DMax. Again 3DMax is only good for animation stuff not to mention its complexity.
Apivat J is offline Find More Posts by Apivat J
Sky Crawler design in May issue of MA RegH Parkflyers 47 Aug 28, 2012 09:47 AM
How to Cut a 3D modle in Cad. F-111Nut The Builders Workshop 3 Feb 24, 2005 10:39 PM
Flying Boat Design... Where to start? All_talk Waterplanes 3 Nov 04, 2003 11:31 PM
Newbie interested mainly in micros. Where to start? tjg417 Scratchbuilt Indoor and Micro Models 2 Sep 03, 2003 07:49 PM
Where to start DenB Electric Plane Talk 4 Jul 16, 2001 10:43 PM
