Old Oct 05, 2004, 02:42 PM
soholingo is offline
Find More Posts by soholingo
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
Affordable Surprises???
Looks like Dieter may be selling surprises at a decent price.
Dieter a couple of questions....
Can I get flaps?
Are the fuses made with kevlar like the s11?
Whats the difference between the 5 and the 6 besides airfoil and wing length?
How big of a prop can they take?
Two piece wing option?
http://www.rcgroups.com/forums/showthread.php?t=283255
soholingo is offline Find More Posts by soholingo
Old Oct 05, 2004, 06:41 PM
ShredAir is offline
Find More Posts by ShredAir
slope'n somewhere in the Andes
ShredAir's Avatar
Peru, Puno
Joined Mar 2001
What a nice surprise... : ) there is some interest...
I'd like to shift discussion of the thread to here, so I'll attempt to answer questions from the announcement thread.
First, the nice thing about a Surprise is, it IS a Surprise. These 5s and 6s are built exactly like the current ones, aramid, carbon, everything is the same. In fact at first glance, and even at second, they look like a S11. These planes take 18" props. We let the customers implement the 2-piece wing option themselves, and we recommend to use an axe, because carbon dulls the saw blades very quickly.
Flaps are available top- or bottom-hinged for little extra money, my guess is $30.
These models are designed for 27-cell systems, so they will hold the current 16-18 cell ones. I assume a plane designed for 16-cell/200A, will simply be just big enough to make the FAI loading (75g/dm2) and have noses long enough to accomodate 18" props; kinda like a Surprise 6.
The RG-14 and MH-30 airfoils are both very fast and similar enough for other factors to wash out their differences. One such factor is wing planform, and that is proven Surprise. If you want to use snap-flap in turns, I'd stay away from the RG-14, and even the MH-30 is probably not all that happy with it. I consider snap-flap on these planes difficult to implement, and I achieve better results by optimizing the CG.
For a 2-meter Surprise, we can offer a similar deal on the Surprise 7. Please let me know if there is interest, and I'll get more info.
Dieter Mahlein, ShredAir
ShredAir is offline Find More Posts by ShredAir
Old Oct 05, 2004, 06:49 PM
temacc is offline
Find More Posts by temacc
H2OFLY
Portland Oregon USA
Joined Feb 2000
Originally Posted by ShredAir
snip....We let the customers implement the 2-piece wing option themselves, and we recommend to use an axe, because carbon dulls the saw blades very quickly.....Dieter Mahlein, ShredAir
What!? Dieter has a sense of humor!?
But we all knew that, didn't we?
Hey, Dieter,
Sorry I missed Saturday at your Quiet Fly event in Washougal...but glad I got to see you both, again. Doing it again next year?
Terry in Portland
temacc is offline Find More Posts by temacc
Old Oct 05, 2004, 07:08 PM
tufnik is offline
Find More Posts by tufnik
F5B, helis...too much
Fairfax, VA
Joined Mar 2002
Snap
What is snap-flap?
The main advantages, I believe, of a plane with flaps, vs no flaps, are better spot landings and faster turns, right? My planes don't have flaps. I use spoilerons for the landings. Can you still be competitive with a no-flap plane?
tufnik
tufnik is offline Find More Posts by tufnik
Old Oct 05, 2004, 07:23 PM
Synth is offline
Find More Posts by Synth
We come in peace.
Synth's Avatar
Canada, BC, Penticton
Joined Feb 2003
Surprise 7 sounds cool. Which airfoil?
Synth is offline Find More Posts by Synth
Old Oct 05, 2004, 07:33 PM
down_shift is offline
Find More Posts by down_shift
down_shift's Avatar
United States, VA, Leesburg
Joined Feb 2003
Originally Posted by tufnik
What is snap-flap?
tufnik
Mixing flaps that deploy with up elevator. I have a few millimeters of flaps on a proportional link to up elevator on the Avionik. Works well by adding lift during the tight turns. HD-43 6.5% airfoil
Dieter - several of us are thinking about moving to 16 cells next year. What are the differences between the Surprise 5 or 6 to the 11?
down_shift is offline Find More Posts by down_shift
Old Oct 05, 2004, 09:22 PM
ShredAir is offline
ShredAir's Avatar
Peru, Puno
Joined Mar 2001
The S7 airfoil is the MH-30 7.4%, which probably the same as the 6, but I have to check that.
Russ, as I said, at first and second glance, the differences between 5, 6, and 11 are minimal: almost identical planform and outlines, with the 5 having about an inch more span than the 11, and the 6 about an inch less. I need to obtain exact surface area data for a clearer answer. But mostly, it comes down to airfoil differences.
Another word on snap-flap: your Avionik must be flying at less than max FAI load, otherwise I doubt you'd see an improvement particularly with proportional snap-flap. If your radio allows, experiment with 100% of snap-flap deploying over only the last 30% of up-elevator travel. From what I've observed with FAI-max loaded planes, CG position is far more important to turning characteristics than snap-flap.
Old Oct 05, 2004, 11:50 PM
rcelectfly is offline
Find More Posts by rcelectfly
rcelectfly's Avatar
San Diego, CA, USA
Joined Nov 2001
Dieter,
I tried the axe first to get the canopy opening for the canopy option. To say the least it did not work very well. I think that I should have used my chainsaw instead for the canopy opening.
Now, I am afraid to use the axe to make the wing into two pieces.
Chuck
rcelectfly is offline Find More Posts by rcelectfly
Old Oct 06, 2004, 12:16 AM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
Originally Posted by rcelectfly
Dieter,
Chuck
LOL!!! I forgot to ask for the canopy... Thanks for having my back Chuck
Old Oct 06, 2004, 03:40 AM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
I know for sure that a 3 piece wing is an option for the Surpise 10, I've seen a couple, so there might be a way....
WimH is offline Find More Posts by WimH
Old Oct 06, 2004, 05:30 AM
Kyri is offline
Find More Posts by Kyri
Kyri's Avatar
England
Joined May 2000
I had a surprise 6. It was an extremely nice plane to fly and I miss it.
The wing is similar in construction to the S-11 except that there isn't a carbon D-box, and it a bit thicker than the -11.
The spar is very strong, if I can find the remains I'll post a picture of the spar.
I think it will be a great option to have one of these planes. I also liked the landing capability of the -6 vs the -11 (non flapped). On 16 cells and being a bit lighter they should be even better in the turns and landing.
As far as I remember the area was OK for the current rules so it will for sure be OK for the new rules. The wing was a little shorter but the chord a little wider than the S-11. In any case playing with the tail area can make planes legal for ex the S-9 with the tail from and S-7 would also be legal.
Regards
Kyri
Kyri is offline Find More Posts by Kyri
Old Oct 06, 2004, 07:39 AM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
Sure there is a way but Rudi doesn't want to make them...
Old Oct 06, 2004, 08:17 AM
kitfoxdrvr is offline
Find More Posts by kitfoxdrvr
Authorized Self-Portrait?
kitfoxdrvr's Avatar
Greensboro, NC
Joined Nov 2003
Dieter:
No similar pricing options for a F5F-legal airframe of the same vintage? Need a good home for my 10 cell motor!
Steve
kitfoxdrvr is offline Find More Posts by kitfoxdrvr
Old Oct 06, 2004, 08:39 AM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
Where is the info on the site?
Kirby
kepople is offline Find More Posts by kepople
Old Oct 06, 2004, 09:23 AM
ShredAir is offline
ShredAir's Avatar
Peru, Puno
Joined Mar 2001
A 3-piece wing MAY be an option, but why spend that money, lug the extra weight, and compromise strength if the wing is only 166 cm long? A 3-piece wing IS an option on Surprise 10 and 12 (about 2-meter span), as it is on the Surprise 7.
Steve: looks like we can do a similar price on the Surprise 7, which is 10-cell legal.
Kyri: thank you for the comments. What you describe is part of the reason why Rudi on is own, without me bugging him, is dusting off the "old" 5 and 6.
Folks, since there is some interest, I'll go back and get more detailed information; I'll have that in 24 hours. I did glean this old promo shot of Surprise 6 with Rudi Freudenthaler off his website (it was tiny, I doubled it in size, hence it's so crappy). There it says the span of the 6 is 1685 mm, which is 66.3", so I definitely have to get the better data.
Kirby, we're embarrassingly behind on our website updates, but Surprise 5 and 6 would not yet appear anyway.
