Old Oct 04, 2004, 07:56 PM
guapoman2000 is offline
Find More Posts by guapoman2000
Account closed
Joined Oct 2002
Orlando E-Zone SQUAD Version-XIII. (V-1 Started by RMason they think!!!)
WORD is mini-Sport, my true Love
guapoman2000 is offline Find More Posts by guapoman2000
Old Oct 04, 2004, 08:54 PM
sbmon is offline
Find More Posts by sbmon
Joined Aug 2004
Wow that looks great Jim
What paint did you use?
sbmon is offline Find More Posts by sbmon
Old Oct 04, 2004, 09:15 PM
fishdeth is offline
Find More Posts by fishdeth
Team Broke
fishdeth's Avatar
Orlando/ Winter Garden, FL
Joined Feb 2003
Thanks guys,
I used Pactra orange & yellow paint I got at Graves. It is foam safe.
The red is Testors and doesn't do well on Bluecore but doesn't seem to bother the Depron. (Which BTW is a wonderful material to build with)
I sprayed the red over top of the orange after it was fully dried.
I am really STOKED about this baby !
Jim
Sorry, just wanted to get a pic here in the new thread......
fishdeth is offline Find More Posts by fishdeth
Old Oct 04, 2004, 10:14 PM
Account closed
Joined Oct 2002
Jim,
It's going to be better than the GWS FORMOSA. Notice the long FUSE and super wide (Tall) FUSE design which will help it perform fantastic Knife Edges!
Wow! Can't wait to see her in the air!
Great Job!
Carlos
Old Oct 04, 2004, 10:24 PM
Account closed
Joined Oct 2002
Mini-Sport Complete!
Gerry was kind enough to give me his hollow rubber Pilot that served him well in many missions with his own mini-sport and scratch build BUCKER JUNGMEISTER. He also gave me the windscreen from his mini-sport.
Thank you Gerry!
Here's a couple of pic's showing this pilot take on new assignments in a new model.
Old Oct 05, 2004, 12:11 PM
Account closed
Joined Oct 2002
Jet Models Will Push the Envelope for Safety's Sake
http://www.nasa.gov/vision/earth/imp...light/gtm.html
NASA Langley technicians built the Generic Transport Model trainer, a five-and-a-half percent scale version of a commercial airliner that weighs 50 pounds. It has an 82-inch wingspan, is remotely piloted and has turbine engines. Builders would have liked to construct a larger model, because it would have been easier to equip with all the gear needed to make it realistic. Instead they used already existing molds to help keep the cost down and because they had wind tunnel data for the same sized model.
Interesting article. Wish I could be up there helping out with those models, I mean RESEARCH!
Old Oct 05, 2004, 04:12 PM
Account closed
Joined Oct 2002
Going to try and get home to fly the fleet at Edwards!
Carlos
Old Oct 06, 2004, 07:16 PM
Account closed
Joined Oct 2002
2nd day in a row SUPER FLYING @ EDWARDS!
Check out my flight report!
http://www.rcgroups.com/forums/showt...16#post2725816
Old Oct 06, 2004, 07:50 PM
dogon1013 is offline
Find More Posts by dogon1013
Watts Rule, Glows Drool
dogon1013's Avatar
orlando, FL
Joined Mar 2003
I need some help from those of you with covering experience.
I recently saved the first RC glider i ever built from my moms attic. It is an Estes Astro blaster rocket assist canard glider that i hope to convert to Electric (it is just missing the 2 rudders on the wing tips). I built it many years ago, when i was about 14. (almost 14 years ago ). the years in the attic left the covering all wrinkly. after hitting it with the heat gun all the wrinkles disappeared but where the wing meets the fuse the covering pulled away. i want to re-pair and recover some of the wing.
The wing is pushed thrue a wing shaped hole. i was able to break the glue free and pull out the wing. the question is how should i go about re-pairing and re-covering.
should i glue the wing securely and fillet the wing fuse joint before covering? or do i cover the wing and fuse, trim to the joint line, and then glue them together.
I Plan on using the same covering that is already on there, but i will just add a white stripe to the bottom of the fuse and then a white strip on each inboard part of the main wing (and maybe the canard too).
Toby
dogon1013 is offline Find More Posts by dogon1013
Old Oct 07, 2004, 08:17 AM
plumb is offline
Find More Posts by plumb
Look what I did:D
plumb's Avatar
orlando,Fl
Joined Mar 2003
Toby
Pull all the covering and redo the whole thing. It may be easyer to do the fuse and wing seperataly but if the wing slides through the fuse you may want to cover it after its installed or the covering may tear or cause a bind on reassembly.
Brad
plumb is offline Find More Posts by plumb
Old Oct 07, 2004, 11:12 AM
dogon1013's Avatar
orlando, FL
Joined Mar 2003
The wing is very tapered so 80 of the wing covering will not touch the fuse during asssembly.
I am thinking of just cutting where i want the white stripe, re-assembling and glueing the wing, and then adding the stripe and repairing the fuse covering.
The real question is do i glue the wing first and then cover? or cover and then glue the wing? you are saying glue the wing and then cover, right?
Toby
Old Oct 07, 2004, 12:26 PM
plumb is offline
Look what I did:D
plumb's Avatar
orlando,Fl
Joined Mar 2003
no, cover and then glue. you can just remove small spots for ca wood/wood contact. It will be far easyer to cover smaller pieces than an assembled plane.
Brad
Old Oct 07, 2004, 12:30 PM
RMason is offline
Find More Posts by RMason
A Few Sandwiches Shy
RMason's Avatar
Orlando, FL
Joined Jun 2001
Toby -
Glue the wing in then cover it.I have 2 of them at home. Great conversion for electric.
Rob
RMason is offline Find More Posts by RMason
Old Oct 07, 2004, 05:01 PM
dogon1013's Avatar
orlando, FL
Joined Mar 2003
Rob,
you wouldn't happen to know where the CG is supposed to be would you?
Old Oct 08, 2004, 07:59 AM
plumb is offline
Look what I did:D
plumb's Avatar
orlando,Fl
Joined Mar 2003
I would assume from the two canard planes Ive had, that it would be around the leading edge of the main wing.
Orlando E-Zone Squad Version XV MattVernon Club Talk 3089 Jun 26, 2005 05:47 PM
Orlando E-Zone SQUAD Version- Niner. (V-1 Started by RMason they think!!!) fishdeth Club Talk 508 Jan 04, 2005 12:15 PM
Orlando E-Zone SQUAD Version-XII. (V-1 Started by RMason they think!!!) fishdeth Club Talk 501 Oct 04, 2004 08:07 PM
Orlando E-Zone SQUAD Version-XI. (V-1 Started by RMason they think!!!) Don Sims Club Talk 501 Jul 03, 2004 04:12 AM
Orlando E-Zone SQUAD Version-X. (V-1 Started by RMason they think!!!) Don Sims Club Talk 511 Apr 28, 2004 03:19 PM
