Old Oct 03, 2004, 06:02 PM
New Park Pilot is offline
Find More Posts by New Park Pilot
Norhteast Arkansas
Joined Jul 2004
Please Help! Air bubbles are driving me crazy!
Hey guys, I have a Sig King Kobra with a Super Tiger .61. I just brought the plane out of a six year retirement to find that it has the same problem now as it did then. The problem is that I keep getting air bubbles in the fuel line. The plane runs fine long enough to tune the engine and fly for a minute or so, then it begins to "surge" and lose power all togehter, then die. Before I put the plane away six years ago, I replaced the tank and all fuel lines with no improvement. I also tried different amounts of foam rubber around the tank. I have had it sandwiched in very tight, I have tried no foam at all, and I have tried everything in between. No luck. Someone said try a fuel filter. Tried that. Still no luck. Well, I tried it at home yesterday and it seemed fine, I took it to the field this morning, made a few last minute needle valve adjustments, and took off. Same as always, ran like a striped monkey for about a minute, then began to surge and finally died and gave me a very good test of my skills! (Died in a really bad place). I am out of ideas. Is there anyway that this could be anything to do with the motor or does it have to be a fuel system problem? My father did have one suggestion that I will try if none of you guys have any other ideas. I have the brass tubing from the tank coming out of the front of the firewall to make tubing replacement easy and the holes in the firewall are just large enough for the tubing. Could the vibration from the firewall into the brass tubes be causing these bubbles? I guess I will drill the holes out larger so that the tubing doesn't rest on the firewall. The KK is way to good of an airplane to let sit because of this, but it is a very frustrating problem. I remembered today for the minute or so that I got to fly it just how great it flies. Could any of you guys shed some light on this for me? Thanks a lot in advance.
Zach
New Park Pilot is offline Find More Posts by New Park Pilot
Old Oct 03, 2004, 07:15 PM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
Assuming that there are no leaks in the fuel pipes, the most likely cause of bubbles in the fuel line is a poorly fitting needle valve. Simplest cure is to put a piece of fuel tubing over the needle valve where it screws into the carb. Many Super Tigre models have this problem.
DaveSawers is offline Find More Posts by DaveSawers
Old Oct 03, 2004, 07:49 PM
Handy is offline
Find More Posts by Handy
Joined Aug 2004
Another cure for the needle valve would be to brush on some copper coat as a gasket material, works great and has solved many air leak problems, also check for any foreign material in the carb. If the Copper coat fixes the problem, run it for a while to verify, then buy a new needle valve. I would start checking for a mild fuel leak while the engine is at WOT and idle teathered to the ground and tilted straight up.
Handy is offline Find More Posts by Handy
Old Oct 03, 2004, 08:07 PM
Norhteast Arkansas
Joined Jul 2004
Thanks for the input guys. I will try those things.
Old Oct 03, 2004, 11:32 PM
XJet is offline
Find More Posts by XJet
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
Another thing to try is to use different oil in your fuel.
Last week we worked to set up a trainer for a club member who had flown plenty of helicopter stuff but no fixed-wing.
He fitted a TT46 to his model and we ran it in (as per instructions) using fuel that had a moderate level of castor in the fuel.
After a minute or so's running on the ground, air bubbles began to appear in the fuel line.
We replaced the external lines and clunk line and tried increasing the vibration isolation of the tank -- all to no effect so then (just playing on a hunch), I told him to switch to some fuel with pure synthetic lube. The problem disappeared completely.
It seems that some oils (particularly those with a high castor component), foam far more easily than some kinds of pure synthetic.
XJet is offline Find More Posts by XJet
Old Oct 04, 2004, 05:40 AM
turk1 is offline
Find More Posts by turk1
turk1's Avatar
Istanbul, Turkey
Joined Aug 2004
Sirs,can the problem be loss of nipple pressure from muffler?I have such a problem with my TT42 GP(inverted mount) for a time, until I discovered the castor oil reservoir clogges the pressure nipple after 2-3 mins of perfect run and then disaster.Watch the nipple pressure system first.
turk1 is offline Find More Posts by turk1
Old Oct 04, 2004, 04:49 PM
Tony Oliver is offline
Find More Posts by Tony Oliver
Tony Oliver's Avatar
North-East England
Joined Mar 2002
Take the engine out of the model and run it in a test stand. Connect one tube only to the carb from the pickup of a different tank to the one in the model - make sure the tank position is such that the fuel level is the same as the needle. that way there's no syphon or fuel draw problem. See if you can replicate the 'fault'. If you can, it's the engine. If not, it's still the plumbing/tank/pressure.
Tony Oliver is offline Find More Posts by Tony Oliver
Old Oct 04, 2004, 06:07 PM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
I read in a mag a while ago that putting a couple of drops of vinyl cleaner in a tank of fuel stops frothing which is another cause pf bubbles in fuel.
I'm not quite sure which kind of vinyl cleaner but I guess it's the type used for cleaning plastic parts of cars.
Andy.
AndyOne is offline Find More Posts by AndyOne
Allen wrenches driving me crazy!! Who makes the best wrenches? Mike C Electric Plane Talk 23 Aug 13, 2008 06:53 AM
Receiver plugs are driving me crazy!!!! HELP! cwildt Electric Plane Talk 5 Jul 20, 2005 10:34 AM
Please help i dont know what to buy, driving me CRAZY doctor_prox Beginner Training Area (Aircraft-Electric) 12 Jun 21, 2004 05:42 AM
Seperates Driving me CRAZY.. Can someone help? Tram Micro Helis 3 Feb 20, 2004 01:03 PM
Deans plugs are driving me crazy... BriWill Beginner Training Area (Aircraft-Electric) 17 May 05, 2003 03:59 PM
