Old Oct 02, 2004, 11:10 PM
Brill 1 is offline
Find More Posts by Brill 1
Artillery! King of Battle!
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
Are my TP2100 3S packs unbalanced?
I am two TP2100 G2 pack with about 15 cycles on them. They haven't really given my the performance I was excepting and tonight I noticed something.
I notice a drastic drop in power about 10 minutes in to a flight with my Zoom heli. The drop is something like 30-40%. I land, check temp on pack, 117 deg and check voltage, 10.88 volts! After resting the pack and allowing in to cool to room tempature, the resting voltage is 11.1 volts! I charge the pack and it take 1940mah...
I thought this was nornaml until I flew the Zoom with a Kokam 1500 3S pack until LVC kicked in at 9.0, landed, check pack temp, 138 deg and pack voltage 9.44 volts! After cooling and resting voltage is 9.55!
Should I call TP and send in my packs for testing? The date code on the pack is 8/4/04.
Thanks!
Brian
Brill 1 is offline Find More Posts by Brill 1
Old Oct 03, 2004, 09:04 AM
adamg is offline
Find More Posts by adamg
adamg's Avatar
Saskatoon, Canada
Joined Feb 2004
Charlie has stated quite a few times that a Thunder Power battery is over-discharged if it does not rise to a resting voltage of 3.4v/cell after the discharge.
adamg is offline Find More Posts by adamg
Old Oct 03, 2004, 09:14 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Why do you say it was over discharged? The TP is a 2100mah and the Kokam is a 1500mah pack.
The TP resting was 10.88V
The Kokam resting was 9.44V
If anything the Kokam was overdischarged.
Something's wrong with the TP, don't you think?
hoppy is offline Find More Posts by hoppy
Old Oct 03, 2004, 09:34 AM
Charlie Wang is offline
Find More Posts by Charlie Wang
Joined Dec 2002
Looks like with the recovery voltage of 9.44V is low, repeated use of the 1500s pack(or any Li-Poly pack) under this condition would likely cause one cell to fail prematually.
Anyway, you can call TP on Monday, they should be able to take care of you.
*Recovery voltage should be 10 to 15% higher than the cutoff voltage.
Regards,
Charlie
Charlie Wang is offline Find More Posts by Charlie Wang
Old Oct 03, 2004, 11:00 AM
Brill 1 is offline
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
Thanks Charlie, I will give TP a call on Monday and talk about it.
Brian
Discussion UGHH,I just ruined my TP2100 3s gen2? miamiquasar Batteries and Chargers 18 Jul 05, 2006 08:33 AM
FS: tp2100 3s packs $30.00 each (gen1) kmp647 Aircraft - Electric - Airplanes (FS/W) 5 Feb 21, 2005 01:11 PM
WTB: Gen2 TP2100 3s packs MX Batteries and Chargers 7 Sep 17, 2004 08:35 PM
Will I Fry My TP2100-3S? HavingFun2002 Batteries and Chargers 7 Apr 30, 2004 03:58 PM
FS: Thunder Power TP2100 3S packs Brand new mikeb33 Aircraft - Electric - Airplanes (FS/W) 20 Feb 27, 2004 06:00 PM
