Old Oct 17, 2004, 11:19 PM
ewo is offline
ewo
Find More Posts by ewo
ewo
ewo's Avatar
Spencer In.USA
Joined Oct 2003
Buzz
i could turn a rats stomach, But i dont care
Now dont be bashfull, show us your face, you cant be uglier than me
Thats ok, My middle name is pepto
Just build the thing and have fun
ewo
ewo is offline Find More Posts by ewo
Old Oct 18, 2004, 12:27 AM
stjobs is offline
Find More Posts by stjobs
Gainesville, Florida, United States
Joined Sep 2001
I might give this a try with the EDP-50 DD and either 3x2 or 3x3 prop. Any suggestions? Has anyone done this, and what kind of AUW is recommended? I would use a Kokam 2s1p 340mAh pack.
Is this an extremely fast flier? I'm not looking for very fast, just simple and easy to fly.
stjobs is offline Find More Posts by stjobs
Old Oct 18, 2004, 09:36 AM
jerbear is offline
Find More Posts by jerbear
jerbear's Avatar
indianapolis, indiana
Joined Oct 2002
stjobs
check out post # 30 on page 2 i believe
jerbear is offline Find More Posts by jerbear
Old Oct 18, 2004, 03:55 PM
stjobs is offline
Joined Sep 2001
Post 30 is a guy using an EDF unit... probably less thrust than an IPS motor run DD (EDP-50XC) with either 3x2 or 3x3 could provide.
I'm going to give it a try, will report later.
Old Oct 18, 2004, 06:24 PM
stjobs is offline
Joined Sep 2001
Hm... I put it together per the plans. AUW with 340mAh Kokams was 4 oz exactly. It felt like it had enough "pull" (or push, in this case) to fly. I brought it up to about half throttle and gave it a toss. Immediate nose over into the ground. I was flying over grass and the plane is light, so there was no damage other than the battery popping loose (I had it taped on).
Is the CG on the plans correct? Before installing any gear, I did some test glides with the plane, and with the CG at the spot in the plans it would nose over into the ground every time. I had to move it nearly 3/4" back to get it to glide well. Once I did that, the glide was fine. However, when I added the gear, I put the battery right at the nose. CG was right on the plans. What can I do to get it to fly level? I tried increasing the elevator throws and giving max elevator up, which brought it from immediately nosing over to diving steeply then starting to level out before sliding along the ground.
Old Oct 18, 2004, 07:42 PM
jerbear is offline
jerbear's Avatar
Joined Oct 2002
stjobs
my wing "ready to fly" including battery pack balances at 5 1/2 " from the LE of the wing. at this point, i can fly with 0 degrees in the elevons. most wings need a little up in the elevons to fly right. i have a small length of popsicle stick under the rear
(prop. side of the motor) this accomplishes the same thing, only w/o the need to have the up in the elevons. normal launch with this wing is a good slightly upward toss with power off (this is why i have a 2" length of 3/8" motor stick taped to the bottom ... so i have something to hold to get a good toss) as soon as the toss is completed - i give full throttle to gain altitude.
i would re-check the cg and do what is necessary to get it at the 5 1/2" mark. then i would try to find some high grass or tall weeds and squat (sit/kneel) whatever - just do not stand and with the battery in, give it a medium toss at a slight upward angle and see if it goes fairly straight. not immeadiatly up or down. you will still be able to adjust elevons if you need to.
hope this helps.
Old Oct 18, 2004, 07:57 PM
stjobs is offline
Joined Sep 2001
I wasn't aware the elevons had to be up as the neutral position - I will give this a try. I didn't angle the motor like you describe, but wouldn't that only affect it under power? I think my elevons would have to be at a drastic angle to get it to glide with the CG at the spot in the plans. Will report back.
Old Oct 18, 2004, 08:19 PM
stjobs is offline
Joined Sep 2001
Update: the CG in the plans I downloaded indicates it at 4 1/2" back from the LE! At 5 1/2" where you describe, it glides well. This is where I had been balancing it.
I downloaded "Simple Wing - All.pdf". I'm fairly certain my printer had it at 100% scale and so on, as the wingspan measures exactly 24". The CG is at 4 1/2", though. Has anyone used this CG successfully?
You might want to check the plans. The dimension even says 5.5" to where the CG is marked, but it's actually 4.5". Hopefully it will fly well now - just have to wait for daylight.
Also, with the lighter GWS IPS A motor run DD, my equipment has to be pushed far back. It would never balance with the battery under the nose. I have it underneath, about where the bamboo skewer is. I will work out some kind of foam plate under that for protection, or just fly over grass.
Old Oct 18, 2004, 08:57 PM
jerbear is offline
jerbear's Avatar
Joined Oct 2002
stjobs
good luck with the next try. thanks for the update on plans ... i will see if gene can fix it.
buzz
i have a couple of deltas .... both have a slight amount of dihedral
Old Oct 18, 2004, 10:27 PM
ewo is offline
ewo
ewo
ewo's Avatar
Spencer In.USA
Joined Oct 2003
jerbear
dont try to fix it cause it aint broke!!!!!!
Every body builds differently 1/8" here and 1/4" there
Motor further forward or further back, even a little makes a difference
Mine balances exactly 5 3/4" from the nose and its just slightly nose heavy, verry slightly
i cant stress enough how important it is to do glide tests on every build IMOHO
balance for the best glide balance point, then move that forward 1/4 to 3/8" for powered flight
it works every time for me
ewo
Ps
I didnt build mine from the pdf,s
I used the demintions on the picture from the first post
Old Oct 18, 2004, 10:44 PM
jerbear is offline
jerbear's Avatar
Joined Oct 2002
ewo
good advice .... it seems everyone has their own way .... online cg calculators,
hanging balance devices, and gut instincts. yours is the same as gpw's and it sure has served him well also. the amazing thing to me is that this wing is not as cg sensitive as many other models i have built ?? .... go figure !!
Old Oct 19, 2004, 12:27 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
I see the mistake. The 5.5" was marked from the original nose, before I chopped it off. Here's a corrected screenshot. I'll fix the drawings later....
Gene Bond is offline Find More Posts by Gene Bond
Old Oct 19, 2004, 07:34 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Jbear ... I love the wing !!!!... it epitomizes the the FUN/Simple aspect of Foam Flying ...I hope we can encourage you to do more "simple" projects ....????? !!!!!!!!
EWO...Test glides !!! I hear ya'!!! Very important .....that's two HO's.... humble opinions , of course ...hahahahahaha
gpw is offline Find More Posts by gpw
Old Oct 19, 2004, 08:42 AM
jerbear is offline
jerbear's Avatar
Joined Oct 2002
gpw
could be ! from simple minds come simple plans !!!
and i graciously accept any comments from the " blue foam master"
look forward to hearing you built and flew one !
Old Oct 19, 2004, 10:46 AM
stjobs is offline
Joined Sep 2001
"I see the mistake. The 5.5" was marked from the original nose, before I chopped it off. Here's a corrected screenshot. I'll fix the drawings later.."
That's more like it I will test fly it today.
Alert Jerbear's Simple Wing Part 2 Dulie Foamies (Scratchbuilt) 1155 Mar 17, 2016 12:38 PM
John Thompson's Removable Wing E3D Neil Stainton Sport Planes 49 Sep 14, 2002 07:55 PM
70's Sweeper Wing Duke58 Foamies (Kits) 9 Jan 04, 2002 07:16 AM
Has anyone built with the Lil Hornet's foam wing left overs? poobs Parkflyers 32 Sep 29, 2001 02:47 PM
PICO J3-S LOOSE WING PINS RZAKER Sport Planes 1 Jun 12, 2001 09:04 PM
