Old Oct 05, 2004, 10:17 AM
jerbear is offline
Find More Posts by jerbear
jerbear's Avatar
indianapolis, indiana
Joined Oct 2002
bud
now you will really appreciate the j250. it is incredible, how that small amount of dihedral makes it much easier to fly.
jerbear is offline Find More Posts by jerbear
Old Oct 05, 2004, 11:06 AM
spudandretti is offline
Find More Posts by spudandretti
Honey,just one more thing
spudandretti's Avatar
Rensselaer,IN
Joined Jan 2003
Well it flies great, inverted, every thing but loops? wonder why, any ideas?Bud
spudandretti is offline Find More Posts by spudandretti
Old Oct 05, 2004, 11:40 AM
jerbear is offline
jerbear's Avatar
Joined Oct 2002
bud
could be the cg is a little off ... you can move the battery aft a little ?
also ... is it possible to increase the throws a little ?
Old Oct 05, 2004, 12:16 PM
Rensselaer,IN
Joined Jan 2003
I'll try and move the cg back, the motor needs to be angled down from the front? first wing.Bud
Old Oct 05, 2004, 12:32 PM
jerbear is offline
jerbear's Avatar
Joined Oct 2002
bud
the motor should be shimmed about the thickness of a popsicle stick at the end
CLOSEST TO THE PROP ..... this causes the motor to sit at a slight downhill angle towards the front of the plane. with power on ... it will right itself in flight, causing a slight "climb with power" situation. mine is this way, and i am able to set the elevons at 0 degree for flight
Old Oct 05, 2004, 12:41 PM
Rensselaer,IN
Joined Jan 2003
Thanks.Bud
Old Oct 05, 2004, 02:37 PM
lgliser is offline
Find More Posts by lgliser
branson mo.
Joined Mar 2002
hellow and thanks for sharing the simple wing design. i built one up last pm
and gave it a try this am. wow it flys vantastic..i put a 3s1p 1020 up in
the nose to help set my cg close to plan, plenty of power.....
the 1 inch diehedral works greate to tame it down..wish i could add a pic
but my dig cam is on the blink...thanks again
lgliser is offline Find More Posts by lgliser
Old Oct 05, 2004, 02:53 PM
jerbear is offline
jerbear's Avatar
Joined Oct 2002
lgliser
glad you like it and thanks for the comments. it makes me feel good that i can finally give something back on this forum ...... i certainly have gotten tons of great advise and free plans from the likes of gpw, tog, genebond and many others. hope many others will enjoy this simple wing.
Old Oct 05, 2004, 07:06 PM
Cass is offline
Find More Posts by Cass
Departing at 'O' dark 30
Cass's Avatar
Sudbury, Ont. Canada
Joined Feb 2002
Wonder how it would fly on an IPS and 'A' gear with a 9x7 slow fly. Its so easy to build, if it could fly slow it might make a great "entry" model to RC.....
Cass is offline Find More Posts by Cass
Old Oct 17, 2004, 09:07 AM
ewo is offline
ewo
Find More Posts by ewo
ewo
ewo's Avatar
Spencer In.USA
Joined Oct 2003
jerbear
I started your wing this morning
Just one question right now, how wide and how long is the cover for the nose?
thanks
ewo
ewo is offline Find More Posts by ewo
Old Oct 17, 2004, 11:29 AM
ewo is offline
ewo
ewo
ewo's Avatar
Spencer In.USA
Joined Oct 2003
IM done
anxious as heck to test this bird out
I hope it does ok in the wind, cause
Im about to find out!!!!!!!!!
ewo
Old Oct 17, 2004, 01:36 PM
raythomas is offline
Find More Posts by raythomas
KZ RIDER
raythomas's Avatar
United States, MS, Tupelo
Joined Nov 2001
Would a gws EDP-50 direct drive with a 3x2 prop fly this wing? I have two of them but don't have any johnsons. Also, when you put it together what do you use for glue? In the pictures at the front of this thread it looks like a cross between hotglue and silicone. Thanks Ray
raythomas is offline Find More Posts by raythomas
Old Oct 17, 2004, 03:21 PM
jerbear is offline
jerbear's Avatar
Joined Oct 2002
ewo
sorry i did not get back to you sooner .... should have checked, as i have been here building. since yours is done - just for reference ... the cover is 11" long and 1 3/4" wide. (4" to glue under the bottom front and 7" to cover the gear)
looks like a very good job to me !!! they will handle a little wind .... preferably 10/12 mph or less. mine only weighs 4.3 oz. w/o the battery pack.
Old Oct 17, 2004, 03:25 PM
jerbear is offline
jerbear's Avatar
Joined Oct 2002
ray
being it is as light as it is .... i believe the edf 50 and 3x3 prop would fly it ok, maybe not as fast. if you try ... bear in mind that the edf 50 is lighter than the j250, so you would need to get your servos as far forward as possible (almost directly behind the battery spot, which is at the very front.
Old Oct 17, 2004, 03:27 PM
jerbear is offline
jerbear's Avatar
Joined Oct 2002
ray
sorry .... forgot the glue. i use mainly hot glue, but use 5 minute epoxy for the fastening of the cover to the bottom.
Alert Jerbear's Simple Wing Part 2 Dulie Foamies (Scratchbuilt) 1155 Mar 17, 2016 12:38 PM
John Thompson's Removable Wing E3D Neil Stainton Sport Planes 49 Sep 14, 2002 07:55 PM
70's Sweeper Wing Duke58 Foamies (Kits) 9 Jan 04, 2002 07:16 AM
Has anyone built with the Lil Hornet's foam wing left overs? poobs Parkflyers 32 Sep 29, 2001 02:47 PM
PICO J3-S LOOSE WING PINS RZAKER Sport Planes 1 Jun 12, 2001 09:04 PM
