Espritmodel.com Heli Air
Closed Thread
Old Sep 30, 2004, 11:25 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Jerbear's Simple Wing
Jerbear decided to try a simple wing design, following all the success he had with the flat-plate insulator. Following are the plans and some pictures of the one I built to prove the plans. I found that the original design needed a spar, after having the wings go into a high speed flutter a few times with my rather aggressive flying style The spar isn't shown in the early pictures, but is in the later.
Here's a video of a maiden as well... (He's not too proud of this one ): http://www.genebond.rchomepage.com/v...ple%20Wing.wmv
Gene Bond is offline Find More Posts by Gene Bond
Old Sep 30, 2004, 11:26 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
More
Old Sep 30, 2004, 11:28 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
And...
Old Oct 01, 2004, 08:01 AM
gpw
“There’s no place like Foam”
gpw's Avatar
Joined Jul 2002
Wait till he finds out about Low Aspect Ratio....hahahahaha here we go again!!!! hahahaha
gpw is offline Find More Posts by gpw
Old Oct 01, 2004, 10:46 AM
emoone's Avatar
La Grange, Georgia, United States
Joined Nov 2001
interesting!
emoone is offline Find More Posts by emoone
Old Oct 01, 2004, 03:07 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Hehehehehe He is on a quest for speed
I promised that after the current super-secret project I'm fiddling with, I'd work on a small pattern-type plane that should work DD. The only problem is he is a dedicated 3 channel guy. He gets confused when the throttle is on a stick instead of the rear slide (HiTec Focus 3).
I need to get some fresh video, to show how well the plane actually does fly, since it's pretty surprising the speed and agility of a stupid flat-plate. I take back all the bad stuff I said about flat-plates, they have their place.
Old Oct 01, 2004, 03:10 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Oh yea, notice that there is 1" of dihedral on each wing...
This is part of the 'magic' which makes these things great. Just enough to keep it from being twitchy andunstable, but it actually flies inverted well enough to enjoy.
Old Oct 03, 2004, 09:23 PM
ewo
What goes up, Must come down!!
ewo's Avatar
Spencer In.USA
Joined Oct 2003
Jeeze
Now i have another airplane i have to build Thanks guys
ewo
ewo is offline Find More Posts by ewo
Old Oct 04, 2004, 08:46 AM
jerbear's Avatar
indianapolis, indiana
Joined Oct 2002
ewo
you will really enjoy this one ..... good speed - even slows down decent - floats in for a very easy power/off landing - huge loops (inside and outside) nice rolls, and as gene mentioned ..... pretty easy to fly upside down. gene's and mine both weigh in at 4.3 oz. w/o battery. and as i am using 2s irate 830 packs, auw rtf is 5.7. j 250 really shines w/ direct drive at that weight .... flight times are 12 - 14 mins.
it is my current favorite to fly .... let us know how you like it, when you get around to it.
jerbear is offline Find More Posts by jerbear
Old Oct 04, 2004, 03:23 PM
Honey,just one more thing
spudandretti's Avatar
Rensselaer,IN
Joined Jan 2003
Can not remember, what was the size bit you use to drill out the props for the j250, gonna give this one a try, fast build, looks fun.Thanks,Bud
spudandretti is offline Find More Posts by spudandretti
Old Oct 04, 2004, 04:28 PM
Joined Feb 2004
5/64 works for me. But get a 2nd. opinion !
KsLarry is offline Find More Posts by KsLarry
Old Oct 04, 2004, 04:29 PM
Departing at 'O' dark 30
Cass's Avatar
Sudbury, Ont. Canada
Joined Feb 2002
Man the flying wing stuff gets simpler and simpler! I love it, way to go guys. Nice vid too . This one might be a good candidate for a sturdyboard, paper left on, type build.....
Cass is offline Find More Posts by Cass
Old Oct 04, 2004, 04:30 PM
jerbear's Avatar
Joined Oct 2002
spudandretti
i believe it is a # 14 but not sure .... as mine is not marked. the easy way is to compare the shank portion of the drill bit to the shaft on the j 250. it should be one size smaller than the j 250 shaft to insure a snug fit. i also use a drop of CA.
hope this helps
Old Oct 04, 2004, 04:35 PM
jerbear's Avatar
Joined Oct 2002
cass
i am not sure of the weight on the sturdyboard .... it may work, i just don't know the weight difference between it and the blucore fff. as i mentioned the wing complete and ready to fly w/o batteries is 4.3 oz. i tend to believe it would work .... try it - you'll like it !!!
Old Oct 04, 2004, 04:38 PM
Rensselaer,IN
Joined Jan 2003
thanks I will give it a try.Bud
Closed Thread
Alert Jerbear's Simple Wing Part 2 Dulie Foamies (Scratchbuilt) 1133 Feb 25, 2011 09:30 AM
John Thompson's Removable Wing E3D Neil Stainton Sport Planes 49 Sep 14, 2002 07:55 PM
70's Sweeper Wing Duke58 Foamies (Kits) 9 Jan 04, 2002 07:16 AM
Has anyone built with the Lil Hornet's foam wing left overs? poobs Parkflyers 32 Sep 29, 2001 02:47 PM
PICO J3-S LOOSE WING PINS RZAKER Sport Planes 1 Jun 12, 2001 09:04 PM
