Sep 30, 2004, 10:15 PM
Langley, B.C, Canada
Joined Jun 2001
Here are some possible power plants i found for a good price;
AXi 2820:10 cells, 10x6 prop, 9400 RPM, 29 amps, 221 Watts to the prop.
Axi 2826: 16 cells, 11x8 prop, 10300 RPM, 46.9Amps, 507 watts.
It's apperent that the Axi 2826 will give twice the power. But it needs 16 big cells to handle 45 amps. That'll add alot of weight. But att he same time, 500m watts will probly still fly her pretty darn good. The Axi 2920 is very efficent, and a mear 29 amps is quite low compaired to 45. I can use smaller cells, and less of them, but will 221 watts be enough power? I could go to an 11 inch propa nd bump up the watts to about 250-275 or so. But that'll mean mid 30's for the amps, still only needs 10 cells though. Im alittle worried about pulling 45 amps through the 2826 as the maximum current stated on the website is 40 amps...
I found that a 11-12 inch prop is about as big as i can use for landing gear clearance, so if i go with the bigger Axi, prop size might be a problem. The stock OS 40 uses a 10x6 wood prop, which is probly ideal for this type of design, im unsure though, im not sure which power plant is better for this project..
Both are around $215 US with a Jeti 40 amp BL ESC.
Thomas
