Old Mar 26, 2001, 03:07 PM
Ryan Nau is offline
Find More Posts by Ryan Nau
Tork it or Dork it
Ryan Nau's Avatar
Elizabethville,PA USA
Joined Jul 2000
What Nimh battery pack should I get for my Skat to get long flights?
On skat #2 i want to use another pack instead of my 8x600ae so I can get longer flights with it. What is the biggest nimh pack I can get for the longest running time that will fit inside that small skat fusluge? I use a Permax 400BB and 5-5 graupner racing prop??
Ryan Nau is offline Find More Posts by Ryan Nau
Old Mar 27, 2001, 01:41 AM
jschrader is offline
Find More Posts by jschrader
jschrader's Avatar
Munich area, Germany
Joined Jan 2000
I don't know the fuse of the skat but the
only NiMh that will work on high current are Twicell 1600.
I use 8 of them in my Switchblade and Adrenalin on 6V motors with 9 Minutes full speed and yet another one to calm down
Load at max. 2A reflex.
But you'll get much better performance on 7 cells 700 AR though.
jschrader is offline Find More Posts by jschrader
Old May 10, 2001, 11:40 PM
dmccoach is offline
Find More Posts by dmccoach
Kutztown, PA
Joined Feb 2001
Where can I get these Twicell packs?
dmccoach is offline Find More Posts by dmccoach
Old May 11, 2001, 09:37 AM
LJH is offline
LJH
Find More Posts by LJH
LJH
Moths do not fly inverted
LJH's Avatar
Greenwich CT.
Joined Sep 2000
I don't know how big the fuse is as well, but I have been useing the Radio Shack 1600's in my Twister with great result. What kind of AMP draw do you see with the P400 BB. I have been useing the RS pack in my PJC with a 14 turn Colbalt that Pulls 17 AMPS static on this pack. I have to fly at reduces throttle but I do regularly get 9:30 flights on that set up. On the Twister I am getting a easy 12 mins. Hope this helps.
Cheers,
Jim
LJH is offline Find More Posts by LJH
Old May 11, 2001, 10:24 AM
davidfee is offline
Find More Posts by davidfee
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
The SkaT fuse is JUST wide enough to fit 2 500 or 600mAh cells side by side. You can go longer than the standard 7 cell 5/600 mAh pack, but not wider or taller. The SkaT has probably the smallest under-wing cross section of any of the S400 pylon racers. A race only takes ~80-90 seconds... why do you care about long flights?
-David
davidfee is offline Find More Posts by davidfee
Old May 11, 2001, 10:57 AM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
A skat is a pylon racer, it is designed to go fast with minimum space. If you want longer flight, may be you should get a larger plane that carry a bigger electron tank.
Brian
bhchan is offline Find More Posts by bhchan
Old May 11, 2001, 02:53 PM
Ryan Nau is offline
Tork it or Dork it
Ryan Nau's Avatar
Joined Jul 2000
I just wanted some more minutes out of my flights. Besides know sometimes i use a 8x1000nimh and it works good for 7 minutes and has good speed. But I still like the 8x600ae for fast flying.
Old May 13, 2001, 06:08 PM
Dave Campbell is offline
Find More Posts by Dave Campbell
United States, MI, Commerce Charter Township
Joined Dec 2000
Guys,
If you really want to get long flights in a sp400 racer that is going to be used for sport flying, then you would do well to consider the Astro 010 with either the on/off control or the Jeti that Astro is now selling with the 010.
On 8 cells and the advanced timing that the Jeti controller gives, the 010 does a convincing impression of a 6v Sp400. I did a lot of testing on a new 400 F5B of mine over the spring and really like this combo. 500AR's last 6-7min., 1100 NiM's last 15 min. These are full throttle times. Take also into account that you will see a loss in weight, making an even better sport plane.
The low current draw of the 010 would also allow you to use the 720 NiM cells. These are the same weight as 350 NiCds, and really tiny. A sub 11oz. racer is doable this way-makes for really slow landings.
If you can get around the mental block of not having a throttle, Specialized Model Supply is running a special on 010's with the original controller for $89. I flew my pylon racer at 15.5oz at one time with this setup on 1700AULs, it's not a disadvantage like you would think.
Dave
Dave Campbell is offline Find More Posts by Dave Campbell
Reply With Quote  (Disabled)
Old May 16, 2001, 12:00 AM
exowatt is offline
Find More Posts by exowatt
UTAH, SLC
Joined Mar 2001
what prop are you useing on the 010?
i have a couple of simple 400s that i love
to sport fly and the 600ae's dont last for crap... im not up to par with the brushless motors so any help or recomendations would be great... the local hobby shop has a 010 if you think it would fly a simple ill buy it.
exowatt is offline Find More Posts by exowatt
Old May 16, 2001, 05:49 PM
Joined Dec 2000
I pretty much stick with the APC or Graupner CAM 4.7-4.7, but I have also flown a 5-3 glow prop for more and it was flyable if a little sedate.
The 010 will fly the heck out of a Simple 400, no sweat. If you get the motor with the Astro on/off controller(probably what your dealer has in stock) then stick to no more than the 4.7-4.7 prop and 7 cells unless you have a way to measure current. Any of the packs you already have should work ok.
I see that Hobby Lobby is now offering the Jeti-06 controller for $70.... Astro is selling these on their 010's(rebadged) for $120-130.
Dave
Old May 16, 2001, 06:30 PM
Ryan Nau is offline
Tork it or Dork it
Ryan Nau's Avatar
Joined Jul 2000
How fast will a Skat fly with an 010 compared to a 400 on 8x600ae?
Old May 16, 2001, 10:20 PM
dave morris is offline
Find More Posts by dave morris
dave morris's Avatar
orlando fl
Joined Oct 2000
Dont know about a scat, but my flea flies great on a 12t 010, jeti 18amp bl and a 4.7x4.7 apc on 7 cells (about 70 watts into a 13 oz plane). I like the 12t because of a bunch of 7 cell 600ae and 500ar packs I have, and duration is in the 8-10 min range. I am thinking of trying the schulze18 be as test indicate higher effecentcy at partial thottle. I do not think it would be a good idea to run WFO at 70 watts as the motor only weighs 30 grams and heats up pretty quick.
dave morris is offline Find More Posts by dave morris
Old May 21, 2001, 01:03 AM
sf_247 is offline
Find More Posts by sf_247
Austin, Texas USA
Joined Mar 2001
Ryan-
We sell packs that are composed of the high quality Twicell Sanyo 1600 NIMH AA cells. The 8 cell packs are on sale for $24 right now with high quality silicone leads. I use them in my Speed 400/480 applications. They weigh a little more than 600AE packs, but greatly increase the duration.
Shawn
eflightpower.com
sf_247 is offline Find More Posts by sf_247
Old May 21, 2001, 06:14 AM
Ryan Nau is offline
Tork it or Dork it
Ryan Nau's Avatar
Joined Jul 2000
I don't think they'll fit in the SkaT's small fusluge.
Old May 21, 2001, 01:12 PM
sf_247 is offline
Austin, Texas USA
Joined Mar 2001
FYI-
They are 1 1/16" square by 4 inches long.
Shawn
eflightpower.com
what LiPo battery would you get for a stock GWS F4U? STaNgXs Parkflyers 5 Nov 17, 2004 05:58 PM
Question GWS Me109 -What NiMh battery pack to use? irelandki Parkflyers 11 Apr 29, 2004 10:17 AM
What type of battery pack should I use in my Moth? PDX Slope Pilot Slope 5 Dec 08, 2002 09:40 PM
What flight pack should I use for the Lite Stik? xadmin Parkflyers 2 Nov 13, 2001 12:08 AM
What prop and battery pack? For Speed 480BB Race Teamairplane Electric Plane Talk 3 May 28, 2001 06:00 AM
