I have accepted the risk when I ordered a Hacker 18L and some light weight 1050mah cells. On paper or on the spreadsheet rather, the results seem excellent.
Many think the motor does not have the muscle for the job my views are its no more proportionally smaller than the razor V2 was for the hornet. And I plan to get the bird as light as possible regardless. What are your thoughts guys on my motor and cell choice ? |
The 18l looks surpizingly good efficiency wise, but the head speed looks a little high unless there is an 8t pinion available on a 9t pinion the head speed is up around 2400 and from what I've heard the tail getts crazy on high head speeds. I have also read that Align was working on a differant gear ratio for the tail. If you can knock 2-3oz off the AUW it looks even better(what motor wouldnt
Hacker 18L does look very good on the right pinion. Nice and light as well. T-rex tail is nuts. |
San Carlos, California, United States
Joined May 2002
I'm really surprised the 16/15/3 becomes that hot on the T-rex.
I fly Coronas which weigh 1200 grams on that motor, and the motor doesn't become that hot. For some reason, your T-rex is eating a lot of power. Do you know what the headspeed is on the 16/15/3? From what I've heard, the T-rexes are already heavy, so you want to avoid adding more weight. This kinda rules out the next larger Mega (16/25/2). If you can get pinions large enough, then some sort of outrunner might be a good choice, because they dissipate heat fairly well. Toshi |
I'm new to brushless motors. I'm running a Himaxx 2015-4100 in a HB FP elite and I have another one for a Hornet 2. The power has been great and they also seem to be quieter then brushed motors. I'm amazed how quiet the HB is with the Himaxx. They do seem to run quite warm, though. All of the searching I've done on this subject seems to verify that. Is it true? Does a brushless motor run warm to hot even when properly set up? Is it just the way they are?
Somerset, PA
Joined Feb 2004
Seattle,
I was just searching for threads about hot 2015-4100s. mine is setup HB elite FP with piccolo blades 3S 1100, and gy240. brushless tail. I'm hovering at about half throttle. It was quite warm with the 10t pinion almost to hot to hold. So, just today I went down to 9T pinion and its better, still warm but not hot. I was thinking of going down to a 8T pinion. does anyone use an 8T pinion with this setup? |
Interesting. Maybe I'm over stressing my motor by running a 10t pinion. I'm also using the M24 blades which have quite a bit more mass then stock HB blades. (BTW, the M24 blades are one of the best things you can get for a HB.) I have a Sparrow heat sink on the Himaxx, and after a good 15 minute flight (w/ a TP 1320 3-cell LiPo) it's hot enough that I can not comfortably hold on to the hink sink for more then five to ten seconds. Does this mean I'm running inefficiently and/or hurting the motor? Persistant, if you try 8t pinions, please post your results.
Joined Aug 2004
I'm using the HiMaxx 2015-4100 on my Aerohawk with a 2S TP 1300 LiPo. I too was concerned about the temp, and was looking for longer flight times. Below are the flight times (hovering) and motor temperatures that I measured for each pinion. Note that I am using Like90 blades. The 8-tooth pinion took about 60% throttle for hovering. The 11-tooth was somewhere less than 50%.
8-TOOTH Flight Time=15.5 Minutes Motor Temp= 111 Degrees F. 9-TOOTH Flight Time=14.5 Minutes Motor Temp= 123 Degrees F. 11-TOOTH Flight Time=13 Minutes Motor Temp= 136 Degrees F. The above data seems to indicate that motor stress increases as you increase pinion size, which makes sense. I've since moved off of the 8-tooth pinion in favor of a larger pinion with more power (I'm doing less hovering and more FF now). |
Nice data, MrBruiser. I would of guessed that the temperature differences would be greater between pinions... However, maybe 136 degrees is not so bad. The Himaxx documentation lists the maximum allowable motor temp as 212 degrees F.
I ran a few flights with the canopy off and it did make a difference: the motor was only warm instead of hot. I didn't think the canopy would restrict cooling that much but it seems that it does. I'm going to try mod'ing the canopy to let more air get to the motor and electronics. |
I typically try to stay under 160F so 136 isn't bad, for comparison the B20-22s in my hornet after 20 min of hovering and slow circuts is only in the 126-27F range. the H2 gets the motor a little hotter and cuts into the flight times but I think the heat was still in the 130-135F range after a 15 min flight.
| Thread Tools | |
| Discussion how hot is too hot for esc and motor | rmasu | Mini Helis | 4 | May 22, 2006 04:48 PM |
| Question How hot is too hot for a can motor? | roosevelt | Power Systems | 7 | May 21, 2006 09:33 AM |
| How hot is too hot for motor? | skyhawk | Electric Heli Talk | 6 | Aug 10, 2003 11:26 PM |
| Battery temperature: How hot is too hot for LMR sailplanes | jshelton | Power Systems | 8 | Nov 02, 2001 06:48 PM |
| How hot is too hot for a SP400 motor? | Steve Fehr | Electric Plane Talk | 4 | Oct 22, 2001 03:56 PM |
