Old Sep 26, 2004, 07:19 PM
BQuick is offline
Find More Posts by BQuick
Joined Jun 2002
F-86 Sabre - My first EDF project
Here's my first EDF attept:
24" wingspan.
Go brushless 20mm, 10 magnet motor.
6.6 oz AUW with 3s 600 MaH Li-Poly.
EDF-50 converted.
It flies well, but I would love to have a little more power. It will rog in about 25 feet and will climb at a decent (although shallow) rate. It will loop with a dive and will roll reasonably well. The wing is flat bottom, so it won't fly inverted.
BQuick is offline Find More Posts by BQuick
Old Sep 26, 2004, 08:59 PM
spencer6891 is offline
Find More Posts by spencer6891
spencer6891's Avatar
NC
Joined Aug 2004
Pretty nice. Can you elaborate on how you built it?
Spencer
spencer6891 is offline Find More Posts by spencer6891
Old Sep 26, 2004, 09:08 PM
blucor basher is online now
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
Sweet.
I was flying my Cd-Rom EDF-50 flea tonite. I too would like more power.
Here's what I have:
22.7 mm
6 magnets
16 turns, wye
Flying on 3S340
I saw the video posted in foamies of the Superflea, it's a cdrom edf-40, it's flying like 80 mph. I'd like that. Any advice is appreciated.
If we can figure that setup out, it would make that F86 go ballistic.
blucor basher is online now Find More Posts by blucor basher
Old Sep 26, 2004, 09:43 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Looks great Bquick and it flies, on the power end I cant help you but I hear that the new 12mm motor from Balspr is working pretty good.
Eric B.
AirX is offline Find More Posts by AirX
Old Sep 26, 2004, 11:24 PM
bobspock is offline
Find More Posts by bobspock
Trevose Pa,
Joined Sep 2004
Try using a 5-bladed fan..Balsa Products has them.I have one in a Fantastic Jets mig-15 using a Conversion motor works cd-rom.
The thrust output is almost scary,climbs at 70 degrees after
leaving a easy hand launch
bobspock is offline Find More Posts by bobspock
Old Sep 27, 2004, 07:54 AM
BQuick is offline
Joined Jun 2002
I tried the 5 bladed fan, but I didn't get much more out of it. I think I loaded up the motor too much and drew more current than the motor could efficiently handle.
The plane was built using a hot wire from 2" foam. The front end of the fuselage was cut using a template on the front and the back of it, as was the rear end of the fuselage.
- Brad Q
My first EDF --- Dual EDF F-15 T-T Electric Ducted Fan Jet Talk 35 Jan 31, 2006 05:43 AM
Wanted Alpha F-86 Sabre EDF or close Riot-Pilot~ Aircraft - Electric - Airplanes (FS/W) 0 Nov 28, 2005 10:37 PM
For Sale NIB Wattage F-86 Sabre EDF Jet localbuyer Aircraft - Electric - Airplanes (FS/W) 2 Nov 20, 2005 09:50 AM
Maiden of my f 86 Sabre edf pipsta Fuel Jet Talk 1 Mar 20, 2005 12:43 PM
Pibros Twinn EDF-50 "My first EDF project" Appie Electric Ducted Fan Jet Talk 13 Oct 25, 2002 05:57 PM
