Old Sep 26, 2004, 03:32 PM
noddy is offline
Find More Posts by noddy
I seem to be in toyland
Joined Apr 2004
Maidened my Ripmax Evolution Sport
Title says it all - I flew my first hotliner after two failed attempts. First time I was so nervous I connected the speed controller backwards. Second time I found my new Futaba receiver was faulty. Today no problems and I can join the warmliner club.
Setup was a 3S4p ETEC 1200 LiPo battery, 40A speed controller, separate receiver pack and Jeti 30/3 with a 10/6 CAM folder. Climbs really quickly at about 45 degrees. Makes a wonderful sound when you put the nose down. Slows down really well for sloping or thermalling. But the landing!!!!!!!!! Started finals as usual on my slope site. About 75m downwind I turn for landing. And it just keeps on flying - I have to duck as it shoots over my head and back out on the slope. This is nothing like anything I've flown before!! In desparation I tried the spoilerons - no bunts or other antisocial behaviour so I have another go. Applied the spoilerons as soon as it is into wind and it sinks like a brick into the floor with no fuss.
There is one problem though - as the speed increases it has a tendancy to balloon up. I've read in the review that the tailplane incidence needs altering but does the C of G have any effect on this?
I can understand why so many people spend so much money on hotliners - the feeling is fantastic. Now where did I put that Hacker catalogue........... this could get expensive.
John
noddy is offline Find More Posts by noddy
Old Sep 26, 2004, 05:33 PM
Lenny970 is offline
Find More Posts by Lenny970
Lenny970's Avatar
Greeley, Colorado, USA
Joined Feb 2000
John,
Welcome to the club! You'll now be destined to spending your hours in search of better and better performance......faster airframes, hotter motors, etc. It's a terrible disease that many of us are also aflicted with.
Ballooning up at high speed is usually an indication of a forward CG location, with it's associated "up" elevator trim. The fix is to move the CG back (a little at a time). Each time the CG is moved back, you'll need to trim the elevator slightly "down" to maintain flight trim. Eventually, you should find an elevator trim/CG position that feels good for both high speed gliding and slow speed gliding. If the elevator is offset noticeably from neutral when you get the model trimmed, that is an indication that the incidence can/should be adjusted.
It's likely that the plane will still pitch up when the motor is powered up. You can either mix in some "down" elevator with motor, or just manually push in a bit of down when you run the motor.
Good luck,
Lenny
Lenny970 is offline Find More Posts by Lenny970
Old Sep 26, 2004, 06:15 PM
Mike Seale is offline
Find More Posts by Mike Seale
f5b-uk
Mike Seale's Avatar
United Kingdom, Dorset
Joined May 2002
John
Like Lenny says, get the cg right. But if your tx can, you should also use a 'speed' flight mode. This would give you straight and level flight with the motor on - a shallow dive with motor off. You can then flick a switch to go fast but have an easy return to sedate flight when your nerves have had enough.
Mike Seale is offline Find More Posts by Mike Seale
WARNING: Ripmax Evolution Sport Jonas Leander High Performance 16 Jan 09, 2009 02:48 PM
Question Ripmax Evolution Sport setup question paulw Electric Plane Talk 2 May 19, 2006 12:37 PM
Experience with Ripmax Evolution Sport? Jonas Leander High Performance 3 May 07, 2004 01:20 AM
Experience with Ripmax Evolution Sport? Jonas Leander Electric Sailplanes 0 May 05, 2004 01:25 AM
Maidened my MM Dandy Sport today.... juantrinidad Parkflyers 3 Mar 29, 2003 10:30 PM
