Old Sep 26, 2004, 12:32 AM
springfield,mo
Joined Aug 2003
What's the best T/R motor if you use lipo's
Well i did it! started using 1200ma 7.4 and a 340 11.1 lipo's and guess what? (right) burned up tail motor. using the stock 310 motor. so what is the best solution to this endless problem people are having? DD? D-F? or what. let's talk about this aside from going to seperates
(JERRY)
jmctague is offline Find More Posts by jmctague
Old Sep 26, 2004, 12:54 AM
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Well, the 340's will not handle the main motor and as you found out will burn up te TR motor.
2s lipos will work very well DD on the TR. People use the 1200's so the heli still balances.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Sep 26, 2004, 01:07 AM
Australia
Joined Mar 2004
buy a brushless tail motor, you will never have any trouble again
Philpops is offline Find More Posts by Philpops
Old Sep 26, 2004, 01:22 AM
Life-One flight at a time
HBirdV.2's Avatar
B.C Canada
Joined Jul 2004
I run a EDP-50 DD tail motor with heat sink and it doesnt even get warm on a 2S Lipo and Acro280BB main motor. (Hummingbird Helicopter)
The EDP-50 is great and even better with a 3030 prop
HBirdV.2 is offline Find More Posts by HBirdV.2
Old Sep 26, 2004, 01:31 AM
Dionysus Design
Chico, CA USA
Joined Nov 2003
There isn't much you can do except go seperates. A high frequency tail ESC will give back the tail motor life. With that aside, using a tail motor with carbon brushes is the only real thing you could do. I have also found that cutting my main blades reduced the strain on my tail motors, but that may also cause other issues with lift, etc.
DD will draw more current than the geared tail motor setup, so I recomend sticking with the gears for right now.
Dan_Jones is offline Find More Posts by Dan_Jones
Discussion What's the best size Saito for all purpose use on 46-50 size models CustomPC Engines 5 May 20, 2007 04:10 PM
Alert If you use Lipo then you have to see this jmm Batteries and Chargers 1 May 20, 2005 07:19 AM
What's the best fully R/C 1/2A engine? thrashaero Engines 1 Jan 07, 2003 07:26 PM
What's the best way to secure MP Jet Gearbox and a 280 motor? twng Beginner Training Area (Aircraft-Electric) 2 Mar 05, 2002 08:35 AM
What's the best brushless system (motor/controller) for .40 to .60 sized sport planes rsieminski Power Systems 8 Jan 27, 2002 09:54 PM
