Old Mar 15, 2005, 03:32 PM
Daniel11 is offline
Find More Posts by Daniel11
Daniel11's Avatar
Vicksburg, MI
Joined Jul 2004
Any P-51s?
-Daniel
Daniel11 is offline Find More Posts by Daniel11
Old Mar 15, 2005, 06:01 PM
ronnath is offline
Find More Posts by ronnath
ronnath's Avatar
Iowa
Joined Oct 2001
click on the link
go to WWII>fighters>north american P-51>USA
it lists over 70 of them.
start clicking on each one for a bigger picture.
ronnath is offline Find More Posts by ronnath
Old Mar 16, 2005, 12:39 AM
yankeecanuck is offline
Find More Posts by yankeecanuck
Canada, BC, Victoria
Joined Sep 2003
Twin ducted-fan foamy plans
http://www.rcmicroflight.com/plans/2jet/2jet.asp
yankeecanuck is offline Find More Posts by yankeecanuck
Old Mar 16, 2005, 06:25 AM
taekwondo is offline
Find More Posts by taekwondo
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
So many planes to build, so little time.
taekwondo is offline Find More Posts by taekwondo
Old Mar 16, 2005, 04:41 PM
natetanr is offline
Find More Posts by natetanr
Utah Flyers
natetanr's Avatar
Farmington, UT
Joined Dec 2004
Combat EPP Wing
Wild Wing EPP
Pictures and Instructions also Instructions to build a foam cutter
http://www.utahflyers.org
natetanr is offline Find More Posts by natetanr
Old Mar 16, 2005, 05:35 PM
Daniel11 is offline
Daniel11's Avatar
Vicksburg, MI
Joined Jul 2004
Originally Posted by ronnath
click on the link
PLANS, not side views, although there are some interesting ones.
-Daniel
Old Mar 30, 2005, 12:28 PM
TGC is offline
TGC
Find More Posts by TGC
TGC
AMA1940
TGC's Avatar
Indian Lake, Ohio
Joined Apr 2004
L-19, O-1, Cessna 170, Bird Dog Plans & Docs
t1mux (Tim) and thatovalguy (Howard) have collaborated on a project that gives you full-size plans and extremely high resolution color graphic skins to build 4 different color schemes of the L-19 and O-1 versions of the Bird Dog using FFF Blucore or Depron.
As scaled, the plans will give you a 36 inch / 915 mm. wingspan. Left click each individual example of the 4 profiles and then click the enlargement icon for a high resolution .jpg file (3696 x 2854 pixels) before downloading each plan. Your full-size printout will be about 30" x 40". Use MS Paint (or your personal favorite) to tile it out for your printer size sheets.
Just click here for the free plans post..
thatovalguy's thread #9 with the building discussion is here. (Post #102)
Additional documentation, historical info, photos and Bird Dog links are here.
Cheers! Tom
(The wing mounted armament in Photo #2 is 4 x 2.75" Willy Pete rockets!)
TGC is offline Find More Posts by TGC
Old Apr 02, 2005, 10:49 AM
mad mike is offline
Find More Posts by mad mike
I crash, therefore I FLY!
mad mike's Avatar
Spring Hill, FL
Joined Feb 2003
WaterDog has posted two threads with links to pdf instructions and tiled plans! One is for his amazing ST, the other is for it's "little brother," the STC.
The ST will make a fantastic AP ship, while the STC could easily serve as a "trainer" version. Both could also easily be built as "fun-flyers," if you aren't interested in AP. Both designs use the *same* building method, so if you want to experiment with the STC, you'll be able to use what you learn from building and flying it, to follow up with the larger ST. How's that for a confidence builder?
Of course, these are designed for FFF or depron.
The threads:
WaterDog's ST
WaterDog's STC
Don't know if you are interested in building either one? Both threads contain several videos that will help you decide!
Mike S.
mad mike is offline Find More Posts by mad mike
Old Apr 06, 2005, 06:35 PM
chue is offline
Find More Posts by chue
chue's Avatar
Joined Mar 2005
Many good planes of paper airplanes
http://istf.fw.hu/air1.html
Modesto
chue is offline Find More Posts by chue
Old May 02, 2005, 05:16 PM
theBOZman is offline
Find More Posts by theBOZman
__Jackass Savant__
theBOZman's Avatar
United States, CA, Oxnard
Joined Feb 2005
Here' the real post!
I thought this was supposed to be for free plans?? Come on guys, Kick!
1500+ free plans in to different formats!
It's a bittorrent download. That way, the more people that are downloading it, the faster it goes!
If you don't know what bittorent is, then I recomment using the original client. It's a very simple interface.
http://www.bittorrent.com/
Install Bittorent client, then click on the download link in Internet Explorer as usual. Select "open", then it will ask you where you want to save the completed ZIP file. You can start and stop the download if you need to.
Here's the all 1500+ plans, in one ZIP. Over 600Mb worth of plans!
[non-family-friendly URL name deleted by moderator]
:412/torrents/All_1500_Airplane_Plans.zip.torrent?17174309899036 939AC32364E4C0AF46497FE8EC[/url]
theBOZman is offline Find More Posts by theBOZman
Old May 02, 2005, 06:27 PM
Matt Chester is offline
Find More Posts by Matt Chester
Matt Chester's Avatar
Newnan, GA
Joined Oct 2002
I tried to download that, from a T3 connection, and got a whopping 8kbps, told me it would only take 4 days to download!!!!!! I would like to see what you have, but geezzz that is rediculous.
-matt
Matt Chester is offline Find More Posts by Matt Chester
Old May 02, 2005, 07:44 PM
JAM is offline
JAM
Find More Posts by JAM
JAM
MaxAmps CMO
JAM's Avatar
Nine Mile Falls, WA
Joined Jun 2004
DEL
JAM is offline Find More Posts by JAM
Old May 02, 2005, 08:05 PM
derailed is offline
Find More Posts by derailed
rc transports rule!
new brunswick canada
Joined Jul 2002
there are better sources
why not use one of the better ones?
i tried that one and it's slower than molasis in winter
i dropped it and went with faster ones
derailed is offline Find More Posts by derailed
Old May 03, 2005, 03:17 AM
__Jackass Savant__
theBOZman's Avatar
Joined Feb 2005
deleted
Old May 03, 2005, 07:38 AM
Newnan, GA
Joined Oct 2002
Is there anywhere you can just put it on a server for FTPing?
How do I ping you and check for latency?
I will try again from my brother in laws Cable Modem.
Alert Free plans thread move???? JAM Foamies (Scratchbuilt) 8 Aug 11, 2006 06:26 AM
gws edf 50 free plans thread Pablo_s Parkflyers 5 Jan 24, 2005 10:21 AM
Yippee! Please post your links to free plans HERE! CactusJackSlade 3D Flying 12 Oct 08, 2004 01:30 PM
The Great 'Links to Free Plans' Thread! (split by moderator) Zachary Foamies (Kits) 6 Oct 01, 2004 09:46 AM
Yippee! Free plans Thread JAM Foamies (Kits) 11 Sep 25, 2004 10:29 AM
