Old Sep 23, 2004, 10:52 PM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
AXI Stator Coating - What IS that stuff?
My Axi was sounding a little raspy when spinning the prop after one of my "nosedig" incidents, and the shaft had been drive back a fraction of a millimeter such that groove which seats the tiny retainer clip was no longer visible (the retainer clip was still on the shaft, though). I suspected I may have gotten some dirt into the can, so I disassemble it to take a look. Here's a pic of what I found.
What is that resinous coating on the outer surface of the stator plates? Obviuosly I "sanded" some of it off by getting dirt into the can, but the motor has been used a number of times since, and performance seems normal. So, I don't think any serious damage has been done, but this stuff was put there for a reason. If anyone knows what it's for, what it is made of, or whether it needs to be replaced, I'd like to hear from you.
My best guess is it was put there for abrasion resistance for the ends of the stator plates in case you get dirt inside the can
Finally, I need to loosen the set screw holding the shaft to the can so I can move the shaft forward a few thousandths to expose the clip ring groove again. I don't have an allen wrench small enough... does anyone know what size it is?
Tom Frank is offline Find More Posts by Tom Frank
Old Sep 24, 2004, 12:52 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
I know it as winding varnish and it is common practice with motor winders and transformer manufactures to seal their products against moisture and loose winding movement, what the formulation is today i dont know ,but i use epoxy. as for the hex key probably a metric size.
olmod is offline Find More Posts by olmod
Old Sep 24, 2004, 01:17 AM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
This stuff is only on the ends of the stator plates, not on the windings themselves, and has a mottled color, not like a varnish.
I can easily smear on a little epoxy over the abrasions if I keep it thin so the magnets don't make contact. Thanks.
Tom
What is that Soft Silver Stuff? Pookee Batteries and Chargers 4 Feb 17, 2005 09:36 PM
Yippee! What if AXI made a prop hub that would drive GWS props? Maybe something like this. power Power Systems 19 Mar 11, 2004 07:10 AM
Tohru san, what is that on your logo 10? Steph280 Electric Heli Talk 1 May 08, 2002 04:49 AM
What is THAT Adventura II part for? temacc Electric Plane Talk 2 Mar 13, 2002 10:20 AM
What is that Cobalt motor smell? Greg Covey Sport Planes 3 Dec 23, 2001 11:25 AM
