Old Feb 10, 2002, 10:28 AM
sgil2001 is offline
Find More Posts by sgil2001
R/C Enthusiast
sgil2001's Avatar
Craley, Pennsylvania, United States
Joined May 2001
Shelf life of epoxy?
What is the shelf life of epoxy glue? I have some 30 minute epoxy thats about 10 years old.
sgil2001 is offline Find More Posts by sgil2001
Old Feb 10, 2002, 10:42 AM
davidfee is offline
Find More Posts by davidfee
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
It depends...
But usually I'd say 3-5 years. Test it before you use it on anything important. It will still work as an adhesive, but it probably woudn't be as strong and stiff as fresh epoxy. If it stays gummy, then you know it's time to toss it.
davidfee is offline Find More Posts by davidfee
Old Feb 10, 2002, 10:59 AM
RRD is offline
RRD
Find More Posts by RRD
RRD
United States, NC, Asheville
Joined Oct 2001
I would pitch it if you notice any increased viscosity (other than temperature change) in the unmixed components . Every time I have used epoxy in this state it has been much more expensive and troublesome to remove the half-cured epoxy than just buying new epoxy in the first place.
Bob
RRD is offline Find More Posts by RRD
Old Feb 10, 2002, 11:34 AM
J Morgan is offline
Find More Posts by J Morgan
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
I've had it so long at times that one part(can't remember which) wuld turn hard and white in color. Just put it in heated water on the stove and it goes right back to original consistency and color, cures out just like before.
J Morgan is offline Find More Posts by J Morgan
Old Feb 10, 2002, 11:57 AM
davidfee is offline
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
Originally posted by J Morgan
I've had it so long at times that one part(can't remember which) wuld turn hard and white in color. Just put it in heated water...
Yes, some epoxy resins will crystallize if they get too cold for too long. Heating them will usually un-do this. A microwave or conventional oven is better than water, because the water can contaminate the epoxy.
The bigger problem with old epoxy is usually the hardener. Many hardeners degrade over time... either by absorbing water from the air, oxidizing or otherwise decomposing. Many times there will be a color change in the hardener (usually it gets darker). This is not easily un-done... so it's best to chuck the stuff in the bin.
Again, if it's important, just chuck the old epoxy and get some fresh. It's not really that expensive, compared to messing around with bad epoxy.
Old Feb 10, 2002, 12:33 PM
sgil2001 is offline
R/C Enthusiast
sgil2001's Avatar
Joined May 2001
I figured I should just throw it away, but it was a full container. It seemed like such a waste.
Old Feb 10, 2002, 03:31 PM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
I think that water contamination is the only problem. I have some that is over 15 years old and still performs the same. I have to re-melt the resin every few years in a microwave and this may help to drive off moisture. Not a food microwave, by the way.
1:1 hardener often has a shelf life of only 2 years. Gougeon says "shelf life of many years" for West Systems epoxy.
Rick.
rpage53 is offline Find More Posts by rpage53
Old Feb 10, 2002, 03:33 PM
sgil2001 is offline
R/C Enthusiast
sgil2001's Avatar
Joined May 2001
I tried mixing some up before I threw it away. It didn't set-up properly. It's still tacky.
Do new Nicads have a shelf life? Sal C Power Systems 7 Oct 30, 2004 09:48 PM
Motor shelf life? Vonbaron Electric Plane Talk 5 Jan 26, 2002 11:53 AM
Shelf life of epoxy? mtayl Power Systems 0 Sep 07, 2001 10:49 AM
Shelf life of a kit? MMGM Electric Plane Talk 7 May 05, 2001 12:51 AM
