Feb 10, 2002, 10:52 AM
Riverhead NY USA
Joined Dec 2000
Tiny V-Tail
d12bn -
Tail (elevator) up, Flaps (ailerons) down, plane goes up and vice versa.
Right tail (rudder) up, right aileron down, left rudder down, left aileron up, plane goes left and vice versa.
On a V-tail to determine which way the plane will turn, tip the plane so one or the other tail surface is vertically up (to the ground). When you look at it from the rear, it's effect will be the same as a conventional rudder.
I had quite a time getting the Tiny's surfaces mixed correctly and didn't succeed until I had the servos reversed (or not) properly. It's a bit confusing but doable.
Good luck.
Ron
P.S., What happens when the plane (Tiny) is inverted?
