Old Sep 23, 2004, 08:25 PM
BulletMaster is offline
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
Brushless suggestions for PC9
Guys,
I have an Awesome Models PC9 plane. It currently has a Wattage 400 size cobalt motor in it. Using NiCd batteries at the moment due to current draw (20 - 27 Amps).
What I would like to know is does anyone have any suggestions for a better brushless type powerplant? (I am using a JustGoFly 400DH in a Zoom heli at the mo' and it is cool). I would really like to run this thing on LiPo, but the current draw really restricts the packs that can be used. I also don't want to have to pay more for the battery than the plane is worth!
Tony
BulletMaster is offline Find More Posts by BulletMaster
Old Sep 23, 2004, 09:33 PM
Trikky is offline
Find More Posts by Trikky
Balsa Abuser
Trikky's Avatar
Wyong, Australia
Joined Jul 2003
Tony,
you could look at something from the mega 16/15 range sp480 size motor.
16/15/5 8cells 7x4 prop 12500rpm@16A
or
16/15/7 8cells 8.5x5 prop 9600rpm@11.3A
Or I am sure that one of the Himark brushless motors would work too.
Chris
Trikky is offline Find More Posts by Trikky
Old Sep 24, 2004, 03:04 AM
Chillaxin dude!
Joined Apr 2003
Chris,
Thanks for that...any idea of the KV rating onthe motor (Himark)? also would it be a 2025 or a 2015 can size?
Those currents sound much more like it...I should even be able to use my LiPo's from my Zap for the whole shebang!
cheers
Tony
Old Sep 24, 2004, 08:57 AM
dalelvn is offline
Find More Posts by dalelvn
Garland , Texas
Joined Sep 2003
well the himax 2025 4200 geared at 5.33:1 would be a very good option also e-flite has its park 400 brushless both of which are drawing around 11amps wot.
dalelvn is offline Find More Posts by dalelvn
Old Sep 24, 2004, 04:07 PM
DrZiplok is offline
Find More Posts by DrZiplok
USA, CA, San Francisco
Joined Feb 2004
Odd that you don't mention the 16/15/6. It works well with the APC 8x4 at around 16A static on a second-generation TP2100, as well as on 8 cells.
One thing to consider is that the Wattage cobalt 400 is heavy; if you replace it with a lighter motor/battery setup, you may have CG issues.
= Mike
DrZiplok is offline Find More Posts by DrZiplok
Old Sep 27, 2004, 08:42 AM
dalelvn is offline
Garland , Texas
Joined Sep 2003
well since I use Kotkam 1500 cells want to stay under 12 amps wot that why i use this set up
Old Sep 27, 2004, 12:01 PM
RC4_LIFE is offline
Find More Posts by RC4_LIFE
3D Wannabe
RC4_LIFE's Avatar
Temple, TX
Joined Sep 2004
Hey Bulletmaster - how sturdy is the PC9? I have been thinking about getting one and use Himax 4100 or 4200 geared in that Bad boy.. Thanks in advance
RC4_LIFE is offline Find More Posts by RC4_LIFE
Old Sep 27, 2004, 04:58 PM
Dennis L. Payne is offline
Find More Posts by Dennis L. Payne
Singapore Seletar, Singapore
Joined Nov 2001
I used the UltraFly A24 motor in my PC-9, using a 8 x 6 APC-E on a 1,500 mA Kokam it was showing 102W on the Wattmeter. The model seems to more solid than the Hawk.
Dennis L. Payne is offline Find More Posts by Dennis L. Payne
Old Sep 27, 2004, 08:25 PM
Chillaxin dude!
Joined Apr 2003
RC4,
The version that I have is not a foamie, but has a built up wing/tail feathers and a plastic fuse. Can't give you a flight report yet as it has been far too windy around here to give it a go. Don't really want to try this one out in the local park (where I fly my other slow flying things) so am really limited to flying at a local club field.
Actual build quality is very nice...covering is good and the graphics really make this a sweet looking plane.
Cheers
Tony
Old Sep 28, 2004, 03:55 PM
RC4_LIFE is offline
3D Wannabe
RC4_LIFE's Avatar
Temple, TX
Joined Sep 2004
Bulletmaster,
My mistake but Thanks anyways. I should have read a little closer. Still interested
in the flight report though... I live in a valley area and it's pretty windy most of the times. Any maiden flight should be done without the pesky wind to ruin it...
RC4
Old Sep 29, 2004, 10:06 PM
thespit is offline
Find More Posts by thespit
Chris
bundaberg
Joined Jun 2004
Hi Tony. I've just swapped the standard cobolt motor and nicad bat over to a himark 20.15 4100 with a himax gearbox that came with 3 ratios (im using the middle sized gear .not sure what ratio it is) and 11.1v 2200 ma lipo pack.All i can say is WOW what a difference , level flight at just over 1/4 throttle and landings are so much slower, makes the little pc9 so much better in every way .after a 15 min flight doing loops rolls etc my charger only put 900mah to charge the bat again . worth every cent i reckon Thanks Chris
thespit is offline Find More Posts by thespit
Old Oct 04, 2004, 04:25 AM
Chillaxin dude!
Joined Apr 2003
Chris...
thanks mate...great suggestions. Thanks to all that have put forward some ideas. I have also been given the suggestion of retaining the cobolt and using 2 packs in parrallel of 2000 LiPo's (2s1p). Might give this a go too.
cheers
Tony
Old Oct 04, 2004, 06:26 AM
Trikky is offline
Balsa Abuser
Trikky's Avatar
Wyong, Australia
Joined Jul 2003
Hey btw Tony,
how does it fly?
Chris
Old Oct 05, 2004, 06:37 AM
Chillaxin dude!
Joined Apr 2003
Chris,( Trikky version .....lol)
Been too windy so far (plus went to Adelaide last weekend.... to play with model powerboats). So, still no flight time yet
This is my first aileron low winger (fine with helis, and 3 channel models). So, looking forward to giving it a fling.... Also got a scam-blur flying wing on it's way to me. So got lots of toys to crash!! (hopefully not!)
Will post flight report when I actually get the beast in the air!
cheers
Tony
Old Oct 16, 2004, 08:34 AM
Chillaxin dude!
Joined Apr 2003
Still no joy with a maiden flight...but had the scram-blur in the air. What a hoot....great fun. Fast and does rolls quite quickly. Guess I better get joined with a local club now that I have something that is a bit more respectable to fly with the nitro guys.
When will this wind ever STOP???
Tony
Brushless suggestions for a Birdie Ten? Fubar-One Power Systems 0 Oct 28, 2004 08:04 PM
Brushless suggestions for MM 180 Steviewonder Parkflyers 4 May 15, 2004 12:00 AM
Brushless suggestions for GWS Planes? bigbookfrank Parkflyers 14 May 09, 2004 06:45 PM
Brushless suggestions for Zagi xs MUDBOGGER2 Power Systems 1 Feb 08, 2004 09:49 PM
Brushless suggestions for a Devastator TwinSpar Foamies (Kits) 9 Dec 29, 2003 03:45 PM
