Sep 24, 2004, 08:24 PM
Albuquerque NM
Joined Oct 2003
Tony, Thanks, I was hoping that no one would take offense to the Sub review in the boat section. I justified it by being a "scale" boat as well.
I agree that working with large vac-formed sections can bring out the "best" in me too (if you know what I mean!), and yes, the half shells are a bit on the flimsy side until the internal components go in --But, in this case it's not as bad as it might seem. I miked the hull section and found it to be .045 thick, so it probably started out as .062.
To get started, you first score the hull sections along a clearly difined line along the inside of the shells, which is about 1/8" above the fold line where the plastic takes the 90 degree turn at the bottom. It's best to take your time and make the scribe slowly so the knife doesn't slip off the line leaving a crooked cut. I made 3 light passes with the knife, then broke the plastic along the scored line and basically "tore" the carrier sheet away from the hull section. It is a bit tediouse, but really not all that bad. The good news is that that is the first step in the instructions, so once that's done, it's all down hill from there!
Once the hull sections are seperated from the carrier sheet, tape a full sheet of 100 grit sand paper to a flat board and rub the hull section over it to clean up the irregularities along the edge. Go at it with only a light to moderate preasure, or it will have a tendancy to take too much off the middle, leaving a big arc at the mating surface of the upper and lower sections. Then, lay the hull section on the board and look for high or low spots, which will be fixed with a more "localized" effort, only where its needed.
The process of trimming and dressing the hull sections took about an hour and a half, but a little extra time spent here will save a bunch later.
Hope this helps, but if you need more detailed specifics let me know and I'll do what I can. Actually, doing this kind of thing isn't new to me, as I have built MANY 1/48 and 1/32 scale vac-formed plastic airplane kits over the years, so the technique really isn't "new", it's just "bigger". If it's your first time out though, TAKE YOUR TIME and work CAREFULLY. Like anything else, it's another modeling skill that will devope only by doing it.
Besides, I get bored easy, so I need one like this to wake me up every now and again. And just as an added incentive, the next one up after this is project is the Dumas "Typhoon". I've been looking at that kit for YEARS and am truely "chomping at the bit" to get started!!!
PAT
