Old Sep 22, 2004, 10:35 AM
ctoms is offline
Find More Posts by ctoms
Charlie Toms
ctoms's Avatar
US
Joined Feb 2003
Fuel tank fill line q's
On a plane like the Hangar 9 Funtana 40, how do you fill the fuel tank with the cowl over the engine?
On my other plane I just pulled off the line to the carb and filled the tank that way.
Do I run a third line from the tank and have some sort of clamp on it when not filling.
Charlie
ctoms is offline Find More Posts by ctoms
Old Sep 22, 2004, 12:26 PM
mudfarmer_mike is offline
Find More Posts by mudfarmer_mike
Senior Member unum multum
mudfarmer_mike's Avatar
United States, AL, Huntsville
Joined Dec 2001
Charlie:
I've seen it done a couple of ways.
Run 3 Lines. Connect the third line to a fuel dot thats mounted through the cowel. The fuel dot will plug the line when not in use and allow you a port to re-fuel.
Or,
you can run 2 lines and connect a fuel dot between the tank-to-carb line
using a tee.
mudfarmer_mike is offline Find More Posts by mudfarmer_mike
Old Sep 22, 2004, 01:00 PM
globemaster3c17 is offline
Find More Posts by globemaster3c17
Calm winds and CAVU skies
globemaster3c17's Avatar
Lawton, OK
Joined Jan 2004
Or you can use another product like this one http://www2.towerhobbies.com/cgi-bin...?&I=LXK135&P=0 I haven't had a problem with mine so far, but I've been told that the valve doesn't close completely after a while. When that happens, you don't get fuel to the carb.
globemaster3c17 is offline Find More Posts by globemaster3c17
Old Sep 23, 2004, 09:32 AM
Dustoffer is offline
Find More Posts by Dustoffer
McMinnville, Oregon
Joined Jul 2004
They are right globemaster. After 4 years on my corsair I finally had to change one out. Looked like the small rubber seal loosened and was causing the valve to stick. No big deal, it paid for itself after 4 years of pretty heavy flying.
- Kevin
Dustoffer is offline Find More Posts by Dustoffer
Help! YS-91 Engine Fuel/Tank/Fill/Vent Line Hook-Up (Again) TheSaint Engines 17 Jan 16, 2011 02:39 PM
Correct way to fill the fuel tank. Pete K Engines 6 Oct 06, 2005 11:11 PM
What is the correct way to fill the fuel tank? Pete K Beginner Training Area (Fuel) 2 Oct 02, 2005 11:13 PM
H9 Funtana s 40. fuel tank Ants Fuel Plane Talk 0 Feb 19, 2005 03:19 PM
