Old Feb 08, 2002, 11:28 PM
ZAGIZAGI is offline
Find More Posts by ZAGIZAGI
ZAGIZAGI's Avatar
Los Gatos, CA
Joined Apr 2001
Cheapest battery source to power charger
I'm interested in getting a battery to run my charger from at the field, because the constant use of my car battery for this purpose is hurting it. What I'm looking for is the best value for the money. I'd prefer to spend 40$ or less. I'd prefer gell cell to wet cell. Any ideas?
-ZagiZagi
ZAGIZAGI is offline Find More Posts by ZAGIZAGI
Old Feb 09, 2002, 02:27 AM
Ben74 is offline
Find More Posts by Ben74
Ben74's Avatar
San Francisco, CA, USA
Joined Jun 2001
i got a deep-discharge marine battery at costco for about $45. perfectly suited to the job. i actually killed my car battery charging packs off it, and replaced it with the marine battery. the marine battery has plenty of juice to start the car, and it should not be hurt by frequent discharging.
Ben74 is offline Find More Posts by Ben74
Old Feb 09, 2002, 10:51 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Careful, somewhere I heard, read or was told that a marine battery doesn't get along with an automobile system.
I keep my 'marine' in a battery box just on the outside wall of my 'little corner of the house'. Got a cable going in thru the wall and a female plug on the end of it, with a matching male on my charger for 'home charging'.
On this same cable(2-10 gauge wires/wrapped), 12" to 16" from the box and just before it goes in thru the outside wall is another male/female plug setup(just like the inside). Unplug this plug, toss the box in the truck and SECURE IT IN PLACE(you think the zagi battery can do some damage ).
Works great.
William A is offline Find More Posts by William A
Old Feb 09, 2002, 11:00 PM
ZAGIZAGI is offline
ZAGIZAGI's Avatar
Los Gatos, CA
Joined Apr 2001
Thanks for your responses, guys, but I'm looking for a solution that doesn't involve lugging around a big wet battery. I have a Camry, too, not a truck.
I've seen some guys using something like this: http://www.batterychargers.com/detai...%2D3A&catid=12
Problem is, the units like these I have seen are more than 40$. More like 60$-100$. I heard someone mention the gel cell batteries used in motorized wheelchairs, but the ones of those that I have seen are pricey too.
jlk is offline
jlk
Find More Posts by jlk
jlk
Lifetime Beginner
jlk's Avatar
Chicago & Tucson
Joined Sep 2001
Can't think of a reason not to put a marine battery in a car. The one in my boat charges off a V-8 that looks like it has the same charging system as a car. My understanding is that the marine or deep cycle battery has thicker plates so they don't warp when completely discharged (not a good idea for a car battery as Ben found out).
Jordan
jlk is offline Find More Posts by jlk
Old Feb 09, 2002, 11:08 PM
russ6421 is offline
Find More Posts by russ6421
russ6421's Avatar
ny
Joined Dec 2000
Any Deep- Cycle should not be used in a car. They are made to Discharge slowly and to charge slowly. A car battery is made to give out high cranking amps when you start your car and will charge fast. Most cars of today have a 100amp Alternator but the battery won't charge anywhere near that. Someone I know went thru two deep-cycles before he got smart. Some will get away with it some won't. If you have a small 4cly. maybe and 8 cly probably not for long and some real cold morn you will be walking to work. But the Marine battery is just a heavy duty car battery where the deep-cycle is more for your elec trolling motor and will run it all day or run you RV lights when at camp
russ6421 is offline Find More Posts by russ6421
Old Feb 09, 2002, 11:14 PM
coastalflyer is offline
Find More Posts by coastalflyer
Build/Fly/Crash/Repeat
United States, CA, Diablo
Joined Jan 2002
There is no reason whatsoever that a marine battery won't function correctly in a car.
I use a 12 volt 7A maintenance free battery that is relatively small, lightweight and very portable. Totally meets my needs, which are relatively lightweight. Cost me $17.00 new.
Deciding what size battery YOU need depends on what you're charging. What are your typical daily needs?
Finding a marine battery within your budget will be difficult, if not impossible. They aren't cheap, but then you get what you pay for.
Look at Costco and Sears.
coastalflyer is offline Find More Posts by coastalflyer
Old Feb 09, 2002, 11:18 PM
russ6421 is offline
russ6421's Avatar
ny
Joined Dec 2000
I agree a marine battery will work in a car just don't mix up marine with deep-cycle they are two different animals
Old Feb 09, 2002, 11:24 PM
jlk is offline
jlk
jlk
Lifetime Beginner
jlk's Avatar
Chicago & Tucson
Joined Sep 2001
I guess I should get another battery to start my boat.
Jordan
Old Feb 10, 2002, 12:01 AM
Joined Jan 2002
Actually, they are and they aren't.
Marine batteries are of two types. Deep cycle marine batteries and starting marine batteries.
Deep Cycle Batteries are used where discharging and charging occurs frequently.
Batteries without substantial materials designed for true deep-cycling will lose more than half of their capacity after only a few cycles. A 200 Amp-hour battery will shortly become a 100 Amp-hour battery for the remainder of its shortened service life. What initially may seem to be an inexpensive battery to purchase, now costs twice as much per Amp-hour. True Deep cycle batteries will perform well as cranking batteries, however, cranking batteries will not survive deep cycle use.
Deep cycle batteries can be used in any application and exhibit a long service life, while cranking batteries are limited to starting applications only. Cranking batteries exhibit poor service life in cycling applications.
Reference: http://www.dcbattery.com/
http://www.dcbattery.com/faq.html#2
Old Feb 10, 2002, 12:05 AM
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
FYI, In my post above, the word "marine battery" is meant as the deep-cycle type.
Power Charger with Car Battery Charger? Inverted-3D Electric Heli Talk 3 Oct 29, 2008 01:11 PM
Battery charger adequate source of power? Starfox9 Batteries and Chargers 6 Aug 19, 2004 05:16 PM
Power source for charger almies Batteries and Chargers 8 Sep 20, 2003 12:36 PM
power source for charger nose_first Batteries and Chargers 5 Sep 10, 2003 05:58 AM
