Old Sep 18, 2004, 10:33 PM
fmidgett is offline
Find More Posts by fmidgett
fmidgett's Avatar
Durham NC
Joined Jul 2004
Question
How to test Lipo capacity?
I have 4 Kokam 1200mah 11.1v packs I bought used. One had a bad (puffed up) cell when I got it. When hooked to Kokam charger all lights blinked indicating a problem. I took off the bad cell. Now charger indicates no problem on the 7.4v pack, but it only lasts about 30 seconds before running down. Another pack looks fine, charges fine, lights indicate normal operation, but it also only lasts about 30 seconds. Only one of the cells in this pack gets warm during use, yet all individual cells read the same.
Is there a way to know for sure which cells are good? (If any).Two of the packs work fine. Last for 20 minutes in my Christen Eagle. Is there a way to measure mah capacity besides running the battery for x number of minutes?
Fred
fmidgett is offline Find More Posts by fmidgett
Site Sponsor
Old Sep 18, 2004, 11:45 PM
adamg is offline
Find More Posts by adamg
adamg's Avatar
Saskatoon, Canada
Joined Feb 2004
Even running the battery and recording time doesn't tell you mah directly, and a true constant current load is not an easy thing to come by. A decent charger will do what you need (Triton, etc).
adamg is offline Find More Posts by adamg
Old Sep 19, 2004, 08:23 AM
KEC is offline
KEC
Find More Posts by KEC
KEC
Joined Feb 2004
Fred
I have started to experiment with the Medusa Research Power Analyzer Plus.
I attempted (but failed) to add a voltage graph for a discharge test that I did last night. I discharged a 1200mah 3s1p pack through a 20W 8ohm resistor and monitored it with the Medusa Research Power Analyzer Plus. It also plots current, power, amp hours, and watt hours.
I have also created the gender changer cables so that I can monitor charging.
KEC is offline Find More Posts by KEC
How to cool lipo while running cba test bobf Batteries and Chargers 5 Oct 08, 2005 04:03 PM
How do you test a Lipo's capacity without fancy equipment? CloudyBright Batteries and Chargers 28 Dec 17, 2004 12:25 AM
How to tell LiPo discharge capacity? flanker Batteries and Chargers 0 Jun 30, 2004 10:52 PM
How to test end to end solder joints? Jim McPherson Power Systems 1 Oct 08, 2001 08:21 AM
How to test if a nicad is properly charged John Webb Electric Plane Talk 11 May 09, 2001 10:52 AM
